The_young_once Neutral Newbie March 13, 2005 Share March 13, 2005 hi guys, am experiencing this problem, anyone had it before or know what is the cause? when braking to a stop (sometimes only) got a 'groaning' sound like something grinding against something from around 20kmh to stationary. but other than this sound, braking is still very effective. i brought this up to my mechanic about 7k km ago, he changed the front brake pad (disc), but the sound is back again. my rear is drums, i suspected the groan maybe is the brake shoe inside the drum worn out? so i tried stopping from slow speed using hand brake only (to use only rear brake) but no sound, its only when using the foot brake then got this disturbing groan. there is no 'spongy-ness' in the brake pedal feel, the front pads just changed, the rear drums fine, brake pump no leak, so what can it be? by the way im driving a suzuki carry 1.3 petrol van ↡ Advertisement Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie March 13, 2005 Share March 13, 2005 v normal la..... my sunny facing this problem oso.... go skim ur brake disc lo.. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 13, 2005 Share March 13, 2005 When u changed the front brake pads, did u check the thin metal plate placed between the pads & the calipers? I like to apply a thin film of grease on both sides of it when changing the pads. It helps prevent rust & also those groaning sounds. Link to post Share on other sites More sharing options...
The_young_once Neutral Newbie March 13, 2005 Author Share March 13, 2005 hey ahdi and pisces, thanks for your replies. oh normal ah? cheh then no sweat, thought that something is going to happen to my van, my dad said if braking is still effective shouldnt be big problem. pisces, no i didnt, actually not sure, the mechanic changed for me, cheap only $34 i recall Link to post Share on other sites More sharing options...
Potheader Clutched March 14, 2005 Share March 14, 2005 groaning sounds.. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 14, 2005 Share March 14, 2005 groaning sounds.. =========================== U think it wasn't the brakes he heard "groaning". Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 14, 2005 Share March 14, 2005 The greasing sud prevent the squeaking of the brakes. If u feel a grinding sound, cud b the brakes r wearing out, as most have this "wear indicator" to warn u it's time to change the pads. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 14, 2005 Share March 14, 2005 hey ahdi and pisces, thanks for your replies. oh normal ah? cheh then no sweat, thought that something is going to happen to my van, my dad said if braking is still effective shouldnt be big problem. pisces, no i didnt, actually not sure, the mechanic changed for me, cheap only $34 i recall ======================= I recently changed all four brakes for $95. Inclusive of a brake fluid flushing. The pads cost abt. $53 F & R excl installation. Link to post Share on other sites More sharing options...
The_young_once Neutral Newbie March 15, 2005 Author Share March 15, 2005 braking still very effective, and this sound comes on and off, mine is front disc rear drums, so only changed the front pads Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear March 16, 2005 Share March 16, 2005 if i understand u correctly, my car is also experiencing the same thing. rubbing/abrasion sounds from the front brakes (disc for my ride) when applying or releasing the brakes when the car is almost stationary. realised that this noise is esp loud after a rain or washing my car, prob bcos of the rust on the rotor. go check your brake rotors after rain and u can actually see a brown layer cover the surface. yes, tat's rust... apparently, this rubbing/abrasion sound 'prob' is quite common Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 16, 2005 Share March 16, 2005 Your brake pads cud b trying to tell u the're worn out & need to change. Most pads have this built in wear indicator to warn you. Link to post Share on other sites More sharing options...
Soya Supersonic March 16, 2005 Share March 16, 2005 u mentioned that yr front pads are new. then the sound could be from: i) the pads became glazed as the discs were not skimmed or ii) the mech din apply the anti shim coating on it as for the rear, it could be worn drums pads or simply too much dust accumulated inside the drums. spongy brake feel is not a good indication if the pads are worn. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 17, 2005 Share March 17, 2005 spongy brake feel is not a good indication if the pads are worn. =============================== Fully agree. Cud b sign of water or air in the brake fluid. Best get it checked & flushed. Cud mean a nasty when u need to stop in an emergency. ↡ Advertisement Link to post Share on other sites More sharing options...
Citroen C4 1.2 Sensor & Display
