Esky Neutral Newbie January 13, 2005 Share January 13, 2005 Found an interesting pic. Ever wondered how the Brisk ZC/ZS electrodeless spark plug with 3 sparks per firing work? ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 13, 2005 Share January 13, 2005 this is interesting, you got any link for that Link to post Share on other sites More sharing options...
Kafer2 Neutral Newbie January 13, 2005 Share January 13, 2005 http://www.silverbulletrx7.com/plugs/ Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 13, 2005 Share January 13, 2005 hey thanks CW, OBTW did you install those short silver antenna, like billim's, on your ride??? Link to post Share on other sites More sharing options...
Kafer2 Neutral Newbie January 13, 2005 Share January 13, 2005 (edited) Nope. Didn't install. Afraid reception will be affected ley. http://www.brisk.cz/en/pro1c.php Edited January 13, 2005 by Kafer2 Link to post Share on other sites More sharing options...
Esky Neutral Newbie January 13, 2005 Share January 13, 2005 Got it from this Jap site, it's not the actual Brisk plug but almost the same. Rebadged OEM Brisk, maybe? www.toa-corp.co.jp/eg/engindexwithm.htm Link to post Share on other sites More sharing options...
Genie47 1st Gear January 13, 2005 Share January 13, 2005 Brisk spark plugs are on limited availability from www.sparkplugs.co.uk . Link to post Share on other sites More sharing options...
Genie47 1st Gear January 13, 2005 Share January 13, 2005 This guy did a lot of research. Link to post Share on other sites More sharing options...
Esky Neutral Newbie January 13, 2005 Share January 13, 2005 911 Zentrum of KL carries them. www.911zentrum.com.my Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie January 14, 2005 Share January 14, 2005 Talking about spark plugs... Have you run iridiums on your ride before? I tried swapping in a set of motocraft coppers after my iridiums were eroded to a needle tip. Guess wat? The engine misfired... swapped the old iridiums back in and everything was ok Link to post Share on other sites More sharing options...
Kafer2 Neutral Newbie January 14, 2005 Share January 14, 2005 Nope. I'm running champion eon4 on my car. Supposedly high-tech stuff but while i dun feel any power increase, it's certainly pretty durable & consistent. The denso seems to erode quite significantly leh. Maybe u wanna check the gap on them motorcrafts - suppose to be 1.3mm but actually should be 1mm. Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 15, 2005 Share January 15, 2005 Nope. Didn't install. Afraid reception will be affected ley. http://www.brisk.cz/en/pro1c.php Oh, I thought you did, was thinking of swapping my stock one with yours Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 15, 2005 Share January 15, 2005 Got it from this Jap site, it's not the actual Brisk plug but almost the same. Rebadged OEM Brisk, maybe? http://www.toa-corp.co.jp/eg/engindexwithm.htm have you try it on your ride ??? Link to post Share on other sites More sharing options...
Esky Neutral Newbie January 17, 2005 Share January 17, 2005 No lah, a bit pricey and only available from KL at the moment. Used to be RM25/piece but now RM28/piece due to the Euro's appreciation. And need to pay more than RM10 for courier charges to have them mailed to me. It's kinda pricey if you consider that it's not those platinum plugs which u can use for 60k to 100k km, but normal plugs that last only about 20k-30k km. But from the feedbacks, there's noticeable change in performance, so... it's value for money performance-wise. Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 17, 2005 Share January 17, 2005 I'll speak to my supplier (friend) to see if he is interested in bringing them in to sell Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie January 17, 2005 Share January 17, 2005 How much and where to get? Link to post Share on other sites More sharing options...
Clio Neutral Newbie January 22, 2005 Share January 22, 2005 to me...all the plugs are the same...u cant feel the difference. but a good denso iridium can last around 100k. now selling around $60+ for a set. quite worthy. try those distributors at alexandra village. they selling quite cheap. Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 23, 2005 Share January 23, 2005 only the Denso Iridium Tough can last 100k km, the normal Denso Iridium "IK" series can only last around 30k km ↡ Advertisement Link to post Share on other sites More sharing options...
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Changing of Spark Plugs
Good ENT specialist to recommend ?
Any good private driving instructor to recommend?
Petrol Discounts in Singapore
Where to get Workshop Manual
