Esky Neutral Newbie December 20, 2002 Share December 20, 2002 Hi all, pls tell me what the gas inside the view glass look like when the gas is not leaking? no bubbles at all, or slight bubbles? mine seems to be leaking aircon gas as there's quite a bit of bubbles when the a/c compressor's running... i think the evaporator in the cabin gone liao... . ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 20, 2002 Share December 20, 2002 If you are leaking air con gas, then the air con would not be cold already... the bubble in the window you see is normal.... Get the mechanic to check for leak first by pressuring the system. If no leak, then top up gas and observe for a day or two. Link to post Share on other sites More sharing options...
Esky Neutral Newbie December 20, 2002 Share December 20, 2002 Usually the gas won't leak all immediately, but bit by bit, and you'll notice that the aircon seems to take longer and longer to cool to the same temperature, and the compressor seems to run forever. And from my experience, and what the aircon guys told me, the gas doesn't usually leak so much that it's noticeable unless there's a leak in the system. . Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 20, 2002 Share December 20, 2002 usually, you can tell in abt two days Link to post Share on other sites More sharing options...
Offroader Neutral Newbie December 20, 2002 Share December 20, 2002 Parfum de Pandan ? Wah..dats even more concentrated than Eu De Pandan ! Put in the back..under the seats...in the side pockets.... Gaurantee to turn away, ants, mice,.....might as well become "PANDANOX" Link to post Share on other sites More sharing options...
Neilchua Neutral Newbie December 20, 2002 Share December 20, 2002 How about Pandan Leaves? I saw alot of people especially Taxi drivers put that and i must say it smell quite nice. According to them it drives away cockroaches too I know some taxis put pandan leaves but alas, pandan leaves is good until it turns bad. And when its past its "expiry or useful date", the pandan leaves gives a terrible smell like macham arm pit smell, damn bad... sat in many cabs in my lifetime (work related , dun drive when out for client visits) and this is what I experience. Charcoal better, at least no bad side effects. Link to post Share on other sites More sharing options...
Offroader Neutral Newbie December 20, 2002 Share December 20, 2002 AND.......it will crack and is very brittle....when u try to remove it, all break and then u have to vacume it out....sigh....but, while it is fresh, mummmm.....nice smell....undoubtedly, and natural.... Link to post Share on other sites More sharing options...
Assassin Clutched December 20, 2002 Share December 20, 2002 imagine yourself alway feeling hungry smelling food in your car..... Sure grow FAT... yah...then on top of putting pandan leaves in the car...you'll start stocking tid bits in there too !! Link to post Share on other sites More sharing options...
Guyver 1st Gear December 22, 2002 Share December 22, 2002 What i do is i'll put the pandan leaves in a plastic back and leave an opening on top... so in the way... when the pandan leaves cracks... i'll just empty the plastic bag and put a fresh pandan leaves in again.... Link to post Share on other sites More sharing options...
Smiley Neutral Newbie December 23, 2002 Share December 23, 2002 (edited) fr those who do not like the smell of pandan leaves, try using tea leaves. heard that chinese tea leaves are the best. the tea leaves must be soaked. the good things about tea leaves are (1) do not brittle and (2) do not leaves behind any smell. it basically live its life to the fullest by absorbing all foul smell. the bad thing about tea leaves is it is less lasting than pandan leaves and must be change regularly. great for people who drinks tea frequently. by the way, it works fr fridge as well. Edited December 23, 2002 by Smiley Link to post Share on other sites More sharing options...
Esky Neutral Newbie December 23, 2002 Share December 23, 2002 Maybe can also try those bath salts? They smell good, too! Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear December 23, 2002 Share December 23, 2002 Sigh* My a/c was down on SUnday. Top up the gas and after 2 hours.... no more a/c again.. Just sent in my car... Need to replace the coil and filter. repair is around $220. 9 months to go and a/c give problem... Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 23, 2002 Share December 23, 2002 9 months to go and a/c give problem... Well, you're more lucky than me My 92' Alfa 33 16v, got 13 mths to go & one of the timing belt tensioner's bearing broke Ended up have to overhaul engine with 1 broken & 2 bend valves damaged was about $900 Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear December 23, 2002 Share December 23, 2002 Just receieved call from A/C mechanic, my fan can't make it till Christmas... Plus another $95 Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 23, 2002 Share December 23, 2002 Baking Soda is another great odor absorber Link to post Share on other sites More sharing options...
Esky Neutral Newbie December 24, 2002 Share December 24, 2002 I've heard normal bread is also a great odour absorber! Some more u get to eat it after letting it absorb the smell! No wastage here!! Link to post Share on other sites More sharing options...
Lillight Neutral Newbie December 24, 2002 Share December 24, 2002 Uh, can I ask where is the best place to put all these pandan leaves/teabags/baking soda/bread? Right on the aircon vent? Or actually deeper inside? Or just anywhere in the car? Link to post Share on other sites More sharing options...
Seansene 1st Gear December 24, 2002 Share December 24, 2002 "Baking Skoda"??? Oh, sorreeeeeee... soda.... ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
Question on Transfer of Car Ownership
Question for Car Servicing
COE renewal question
Question of polyclinics
Noob questions on property
PSLE Maths question. How to solve?
