Rncw 5th Gear May 13, 2008 Share May 13, 2008 hi, i'm driving an altis and i've changed to shell helix syn oil during 5K servicing. i intend to change to either mobil1 or AMSOIL 5w30 at 10K, plus filter. Hi Admin, What would you recommend for Vios 07? Is it advisable to change it at 5K servicing? Please pm me your recommendation and price. Tks. ↡ Advertisement Link to post Share on other sites More sharing options...
Josho 1st Gear May 13, 2008 Share May 13, 2008 Check ur PM Link to post Share on other sites More sharing options...
Singer Neutral Newbie May 13, 2008 Share May 13, 2008 bro, im still on RP 5/30 on my 80+K kms ride Hepi n still hv few qrts to tide me thru 100k before i chg to M1 10/40, bought at Giant $12.80 during promo tat time. Sori dun hv da one u request... Link to post Share on other sites More sharing options...
Ah_low Neutral Newbie May 13, 2008 Share May 13, 2008 Do you observe any improvement in fuel consumption after switching to Shell Helix during 5K servicing. Tks. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 13, 2008 Share May 13, 2008 Ya I saw the promo for the M1. I sud have got some too. Anyway I might just fill with cantlube 5w40 which is on promo now for $28.90/5 lit. Much cheaper than RP anyway. I also considering 5w30 but worried if I use cantlube, it might shear down to a 20weight oil by the time it reaches 10K km. I might also get Toyota Type-IV for the ATF change. Also much cheaper than the Max ATF. Link to post Share on other sites More sharing options...
Rncw 5th Gear May 14, 2008 Share May 14, 2008 i'm a novice driver and been only driving for less than a year. after changing to helix at 5k, the pickup slightly faster. overall the car seems slightly more power and smoother. FC wise, i think about the same, depends on how you drive. Link to post Share on other sites More sharing options...
Singer Neutral Newbie May 14, 2008 Share May 14, 2008 yup, type IV at $25/4 ltr is a better deal Link to post Share on other sites More sharing options...
Jemjem 1st Gear May 14, 2008 Share May 14, 2008 Hi for manual transmission fluid, can advise on which to use? thanks Link to post Share on other sites More sharing options...
Genie47 1st Gear May 14, 2008 Share May 14, 2008 The heavy lubes from RP and Redline are very highly rated. Can't go wrong with them. I'm using Redline MTL. Was on RP's Maxgear 75W90. Link to post Share on other sites More sharing options...
Trex101 3rd Gear May 14, 2008 Share May 14, 2008 Will depend on what car model you driving? Link to post Share on other sites More sharing options...
Ah_low Neutral Newbie May 14, 2008 Share May 14, 2008 K, thanks for the information. Link to post Share on other sites More sharing options...
Jemjem 1st Gear May 14, 2008 Share May 14, 2008 RP is cheaper right? if both are as good, maybe I will try RP first. Thanks bro. jemjem Link to post Share on other sites More sharing options...
Jemjem 1st Gear May 14, 2008 Share May 14, 2008 Me driving Kia Cerato manual. Wan to maintain the car well in case Korean car fails me in less then 5 yrs. :P you have other suggestions other then what Genie mentioned? jemjem Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 14, 2008 Share May 14, 2008 Hi for manual transmission fluid, can advise on which to use? thanks Can try Redline MTL + Redline MT-90. That way its not too thick and not too thin. Link to post Share on other sites More sharing options...
Jemjem 1st Gear May 14, 2008 Share May 14, 2008 Portion of the mixture? jemjem Link to post Share on other sites More sharing options...
Josho 1st Gear May 15, 2008 Share May 15, 2008 Using Amsoil 20w now. Smooth and silence! Think the pick up is faster tho. Link to post Share on other sites More sharing options...
Rncw 5th Gear May 15, 2008 Share May 15, 2008 for Altis, which syn oil is good? Link to post Share on other sites More sharing options...
Trex101 3rd Gear May 15, 2008 Share May 15, 2008 Your Kia Cerato need 2.15L of 75w85 GL-4 manual gear oil, I would recommend same as Octopus 50/50 Redline MTL and MT-90. ↡ Advertisement Link to post Share on other sites More sharing options...
Any amsoil alternatives?
Where to get cheap AMSOIL EO?
Explosion rocks central Bangkok, casualties seen
Assistance needed!
Assistance needed!
Amsoil VS Redline
Amsoil VS Redline
CSC3 Rocks!
CSC3 Rocks!
Amsoil oil distributor
