Patcheon Neutral Newbie December 12, 2004 Share December 12, 2004 (edited) Hi all, Got a question about radiator fluid. Used to use BP radiator fluid but now BP no longer exist in Sg, got to switch fluid. Question is do I need to find mechanic to flush out radiator before adding new fluid in or do I just pour new fluid in. BTW, which brand fluid is recommended? Saw some ads on some 'performance' fluid. Are they really better? But also understand that most car stuff with 'performance' label is much more expensive than ordinary products. Using BP cuz station is just opposite home. Thanks. Added comment: Opps, should be posted under maintenance forum. Edited December 12, 2004 by Patcheon ↡ Advertisement Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie December 12, 2004 Share December 12, 2004 flushing out the radiator is not a too hard task to do. look at ur owners manual and they will tell u where to open up to let the fluid flow out. and then top in the new fluid. i think that there are some fluids out in the market which are of betta 'quality'. heard that those fluid are used on cars like bmw and merc ba. think they haf a betta effect. but for namrla jap car. dun think theres a need to use till those fluid. flush out ur old fluid and top in the new one inside. and one more think is i dun think there will be a problem to mix those fluid togethere ba. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 12, 2004 Share December 12, 2004 If your rid is a european make, it is very difficult for a layman to drain and top up the system. Chances is that you will get only 80% of the exisitng coolant out. Without a vacuum and filling spcialty tool you will never be able to fully charge up the coolant system. With partial fill system there will also be air bubbles trapped inside and that will be the casue of overheating later on. Link to post Share on other sites More sharing options...
Patcheon Neutral Newbie December 13, 2004 Author Share December 13, 2004 Thanks for the replies. My ride is a nothing fancy nissan sunny. Therefore draining out the radiator may be easier except I have long misplace my manuals . If mixing fluid is ok, then I may live with it till maybe the next servicing and will ask mech to flush out radiator. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 13, 2004 Share December 13, 2004 Stick to coolant that are mean for Japanese/Asia cars , don't use those for european cars. Frankly there is no need to add coolant,too much of coolant is bad for your cooling system just top up with distill water will be ok. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 13, 2004 Share December 13, 2004 (edited) NO!!! DO NOT MIX COOLANT!!! If you do that its a recepie for big trouble. Only time you do that is when you're toping up with the exact same coolant. Distilled water is fine. Oh btw, the the coolants that euro cars seem to use have a higher heat transfer rate and boiling point which would help in sg. In addition, they last 5 years as opposed to 2 years. You do the math. Too much coolant is bad??? WTF??? First I've heard of that. Thats what the coolant bottle is for. As the engine heats up and the coolant expands, the extra coolant will flow back into the bottle and when it cools down drain back into the radiator. Just make sure that when cold, the level in the bottle is not above the max to prevent coolant from expanding and rupturing the bottle when hot. Edited December 13, 2004 by Elfenstar Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 13, 2004 Share December 13, 2004 (edited) Its the same for any car. Only thing is that in euro makes, the car is meant to be fully serviced by workshops and as such its a pain to get to the coolant plug at the bottom of the car. Charge up??? Whats that??? Try this for more info... http://www.diynetwork.com/diy/en_maintenan...2270919,00.html (sorry dunno who to make a link... just have to cut and paste) Edited December 13, 2004 by Elfenstar Link to post Share on other sites More sharing options...
Phochem Neutral Newbie December 13, 2004 Share December 13, 2004 tink he meant the ratio of 50-50 anti-freeze/water mixture. Not the amount. Too much coolant (more than 65%) will reduce the viscosity of the mixture whic reduces the mixture's ability too carry heat. Running straight antifreeze can raise metal operating temperatures inside an engine which may be enough to cause problems in the exhaust valves. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 14, 2004 Share December 14, 2004 Oh heheh forgot abt that Well checking the instructions would be best or using premixed coolant. As an added note, in sg we dun need anti-freeze in our coolant so i would rec redlines water wetter which one of the sponsors here sells. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie December 14, 2004 Share December 14, 2004 yup, redline coolants are good. Link to post Share on other sites More sharing options...
Genie47 1st Gear December 14, 2004 Share December 14, 2004 I think what he meant is to fully evacuate the whole coolant system and then completely fill it up evacuating bubbles and all. A complete liquid envelopment. That is what he meant by charge up. Link to post Share on other sites More sharing options...
Patcheon Neutral Newbie December 15, 2004 Author Share December 15, 2004 May I know where to get redline coolant? Thanks. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 15, 2004 Share December 15, 2004 Its called water wetter. you just add that to distilled water. try http://www.buddyclub.org They are at Tampines. Link to post Share on other sites More sharing options...
Hattee Neutral Newbie December 15, 2004 Share December 15, 2004 Our green coolant actually raises the boiling point, hence reduces unnecessary water loss. Engine Ice is the concentrated version. It also very effective against corrosion but worst in effective heat transfer. Hence radiator (not engine) actually operates at higher temperature to compensate for better heat transfer. Whereas Water Wetter only reduces coolant-to-metal surface tension. Hence, improves heat transfer and to certain extend inhibits corrosion. Water Wetter plus distilled water still boils at 100 deg but distilled water is weakest in resisting corrosion. Personally, think should use 25-50% green coolant plus 50-75% distilled water plus the right portion of Water Wetter. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 16, 2004 Share December 16, 2004 (edited) Thanx for helping to explain the charging up technique using a vacuum gun PS Similar techique using larger system are used in most car assemble plants to test the system for leak and follow by coolant filling Edited December 16, 2004 by Yeobh Link to post Share on other sites More sharing options...
Genie47 1st Gear December 16, 2004 Share December 16, 2004 Your system is great for the traditional coolant system with the radiator cap. My car is the other type w/o the radiator cap. The expansion tank's cap is the radiator cap. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 16, 2004 Share December 16, 2004 (edited) No problem with header tank, in fact this device is designed initially to take care of european cars - due to aerodynamic design the engine is always sitting with on side much than the radiator. This is the cause of air bubbles getting trap at the highest cooling systme point. Conventional method of air bleeding cannot do very much. That is why many european car owners are always complaining about overheating problems.Our mechs just cannot understand that air bubbles are poor conductor of heat and so recommed the removal of the thermomstate - this leads to more problems as the cpu is not able to sense the temp correctly and therefore cannot activate the exhaust oxygen sensor to close loop circuit. The result is high fuel cosumption and poor acceleartion etc etc. PS attached photo - vacuum gun used on BMW 7 series cooling system Edited December 16, 2004 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
Math Question
Math Question
Radiator slight crack
Question on Transfer of Car Ownership
Question for Car Servicing
Coolant overflowing from expansion tank
Motul Brake Fluids for the street or the race track?
