Beanoyip Turbocharged November 9, 2003 Share November 9, 2003 I got this problem recently. Usually its after a long drive. Whenever i try to start the car, it gets started then revs will drop very low. And the engine just died like that. I wonder whats the problem to this. I haven't changed my spark plugs for about 40k already. Could it be the problem? ↡ Advertisement Link to post Share on other sites More sharing options...
Virus 2nd Gear November 11, 2003 Share November 11, 2003 Could it be the fuel line/pump choke ?? Link to post Share on other sites More sharing options...
Beanoyip Turbocharged November 11, 2003 Author Share November 11, 2003 So how to rectify it if thats the case. Link to post Share on other sites More sharing options...
Sky8807 1st Gear November 11, 2003 Share November 11, 2003 Maybe servicing is due. Or one of the sensor is not working properly. Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie November 11, 2003 Share November 11, 2003 I have a problem for engine died before it ignite totally and engine died when acc during very slow rolling. Fuel filter change already, next check is fuel pump or vacuum hose. no idea what cause it. same prob as yours? Link to post Share on other sites More sharing options...
Beanoyip Turbocharged November 12, 2003 Author Share November 12, 2003 Think is different problem. Mine is crank once, then died. Btw, u got any lobang for iridium spark plugs? i need to change mine soon. Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie November 12, 2003 Share November 12, 2003 Me dun have lobang for plugs. maybe Pete (C708) got lobang. you can check with him. Link to post Share on other sites More sharing options...
Perry Neutral Newbie November 12, 2003 Share November 12, 2003 i dunno if u all having the same problem as me last time. our engine used to behave abit wierdly (almost half yr back), sometimes accelerate fast, sometimes will die after starting in the beginning of the day. brought to servo a few times, finally philip helped us solved the problem. turns out the temperature sensor was faulty. he says the temperature sensor plays a part in controlling how much fuel is sent to the engine (or something like that), so the problem only occurs if the car starts at beginning of day (when it is still too cold), or after long journey (when it is too hot), then it cannot function properly. hence the weird behavior. think only $70 to change the sensor, abt 30 minutes can liao. u might wanna try this first:) philip mentioned that temperature sensor is another quite common problem amongst vw cars? Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie November 12, 2003 Share November 12, 2003 sound just like my problem!!!! okay will do that first. at least save on the fuel pump!!! But I like a bigger fuel pump leh... :P Maybe will get my friend to send it down for me. BTW, which temp sensor? i.e. temp sensor for which purpose? Link to post Share on other sites More sharing options...
Perry Neutral Newbie November 12, 2003 Share November 12, 2003 er, got so many temp sensor in car ar? i also dunno, according to servo, its the one controlling/directing the amount of fuel into the engine? its located very near the engine portion. saw the mechanics just remove the cover and then take out the old one and put in the new one. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
I'll Never Say Goodbye - Dolly Parton
Another doctor in trouble
To be Happy, start thinking about Death!
