Tarzan666 2nd Gear February 13, 2007 Share February 13, 2007 hmmm thanks..i tink i go back ther again..eye sore 2 drive at nite.. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 i wonder how long can the bulbs last? =============================== My VP already >2 years & still going strong. Only problem is they r getting dimmer as they age. If installed properly, they sud last. Much better then those flashy bulbs sold. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 VP is yellowish like original bulbs. Mine were about 1.5 times brighter when new but the good part is their spread is more even unlike the OEM bulbs which have certain areas brighter & some areas not lighted up. U can just get the H4 bulbs which combine the high & low beams in 1 bulb. After installing, u might need to do the adjustment to get the beam of light to shine on the road & not in on-coming drivers' eyes. I DIY the adjustment on a dark straight road. After adjusting, on the low beam & stand about 50 to 100 meters in front of your car & check if they blind u. If so, the adjustment sud b lower. After that on the high beam & see if it lights up the road as far as the beam can reach. Aftermarket antenna (eg: internal type) usually doesn't have as good reception as the original external antenna. I tried Bosch internal b4, where it is stuck to the inside of the windscreen with 2 thin wires running along the top of the windscreen & the reception loses out to the original external type. Link to post Share on other sites More sharing options...
Wrc206 Neutral Newbie February 13, 2007 Share February 13, 2007 Think maybe due to installation fault as what Adianli said. Try going back to shop to ask them again. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 My Bosch windscreen antenna wire he wana charge me S$50!!! I tell him go fly kite. Went to another shop at Alexandra for S$30 only. =========================== Last time when my Bosch antenna wire broke, I DIY a replacement by just 1 simple solder. Can use a longer wire to join to the old external antenna for better reception. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 tryin 2 revive old thread...yday got vision plus H1 4 my sunny in mcwell..fixed during the day..2nite wen i 1 2 test the lite... the lite seems funni 2 me..it shoots further than stock..but lite like more focus on rite side..left side bit dim & got 2 thin rays of light frm left bulb shootin 45deg 2 the left.. the 2 thin rays veri obvious...veri distractin.. is it sometin wrong with the bulb or need 2 run in bulbs? ======================== Have the headlight alignment checked. Mine is very nice & even spread in front of the car. Better then the OEM bulbs. Bulbs don't need to "run-in". They sud be best from the start. As it gets older, it wil start to dim. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 hmmm thanks..i tink i go back ther again..eye sore 2 drive at nite.. ========================= If they can't even install your bulbs properly, I wud rather not go back & prefer to DIY. They cannot touch the bulb glass at all cos it wil cause the bulb to blow very quickly. I think the guy who install for you got no experience at all. Did he wear a pair of clean white cotton gloves when he install the bulbs? Mine did. > then 2 years & the bulbs still working. Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear February 13, 2007 Share February 13, 2007 (edited) ok thanks..scared 2 align myself..wait kena electrocuted or worse casing crack.... u knoe hw 2 do? He used his bare hands 2 install 4 me... Edited February 13, 2007 by Tarzan666 Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 (edited) It's not difficult but just check how much space there is to move your hands in the space behind the headlamp housing. My hands quite big so it might b a squeeze. It sud b shown in your handbook how to change. Basically just remove the rubber cover then the wire connector (plug) then the spring retaining clip & take out the bulb. Never touch the glass part of the bulb. Only hold from the rear metal part where the 3 terminals r. The alignment is a bit more difficult. Must find location & do at night for best results. Most have 2 screws on each housing to adjust up/down & left/right. Not all use the same method but u got to see what type u have first. Also have to use a cloth to cover 1 headlight while adjusting the other. Dont worry about electric shock cos it's only 12 volts. Edited February 13, 2007 by Pisces69 Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear February 13, 2007 Share February 13, 2007 haiz 2 tink i pay $5 incl GST 4 such workmanship..sian.. let me try..if cannot go back shop bang table aredy..but then hard 2 show them the fault..coz 7pm close & thers still daylight Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 (edited) Try parking about 2 meter from a wall & shine your headlight on the wall. There is a way to adjust using this method but I don't have the calculations to do it this way. This is the professional way to adjust the headlights. Edited February 13, 2007 by Pisces69 Link to post Share on other sites More sharing options...
Adrianli Hypersonic February 13, 2007 Share February 13, 2007 U buy from them n still have to pay installation fee??? Mine, they install for me free one leh. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 Ya lor. Mine also install free. I bought at Toh Guan. Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear February 13, 2007 Share February 13, 2007 yah lah..such simple ting they charge me $5.. haiz.. nvrmind..i'll go back again 2 ask them align 4 me....make them earn their $5.. Link to post Share on other sites More sharing options...
Clubace Clutched February 13, 2007 Share February 13, 2007 Tye soon at toh guan center? Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 13, 2007 Share February 13, 2007 No not Tye Soon. The other place. Around the 4 or 5th level. Got the lobang from a bro in TCS. Best price at that time & they did a good job installing. I watched him & was very satisfied. Link to post Share on other sites More sharing options...
Picanto 3rd Gear February 18, 2007 Share February 18, 2007 Does H4 bulbs needs adjusting after installation? or is it only H1 bulbs need adjusting? Link to post Share on other sites More sharing options...
Subutai 3rd Gear March 29, 2007 Share March 29, 2007 Vision Car A/C Auto Accessories. 106 Rangoon Road. Singapore 218388 Tel: 6297 0756 Fax: 6296 9178. ↡ Advertisement Link to post Share on other sites More sharing options...
Aion Y Plus
Aion Y Plus
Getting a foreign wife
Apple Vision Pro
Apple Vision Pro
Fuel Plus Meet Up
Fuel Plus Meet Up
COVID-19: Retrenchments
Woman lashes out at tutor who asks for payment.
