Ravinged 5th Gear November 2, 2003 Share November 2, 2003 I have a loose hand brake problem ... sometimes can't engage the hand brake, it will drop back down. What to do? How much to change to a new one? Thanks, Ed ↡ Advertisement Link to post Share on other sites More sharing options...
Huggable Clutched November 2, 2003 Share November 2, 2003 Do you mean you have to pull the handbrake higher in order to park? If that's so you can get a mechanic to "tighten" the handbrake. If it doesn't work at all, the cable might be broken, get it fixed immediately! Link to post Share on other sites More sharing options...
Mmythos Neutral Newbie November 2, 2003 Share November 2, 2003 is it the catch problem? when u pull the handbrake is there any resistance or it's free pull? Link to post Share on other sites More sharing options...
Ravinged 5th Gear November 2, 2003 Author Share November 2, 2003 It's not exactly free pull ... can still feel the tension there when I pull my hand brake but it just doesn't lock in that position. I suspect it could be the nut that has become loosen. If it is just loosen, I may just have to screw it back ... what do you think? If the screw threads are fading, for safety reasons I rather change the whole hand brake system than to take the risk. Any good workshop? Ed Link to post Share on other sites More sharing options...
Ravinged 5th Gear November 2, 2003 Author Share November 2, 2003 Huggable, it is still the same when i pull it higher, it just doesn't lock. Ed Link to post Share on other sites More sharing options...
Huggable Clutched November 2, 2003 Share November 2, 2003 Ed, looks like the locking gear is not working. Get a mechanic to check it. Link to post Share on other sites More sharing options...
Ravinged 5th Gear November 2, 2003 Author Share November 2, 2003 Alright ... noted. Ed Link to post Share on other sites More sharing options...
Adawang 1st Gear November 4, 2003 Share November 4, 2003 ratchet problem Link to post Share on other sites More sharing options...
Eliew Neutral Newbie October 5, 2007 Share October 5, 2007 Steal this old thread ...after servicing recently, cannot pull handbrake up >15% when it was about 45% previously (not loose). Mechanic said they have adjusted to the 1st click. Is that ok? Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged October 5, 2007 Share October 5, 2007 yap i think its true. my mechanic serviced my brake last month, after that handbrake lower and tighter. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged October 5, 2007 Share October 5, 2007 2-3 clicks will be better i guess. 1 click if you have a lady driving your vehicle then may have problem engaging or disengaging the handbrake.. as some strength is needed Link to post Share on other sites More sharing options...
Rickster 5th Gear October 5, 2007 Share October 5, 2007 I think thats quite alright. My car's handbrake can previously pull up to 4 notches. After adjustment, can only pull 2 notch. Been using it for a few months liao. So far so good. Link to post Share on other sites More sharing options...
Rickster 5th Gear October 5, 2007 Share October 5, 2007 Good for handbrake turns Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged October 5, 2007 Share October 5, 2007 i sideswipe you, also can turn... wanna try? Link to post Share on other sites More sharing options...
Eliew Neutral Newbie October 5, 2007 Share October 5, 2007 Ya, not used to 1 notch, a bit too low .. used to be at least 3-4 and pull up without pressing the button. Now have to push the button then come up a little. So long as the handbrake icon light up should be ok? Link to post Share on other sites More sharing options...
Adawang 1st Gear October 5, 2007 Share October 5, 2007 Steal this old thread ...after servicing recently, cannot pull handbrake up >15% when it was about 45% previously (not loose). Mechanic said they have adjusted to the 1st click. Is that ok? thats is perfect Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 9, 2007 Share October 9, 2007 [reply] Ya, not used to 1 notch, a bit too low .. used to be at least 3-4 and pull up without pressing the button. Now have to push the button then come up a little. So long as the handbrake icon light up should be ok? Better trust the feel of tightness when you pull the handbrake lever, than trust the handbrake light on your panel.... My handbrake light had been lighted up everytime I turn on ignition key and thru out the journey, for the past 2 years or so due to micro-switch near the handbrake lever faulty.... Didn't bother to fix it cos still driveable. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Dad was sweet talked into signing an agreement form to sell his car on the spot
Brake squeak every morning
