Seth Neutral Newbie October 10, 2004 Share October 10, 2004 Any recommendations to change the extractor? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Tanzy Clutched October 10, 2004 Share October 10, 2004 What car? You can buy aftermarket tuner parts or custom make one. I'll prefer to go with the former option then approach one of the good exhaust shops to fit it for you. Link to post Share on other sites More sharing options...
Darkness Neutral Newbie October 10, 2004 Share October 10, 2004 extractor i was told is illegal right? so wat is the penalty for getting caught with an extractor and wat is the change of getting caught....also will SS extractor make the car very loud? will termal wrapping it help? thanks cheers Darkness Link to post Share on other sites More sharing options...
Normal_aspirated Clutched October 10, 2004 Share October 10, 2004 Extractor doesn't make exhaust sound louder, it's the mufflers...... Link to post Share on other sites More sharing options...
Darkness Neutral Newbie October 10, 2004 Share October 10, 2004 icic thanks dude...so wats the penalty huh? will it cause any insurance issues? Link to post Share on other sites More sharing options...
Tanzy Clutched October 10, 2004 Share October 10, 2004 Of course it is illegal but the chances of getting caught is almost nil. The inspector of the car can't recognise specific extractors for different cars. Extractors on their own won't make the car louder but it usually has to be matched to a straight through muffler for maximum performance, so ultimately, the exhaust note of your car will be louder. If you are going to ever run into problems, it will be with the muffler. The best way to do it is to fit a legal aftermarket exhaust, get the certificate, then go back to the shop to fit the extractors and de-cat. Thermal wrapping doesn't decrease sound. It is to prevent the engine bay from being heated up and to keep the exhaust gas temperature high for higher exit velocity. Link to post Share on other sites More sharing options...
Darkness Neutral Newbie October 10, 2004 Share October 10, 2004 thanks man u sound damn pro at this so for auto car if i change extractor alone no use la? hummm...how much does a extractor cost huh? also i was told by FK that they can custom make for me a extractor...is this safe/durable? or better to stick to those originally meant for the car. those original ones seem ex lei i was told can be 1k thanks bro me so many question Link to post Share on other sites More sharing options...
Epsilon 2nd Gear October 10, 2004 Share October 10, 2004 what is your ride? Link to post Share on other sites More sharing options...
Darkness Neutral Newbie October 10, 2004 Share October 10, 2004 megane phase 2 (not megane II hor) Link to post Share on other sites More sharing options...
Tanzy Clutched October 10, 2004 Share October 10, 2004 (edited) Not pro but did a little research into this. I don't know how much the extractor will cost for your car but what Ricky does for you will never be as good as those produced by specialised tuners who did their calculations and testing for the specific model and engine. Extractor alone might even result in overall power loss. It's always done in conjunction with a free flow cat-back. Why do you need an extractor? It will only shift your power band and torque curve so you get maybe 10 hp at high RPM at the expense of low end torque. Unless you track the car where you always drive it at the red line, I see little performance gain on the road. In fact, it might feel as though your car has lost some power. Edited October 10, 2004 by Tanzy Link to post Share on other sites More sharing options...
Darkness Neutral Newbie October 10, 2004 Share October 10, 2004 oh actually i was looking at improving my low end and both ricky and my other mech told me it is good to change extractor for low end....hummm... all confused now..... wat u suggest i do bro...i wan low end heehee thanks Link to post Share on other sites More sharing options...
Epsilon 2nd Gear October 10, 2004 Share October 10, 2004 i thought that 4-2-1 will improve the low end ..... Link to post Share on other sites More sharing options...
Tanzy Clutched October 10, 2004 Share October 10, 2004 Oh that's interesting. Usually people change to racing extractors which are longer than the normal ones for high end power. I suppose it might be possible to do ones that are shorter than normal. Link to post Share on other sites More sharing options...
Seth Neutral Newbie October 12, 2004 Author Share October 12, 2004 My car is Nissan SS 1.6(A) Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie October 12, 2004 Share October 12, 2004 wad is an extractor and how does it affect the ride? Link to post Share on other sites More sharing options...
Vtim 3rd Gear October 13, 2004 Share October 13, 2004 if your ride is Auto, you can forget about the extractor Link to post Share on other sites More sharing options...
Normal_aspirated Clutched October 13, 2004 Share October 13, 2004 (edited) Yalor, if u want more power, buy a manual one in the first place, lah. Edited October 13, 2004 by Normal_aspirated Link to post Share on other sites More sharing options...
Vtim 3rd Gear October 14, 2004 Share October 14, 2004 Auto still can be done but need to add piggy back ECU to tune the engine ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
ATF oil change
ATF oil change
