Kytl68 Neutral Newbie June 16, 2004 Share June 16, 2004 I notice that after every 2-3 weeks when I go to the petrol station to check my tyre pressure, there is a drop of about 10-15 Kpa on all tyres. Normally, I check the pressure in the morning (almost same time always). Everytime, the tyre start to inflate from around 230 to the set pressure of 245. Is this normal or there is something wrong with the tyre and rim ? FYI, my previous car did not have this problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Cheekg99 Neutral Newbie June 17, 2004 Share June 17, 2004 you very hardworking ... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 17, 2004 Share June 17, 2004 It is normal... Link to post Share on other sites More sharing options...
RadX Moderator June 17, 2004 Share June 17, 2004 It is very normal. Your should do a bi-weekly check on your tyre pressures, preferably in the morning to ensure that your tyres are optimally inflated. This reduces wear and tear, grip, fuel consumption, etc. Link to post Share on other sites More sharing options...
Parkwalker Clutched June 17, 2004 Share June 17, 2004 How do we then inflate the tyres in the correct pressure? becos going to the petrol station would take some distance and by then, the tyres might have been warm (which have higher pressure inside)... anyone can advise? Link to post Share on other sites More sharing options...
Soya Supersonic June 17, 2004 Share June 17, 2004 pump 1 or 2 psi higher lor. Link to post Share on other sites More sharing options...
RadX Moderator June 17, 2004 Share June 17, 2004 That is why I mentioned, you reduce the odds by pumping EARLY in the morning... Anyway any slight increase in temp is not that significant unless you have travelled a few kms For my practice, every other week, I would make, on my way to work, arnd 6am, a trip to the Petrol kiosk, and do the necessary. Link to post Share on other sites More sharing options...
Soya Supersonic June 17, 2004 Share June 17, 2004 allo, u tink everybody wake up at 5am-type like u ah?? Link to post Share on other sites More sharing options...
RadX Moderator June 17, 2004 Share June 17, 2004 allo...i mentioning MY style can anot.... Nevertheless, think morning, as long as not before 12pm shud be ok la....anyway tyres still not warmed up... Link to post Share on other sites More sharing options...
Parkwalker Clutched June 17, 2004 Share June 17, 2004 or 1/2 kpa higher would do? Link to post Share on other sites More sharing options...
RadX Moderator June 17, 2004 Share June 17, 2004 Yeah...IF your optimal pressure is 230, pump to 235 lor...that shud do! Link to post Share on other sites More sharing options...
RadX Moderator June 17, 2004 Share June 17, 2004 Think hor your tyre pressure once out of MSCP reach optimal already and smoking like hell..thus, you need your own personal tyre pump.. Link to post Share on other sites More sharing options...
Soya Supersonic June 17, 2004 Share June 17, 2004 oi, i bloody wowo driver ok? dem slow one. Link to post Share on other sites More sharing options...
RadX Moderator June 17, 2004 Share June 17, 2004 ".... ok? dem slow one. ,....." SLOW is relative my friend... Link to post Share on other sites More sharing options...
Soya Supersonic June 17, 2004 Share June 17, 2004 why u call my relative slow.....?? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 17, 2004 Share June 17, 2004 How do we then inflate the tyres in the correct pressure? becos going to the petrol station would take some distance and by then, the tyres might have been warm (which have higher pressure inside)... anyone can advise? before going home, pump 4 to 5 psi more than usual, then inthe morning before moving off, using a tyre pressure gauge to measure and bleed until the right pressure... Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 17, 2004 Share June 17, 2004 How do we then inflate the tyres in the correct pressure? becos going to the petrol station would take some distance and by then, the tyres might have been warm (which have higher pressure inside)... anyone can advise? buy a portable car-batt operated pump & a tire gauge, then pump/check pressure during the morning lor! just like me Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 17, 2004 Share June 17, 2004 wah ... more hardworking then me leh ... for me I don't even check ... But your tyre pressures is interesting ... my father told me my tyre pressure was 220 but yours is much more ... don't suppose you drive a STI ? ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
