Queries - Octavia
Moeykf
Hahaa... tempted to try the 100w halogen though ..cheaper on the wallet as well as not so hot tongue.gif
yap, much cheaper but I did used it on my old Alfa 33, the headlight was able to take the heat but the internal silver reflector seems to have deformed & loose the shinning coating sweatdrop.gifsweatdrop.gifsweatdrop.gif
mine was quite sometime back, should be around '95, back then is was a little 'greenish/rainbow' in colour running on 95W sweatdrop.gifsweatdrop.gifsweatdrop.gif I think I paid around $40++, after seeing the effect on the reflector, didn't dare to use it on the Civic sweatdrop.gifsweatdrop.gifsweatdrop.gif
Hahaa... tempted to try the 100w halogen though ..cheaper on the wallet as well as not so hot [:p]
Buld with wattage higher then your car's, will harden the hardness and melt it eventually (maybe a year or more). Anyway, unless HID lamp come factory-fitted, otherwise it is not so worth the $$$. The upgrade is ex and the buld replacement is also very ex. My previous headlamp was HID and the replacment bulb is slightly over $200 each. Tho it last longer, but when it's time to replace it, your wallet will suffer. I worked out the cost between HID (last longer but ex) and halogen (shorter lifespan, but cheap), it is still more worth it to replace halogen yearly,than to replace HID bulb once every 2 years.
