Pugpug Neutral Newbie November 16, 2007 Share November 16, 2007 Should I get 5W30 or 10W30 for Sunny FL? ↡ Advertisement Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 16, 2007 Share November 16, 2007 Both are 30wt and has very similar viscosity, no diff between the 2 in our weather condition. Link to post Share on other sites More sharing options...
Solar Turbocharged November 16, 2007 Share November 16, 2007 5w or 10w is more applicable to winter conditions. no worries. either will do. Link to post Share on other sites More sharing options...
Tangoh Neutral Newbie December 10, 2007 Share December 10, 2007 Hi everyone, I'm also an Amsoil user. Bought 4 Quarts 6 months back from MCF and had the oil change done. Now about 11k km on this so-called 25k mile (40k km) oil. Was wondering whether any bros out there have actually extended the use of this oil to more than 10k km? Link to post Share on other sites More sharing options...
Garlic 1st Gear December 10, 2007 Share December 10, 2007 Singapore's driving condition is classified as severe and extended OCIs are not recommended unless you are pretty sure the oil is still fine by doing an UOA. The 40K OCI is only applicable if you used Amsoil's oil filter. At the end of the day, Amsoil still recommends sticking with manufacturer's recommended OCI. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged December 11, 2007 Share December 11, 2007 my AMSoil 10w30 i used for 12000km.. never did any UOA though but is definitely still good when i changed it out. i changed it out bec i still left 8bottles left at that time (bought whole carton), and was eager to change out faster so i can finish 10w30 and try the 0w20, now finally on AMSoil 0w20.. but the 10w30 is still better than 0w20 in my type of usage. i always warm up engine for at least 4minutes no matter what rating i use. even for 0w20 i also warm up this long, so i dun really need much cold start protection. while travelling continuous for 30-50km, the 10w30 is smoother (or should i say the 0w20 is too thin, engine seems to rev to much unecessarily). but Fc on 0w20 definitely is better, i changed my tyre from 185/65r14 to 205/45r16 but fc remains the same.. Link to post Share on other sites More sharing options...
Ericang69 Neutral Newbie December 11, 2007 Share December 11, 2007 For our climate, dont really think our engine required any warm up before move out. Idling do more harm to the engine. But then modern car will automatic rev the engine rpm higher during cold start to ensure engine oil being carries to the cylinder. Cheer - my 2 cents. Link to post Share on other sites More sharing options...
Alvinchua1975 Neutral Newbie December 11, 2007 Share December 11, 2007 in fact looking that the vis of these 2 oils, at higher temp, based on the AMSOIL reports, the difference is only negligable... Link to post Share on other sites More sharing options...
Regret4 Neutral Newbie December 17, 2007 Share December 17, 2007 lm driving a 3 yrs old 350z...can l get 5w20? anyone knows of any workshop tat knows how to service this car? Link to post Share on other sites More sharing options...
Ixat 1st Gear December 17, 2007 Share December 17, 2007 Both are 30wt and has very similar viscosity, no diff between the 2 in our weather condition. Noticed that 5W30(ASL) and 10W30(ATM) Does the ASL or ATM make any difference? What does it stand for? Thanks Link to post Share on other sites More sharing options...
Trex101 3rd Gear December 18, 2007 Share December 18, 2007 The "W" are winter rating. What it means is that the 5w will flow faster than the 10w in Winter condition. In our coldest morning maybe 25'c, both 5w & 10w will probably flow around the same rate with 5w abit faster. If all else being equal(doesn't really apply to modern synthetic), a mineral 10w which contain lower % of VII will be more shear stable then a 5w oil. CCS Vis is measure at 15w(-20'c), 10w(-25'c), 5w(-30'c) & 0w(-35'c) For example ASL 5w30 CCS Vis@-30'c = 5322 ATM 10w30 CCS Vic@-25'c = 4034 Link to post Share on other sites More sharing options...
Lube Neutral Newbie December 18, 2007 Share December 18, 2007 my AMSoil 10w30 i used for 12000km.. never did any UOA though but is definitely still good when i changed it out. i changed it out bec i still left 8bottles left at that time (bought whole carton), and was eager to change out faster so i can finish 10w30 and try the 0w20, now finally on AMSoil 0w20.. but the 10w30 is still better than 0w20 in my type of usage. i always warm up engine for at least 4minutes no matter what rating i use. even for 0w20 i also warm up this long, so i dun really need much cold start protection. while travelling continuous for 30-50km, the 10w30 is smoother (or should i say the 0w20 is too thin, engine seems to rev to much unecessarily). but Fc on 0w20 definitely is better, i changed my tyre from 185/65r14 to 205/45r16 but fc remains the same.. 0w20 is too thin for your car....5w30 or 10w30 is a better choices Link to post Share on other sites More sharing options...
Amppy Neutral Newbie January 23, 2008 Share January 23, 2008 Hi noob here, I'm using amsoil 5w30 now from 20K-30K. Am thinking of sticking to amsoil but have no idea which grade to change to have smoother and quieter engine. I normally rev less than 3k , driving a FL-Vios and stockie. Should I change to 0w20? or? Need advice. Regards, Alan Link to post Share on other sites More sharing options...
Johorat 1st Gear February 11, 2008 Share February 11, 2008 Anyone knows if 30wt would be suitable for heavy load trip like go up Genting highland? Link to post Share on other sites More sharing options...
Garlic 1st Gear February 12, 2008 Share February 12, 2008 " I normally rev less than 3k , driving a FL-Vios and stockie. " -------------- Why not? Your engine was designed to run on 20wt, Link to post Share on other sites More sharing options...
Garlic 1st Gear February 12, 2008 Share February 12, 2008 No prob if you are planning to take a leisure drive up. Unless you plan to drive like a madman... Link to post Share on other sites More sharing options...
Vooth 2nd Gear February 12, 2008 Share February 12, 2008 I drove to genting and back on Redline's 10w30, average speed 150 km/h, now engine still purring and due for 30k soon. Purring is subjective though Link to post Share on other sites More sharing options...
Danapj Clutched February 27, 2008 Share February 27, 2008 Hi my car is about 4 yrs now and about due for 120k. Should I be looking at 0w40 or 0w30? Can my car still use the 30 ratings? Any bros advise? Thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Any amsoil alternatives?
Where to get cheap AMSOIL EO?
Explosion rocks central Bangkok, casualties seen
Assistance needed!
Assistance needed!
Amsoil VS Redline
Amsoil VS Redline
CSC3 Rocks!
CSC3 Rocks!
Amsoil oil distributor
