Sparetyre Neutral Newbie July 5, 2002 Share July 5, 2002 I think it's 75W per ch RMS bridgeable to 2x75W. See how lor, I'll visit Geof tomorrow and get his opinion. FYI. Sony XM-222 MK2 Key Features DC/DC Converter with MOSFET Power Supply High Level Input Specifications Max. Power Output : 4 ohm 2ch : 90W x 2 1ch : 222W x 1 Rated Power Output : 4 ohm 2ch : 35W x 2 1ch : 80W x 2 S/N Ratio : 100dB Dimensions (W/H/D) : 205 x 55 x 158mm ↡ Advertisement Link to post Share on other sites More sharing options...
Kenesh Neutral Newbie July 5, 2002 Share July 5, 2002 wat time u going down?? I'll be dropping by to see Geoff tomorrow as well. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 5, 2002 Share July 5, 2002 Err....CH, how to read the specs? What's with the max output and spec output difference? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 5, 2002 Share July 5, 2002 I should be there tomorrow around 2:30pm....see what he recommends with the old stuff I have Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie July 5, 2002 Share July 5, 2002 the 222W is the max i think. You should be more interested in the RMS rating rather then the max. Link to post Share on other sites More sharing options...
Kenesh Neutral Newbie July 5, 2002 Share July 5, 2002 should be able to catch u there tomorrow after I fix up my Philips BV Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 5, 2002 Share July 5, 2002 OIC, so may not be enough to drive the bazooka tube eh? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 5, 2002 Share July 5, 2002 Okie, see U then! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie July 5, 2002 Share July 5, 2002 OIC, so may not be enough to drive the bazooka tube eh? Should have told me you are buying an amp....Just sold off my 4ch amp....rated at 75W RMS per channel.... More than sufficient for you...... [angelic] Then we could have done a barter trade... 1 amp for the magnets and mintex... Link to post Share on other sites More sharing options...
Davey Neutral Newbie July 5, 2002 Share July 5, 2002 Hey Bro, how's your car dude?! Cheers! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie July 5, 2002 Share July 5, 2002 Hey Bro, how's your car dude?! Cheers! Hey, long time no see!!! Violet will be discharged next week. How about yours? Everything OK? I can't find Eibach, so went for HotBits.... Will only know about the comfort level next week. If you are free, let's meetup and we can cut the mesh wire grille together. BTW, got your OZ Super Legg already? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 5, 2002 Share July 5, 2002 CH, can help my cousin try DIY wire meshing on his Hyundai Accent? Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie July 6, 2002 Share July 6, 2002 CH, can help my cousin try DIY wire meshing on his Hyundai Accent? Of course!!! How about another MCF Garage session next Thur or Fri?? Violet should be discharged by then...hopefully. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie July 6, 2002 Share July 6, 2002 Of course!!! How about another MCF Garage session next Thur or Fri??Violet should be discharged by then...hopefully. The problem isn't yr Violet whether being discharged, mainly concern is whether U can finished the 'Laundry' on that day. Link to post Share on other sites More sharing options...
RadX Moderator July 6, 2002 Share July 6, 2002 Of course!!! How about another MCF Garage session next Thur or Fri?? Violet should be discharged by then...hopefully. The problem isn't yr Violet whether being discharged, mainly concern is whether U can finished the 'Laundry' on that day. I am sure you meant 'lingerie' rt??? Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie July 6, 2002 Share July 6, 2002 Wah, suddenly appeared! Hmmm, the different between 'laundry' & 'lingerie' is whether need to be wash by U. Link to post Share on other sites More sharing options...
Davey Neutral Newbie July 6, 2002 Share July 6, 2002 Brudder! VRG has been discharged for over a week now. Everything seems back to normal. Slight creaking near the door panels due to some rubbing, should be easy to fix. The OZs were on the car when I collected. Definitely better than my previous set of cheap Taiwans ... heh heh Wire mesh?? Hey, I already got them from Jalan Besar. Bought 2 foot run for $20 bucks. Cut and installed, but shiny aluminium looks weird on a silver car, so took them out and they are going to be sprayed either gun-metal or hyper-black if I can find the paints. No prob meeting up. Couldn't make it last night due to last minute family commitments. Also installed some ICE since the last time we met. Basic stuff. Need to checkout your setup to see how things can be improved! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 6, 2002 Share July 6, 2002 Brudder! VRG has been discharged for over a week now. Everything seems back to normal. Slight creaking near the door panels due to some rubbing, should be easy to fix. The OZs were on the car when I collected. Definitely better than my previous set of cheap Taiwans ... heh heh Wire mesh?? Hey, I already got them from Jalan Besar. Bought 2 foot run for $20 bucks. Cut and installed, but shiny aluminium looks weird on a silver car, so took them out and they are going to be sprayed either gun-metal or hyper-black if I can find the paints. No prob meeting up. Couldn't make it last night due to last minute family commitments. Also installed some ICE since the last time we met. Basic stuff. Need to checkout your setup to see how things can be improved! Bro, It may be a bit difficult to spray on the alu mesh becos the paint won't stick! Actually you need to powder coat aluminium to make it last! ↡ Advertisement Link to post Share on other sites More sharing options...
Is a subwoofer necessary?
Factory 6 channel amplifier to 4 channel input DSP
Can play digital music on my old Rotel amplifier
Sony XM-502X (Made in Japan)
DIY ICE strikes back
Need help with Car Audio Configuration!
Where to repair car amplifier?
Is Amplifier Necessary
