Jk3454 Neutral Newbie March 14, 2005 Share March 14, 2005 Hi All I got a problem with my car wheel. One of the wheel look slightly slant meaning is not straight. normal car wheel look 90 degree when u look straight on the front but mine rear wheel look slightly slant and slanting at 80 degreees is it a big problem?how much to repair? ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear March 14, 2005 Share March 14, 2005 cannot repair best to get alignment Link to post Share on other sites More sharing options...
Jk3454 Neutral Newbie March 14, 2005 Author Share March 14, 2005 can align huh?? i scare something went wrong and need major repair Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 14, 2005 Share March 14, 2005 your rear wheel? sounds like: 1. you went and bang the rear wheel against a curb 2. the nuts are not tightened 3. there's sumthing wrong with the rear axle better have it looked at... just my 1/2 cent Link to post Share on other sites More sharing options...
Jk3454 Neutral Newbie March 14, 2005 Author Share March 14, 2005 bingo!!! my wife kena some metal stuff on the road last yr and the whole rims become pi cha. tyre also bust up. where can chk? Link to post Share on other sites More sharing options...
Maded Neutral Newbie March 14, 2005 Share March 14, 2005 if your car still under warranty, go to your SE and tee-gong Otherwise may have to go to a mechanic... that one i dunno liao... maybe some of the other bros here can help... Link to post Share on other sites More sharing options...
Jk3454 Neutral Newbie March 14, 2005 Author Share March 14, 2005 mine is 93 corrolla Link to post Share on other sites More sharing options...
Apollo 1st Gear March 15, 2005 Share March 15, 2005 ur later description is not something not "slight slant", sounds more like serious slant. alignment confirm gone case. if normal steel type, cheap to replace, if sports rim, confirm gone. better replace then after realign with high speed balancing. Link to post Share on other sites More sharing options...
Luckcent 4th Gear March 15, 2005 Share March 15, 2005 It maybe the camber has gone negative....get a 4 wheel alignment check and rectify... Link to post Share on other sites More sharing options...
Jk3454 Neutral Newbie March 15, 2005 Author Share March 15, 2005 ok thanks for ur advice going stamford this sat Link to post Share on other sites More sharing options...
Luckcent 4th Gear March 15, 2005 Share March 15, 2005 no problem, hope it turns out fine for your car.... Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 16, 2005 Share March 16, 2005 If the rear wheels is of independent suspension, the slight tilt is the camber angle setting. Many modified street cars had negative camber setting. ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
Question on Transfer of Car Ownership
Question for Car Servicing
COE renewal question
Question of polyclinics
Noob questions on property
PSLE Maths question. How to solve?
