Spark plug + wire pushed up
Presea
Hi All,
I heard a slight rattling sound from my engine, so I checked it out.
I found that my right most sparkplug wire was slightly higher than the rest, and as such, it was loose and vibrating in it's hole. I tried pushing it down, but it would not return to it's normal position.tongue.gif
My engine runs fine, and there's no unusual behaviours other than the rattle of the cable.
Put out the spark plug cable and see if you have a loose spark plug [jawdrop]
Never heard of that one though.
If really true, find the SOB that changed the plug for you.
the chap who's changing yr sparks didn't pull the cable out the correct way.
check also if yr sparks are 'screwed' all the way in.
hv u tried pushing the cable thru the cable boot/cap ?
Edited by Ace_t
the cable was installed correctly the last time the spark plugs were changed (about 2 months back).
unfortunately, I don't have the right tools to check the sparkplugs... or to tighten them.
I was wondering,...if the sparkplugs were not installed correctly, wouldn't my engine be misbehaving? Or would it still rev smoothly to 7000rpm without any symptoms?
That was my first thoughts.... but the engine is fine... and the spark plugs were changed by a trained mechanic... ... I think... I assume the staff at Autobacs are quite competent. tongue.gif
I think I better bring my car to a mechanic soon... just in case it's something more serious.frown.gif
there will be a lost in power & also engine will not be as smooth as before as that particular plugs will not be firing, that means you are running on only 3 cyclinder nod.gifnod.gifnod.gif
I got the tools.. heavy duty one.
call me anytime.
it could be your cable catch is loose ? but is the sound so loud that u can hear it rattling ?
furthermore, plastic cables dun produce a loud sound.
Hi All,
I just visited my mechanic who showed me that the spark plugs were not installed correctly. He was able to twist in several full turns.dizzy.gif
The really odd thing is that I have been driving since mid July since the spark plug installation, and there was absolutely no loss of power.
Even when drove up to Malacca in early August, I did 190 for almost 1 hour... and everyday, taking off from standstill, wheelspin is still possible (ST115 205 widthsly.gif)
Now I have more faith in my engine's reliability, despite being 12 years old.... and with an improperly installed spark plug.laugh.gif
I will also go and buy a spark plug tool so that I can check after the new plugs are installed.nod.gif
This is actually the 3rd time I've done my servicing at Autobacs....
Wish I saw this before I went to my mechanic....
And yes, the plastic was rattling in the hole of the engine cover (where it was inserted).frown.gif
It was very audible when the car was stationary and the radio and aircon were switched off.shakehead.gif
Edited by Presea
so, it's not properly screwed in but the plug cable is still connected onto the plug itself, right confused.gif
the spark plug tools only costs about $8.50 at hardware shop in Sungei Rd sly.gif there are 2 sizes, Hex 16mm & 21mm, make sure you get the correct one wink.gif
yup.... when the engine was idling, the cable was pulsating at 2 times per second sly.gif....everytime the sparkplug was firing... hence the rattlingfrown.gif
So which size should I get?... jap cars use only one of the 2 sizes of spark plugs, right?unsure.gif
