Revo513 Neutral Newbie February 19, 2004 Share February 19, 2004 As above.. are the differences really significant in terms of - fuel consumption - noise - pick up speed - comfort asking this question cos scared might have a rough ride with the sports mazda 3 that comes with 17" rims. personally havent drove a car with 17" rims before ↡ Advertisement Link to post Share on other sites More sharing options...
Mk1gti Neutral Newbie February 19, 2004 Share February 19, 2004 - fuel consumption (goes UP) - noise (level goes UP) - pick up speed (SLOWER) - comfort (level goes down by a bit) Link to post Share on other sites More sharing options...
Revo513 Neutral Newbie February 19, 2004 Author Share February 19, 2004 yar i know ...but what i really want to know is.. is it SIGNIFICANT? that means will the driver feel the difference easily? or dun really feel any difference at all? hmm Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 19, 2004 Share February 19, 2004 if this is the first time you are driving this new car, how to feel the diff with nothing to compare? unless you are driving it now on a 15' then decide to go 17' then you will feel it what..... Link to post Share on other sites More sharing options...
Skywalker Neutral Newbie February 19, 2004 Share February 19, 2004 There are always difference as I had experienced changing from 15" to 17". 1. Fuel Consumption - slightly more, around 10-20km less per tank due to more surface contact & resistant between tyres & road surface thus need more power to move the car. 2. Noise - noisier due to thinner wall (less rubber), less absorption. Whether or not you use the most quiet tyre available it does not help a lot, other than wearing ear plug 3. Pickup speed - refer to point 1. 4. Comfort - refer to point 2. But the good points are better appearance of your car and better handling & stability. Link to post Share on other sites More sharing options...
Skywalker Neutral Newbie February 19, 2004 Share February 19, 2004 The best way to compare is to test drive a car with 15" and one with 17" to feel the different at least on noise, pickup & comfort. Fuel consumption have to complete a full tank to compare. Link to post Share on other sites More sharing options...
Revo513 Neutral Newbie February 19, 2004 Author Share February 19, 2004 yah la.. the car haven arrive yet so as u said nothing to compare lor, but just wanna ask the experts here mah.. hehe Link to post Share on other sites More sharing options...
Virus 2nd Gear February 19, 2004 Share February 19, 2004 [reply] yar i know ...but what i really want to know is.. is it SIGNIFICANT? that means will the driver feel the difference easily? or dun really feel any difference at all? Personally upgrade 15" to 17". Feel different in slower pickp, but cornering more stable (less body-roll). As for FC, in fact mine was improved. (maybe my 17" is lighter than previous 15" ) As for noise, it will depend on the tire used, not the rim size. For comfort, slighty harder ride (very very little). Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 19, 2004 Share February 19, 2004 difference certainly have lah. but significant or not it all depends mah......if i drive a very powerful car from 15 to 17 i may say not significant mah....anyway, since yours is 17 stock, you can be sure you dunno the diff since never drive on a 15 before...comparing car to car. btw, make sure they set you speedo right, dun afterwards your speedo show salah speed Link to post Share on other sites More sharing options...
Mk1gti Neutral Newbie February 19, 2004 Share February 19, 2004 All said and done, would highly recommend 17s on the M3 together with the bodykit. Chio bu!!! FC goes up and comfort level decrease but they are only a small increase or decrease. It depends on individual preferance though. But high speed stability , cornering and attraction factor . Link to post Share on other sites More sharing options...
Soya Supersonic February 19, 2004 Share February 19, 2004 how significant is actually quite subjective as we all hv different level of tolerance. but based on my own experience, did a +2 rim upgrade on a 1.6 b4 and would say the diff is certainly noticible. more drag, noise, comfort take a backseat (ride more jiggly), and FC goes up abt 5-10%. but on the plus side, handling is sharper, steering feedback is better and looks . if the plus points is wat u r looking for, you've hv no regrets. otherwise, save the money and stick to 15". Link to post Share on other sites More sharing options...
Revo513 Neutral Newbie February 19, 2004 Author Share February 19, 2004 hmm .. thicker tyres will have a more comfortable ride? Link to post Share on other sites More sharing options...
Revo513 Neutral Newbie February 19, 2004 Author Share February 19, 2004 hmm..anyway to check if the speedo is set correctly with respect to rim size? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 19, 2004 Share February 19, 2004 tell your SE to set it. Link to post Share on other sites More sharing options...
Mk1gti Neutral Newbie February 19, 2004 Share February 19, 2004 (edited) Thicker tyres in terms of side profile or thread width?? Thicker side profile, Yes. Thicker thread width, No. But a thicker side profile on 17s is not recommended when it is bigger than the stated recommended profile. 195/65/15 can upgrade to 225/45/17. Going any bigger than 45 on 17s will upset your speedo reading. Edited February 19, 2004 by Mk1gti Link to post Share on other sites More sharing options...
Eddieang Neutral Newbie February 19, 2004 Share February 19, 2004 yes, having a bigger wheel would means you travel longer distance per RPM, may be looking and lead to wrong calculation on FC & speed. Better to recalibrate the meter after the change, otherwise kanna caught by speed camera also don't know why. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 19, 2004 Share February 19, 2004 tell him lah....i already very happy with my stock 16 lah Link to post Share on other sites More sharing options...
Revo513 Neutral Newbie February 19, 2004 Author Share February 19, 2004 Actually, test drove the MZ3 basic sedan (15") and the MZ3 luxury sedan(16") and found that not much difference at all. In fact, i felt that the 15" gave me a harder ride than the 16".. perhaps the roads in Ubi are more unfrenly than Henderson roads . Hope that the sports (17") won't give me too much headache.. ↡ Advertisement Link to post Share on other sites More sharing options...
Disputes between neighbours - A True story
Income tax Evasion
Income tax Evasion
Does rims change shape/warp over time?
Replacing a 2yrs old tyre?
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
