Patcheon Neutral Newbie April 2, 2005 Share April 2, 2005 (edited) I experience a small skid(aquaplaning) last weekend while making the turn from KJE to BKE southbound during heavy rain. Speed about 50km/h. My current tyres is a set of 2 years old 185/65/14 Yokohama Aspec A300 with mileage of 28000 to 30000km. Think it is about time to change a new set of rubber though there is still about 3 to 5mm left before reaching the threadwear marker. Anyone can recommend which tires are good in terms of wet/dry grip. Noise is not so much a concern over safty. One candidate considered is the Bridgestone potenza GIII. Any other recommendations of other brands/models with 14" size available locally? Had no wish to upgrade the rims as ride is 5 years old already. Thanks in advance. Edited April 2, 2005 by Patcheon ↡ Advertisement Link to post Share on other sites More sharing options...
Hihi Neutral Newbie April 3, 2005 Share April 3, 2005 Yokohama CDrive? Link to post Share on other sites More sharing options...
Jetcool 1st Gear April 4, 2005 Share April 4, 2005 G3 has good grip but noisy. Good alternative is Bridgestone Turanza GR80 - not so noisy, but still decent dry/wet grip. Used to cost ard $80+ for 185/65/14 size, but heard price has gone up recently. Link to post Share on other sites More sharing options...
Apollo 1st Gear April 4, 2005 Share April 4, 2005 falken ZE512, abit noisy but aqua planing is better cos of deeper grooves. n rim protector as well. too bad, european tires hardly support 14inch, otherwise would b Pilot Sports or Eagle F1 liaoz. ok lah, they beri expensive also. Link to post Share on other sites More sharing options...
Czchome Neutral Newbie April 4, 2005 Share April 4, 2005 Yok AVS ES100 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear April 4, 2005 Share April 4, 2005 g3/gr80/512/preceda/cpc/eagle f1/p6000/es100 my top picks preceda/cpc Link to post Share on other sites More sharing options...
Patcheon Neutral Newbie April 5, 2005 Author Share April 5, 2005 Thanks all for the replies. Seems like there are quite a few choices. Is the G3 noise level really bad. I once in a while do make trips up north so if noise is really bad, that's a minus to me. Is also considering of the CDrive and the GR80. I thought GR80 only have 15" and above. Is it true that all those v-groves tyres are noisy but offer better grip? Sorry for the ignorance but which brands are "512/preceda/cpc" under? Thanks Link to post Share on other sites More sharing options...
Furrynadz 5th Gear April 5, 2005 Share April 5, 2005 v groove pumps out water to the sides rather than behind, definitely better in wet falken 512, michelin preceda, continental premium contact if u go up north go for something v groove for better grip like eagle f1/yoko es100 i done 160 with es100 (dry) and 120(wet)b4, definitely ok Link to post Share on other sites More sharing options...
Elantrahatch Neutral Newbie April 7, 2005 Share April 7, 2005 GR-80 has 14 inches.. I saw it at CAS customer lobby.. For me, I will get the GIII. Link to post Share on other sites More sharing options...
Seanboi 1st Gear August 19, 2005 Share August 19, 2005 how about DUNLOP DZ101? Link to post Share on other sites More sharing options...
Teddi Neutral Newbie August 19, 2005 Share August 19, 2005 Your tyre size 185/65/R14. Again, If your ride is already 5 years old, changing new tyres may not be good enough. Suggest you have your 4 shock absorbers changed as well. Tyre can consider 195/60/R14. Overall dia is the same as 185/65/R14 Link to post Share on other sites More sharing options...
Timoec Neutral Newbie August 20, 2005 Share August 20, 2005 (edited) if u r heading up north..think es100 will be better choice.. as for g3.. had this experience...tyre screech oni when u go off the limit... scared til face turn white c-drive wear off quite fast..used oni 5 month..liao liao now change back to bf goodrich g-force sport..gooder but noisy maybe u can try d pirelli dragon...heard not bad Edited August 20, 2005 by Timoec Link to post Share on other sites More sharing options...
Sevenz Neutral Newbie August 20, 2005 Share August 20, 2005 SO3, BFG GFS, GSD3, AD07 Link to post Share on other sites More sharing options...
Teddi Neutral Newbie August 26, 2005 Share August 26, 2005 GSD3 & SO-3 does not have 14" Not sure on AD07. Usually Ultra High performance tyres starts from 15" Link to post Share on other sites More sharing options...
Elantrahatch Neutral Newbie August 28, 2005 Share August 28, 2005 That's right. For 14 inches, the variety of tyre selection is extremely limited if you are into performance. If one should want the max performance out of his tyres, getting a 16" will be good. Most performance tyres at least will start from 15" Thus, for 14", i will recommend the Potenza GIII. It's not too heavy but yet the performance is not too bad. Used to run on 14" thus did some light research on tyre availability. Link to post Share on other sites More sharing options...
Seanboi 1st Gear August 31, 2005 Share August 31, 2005 ES100 have 14inch one meh? Link to post Share on other sites More sharing options...
Zoom99 Neutral Newbie August 31, 2005 Share August 31, 2005 If u decide on GR-80, there is offer at Autobacs. Cost=$78/pc incl nitrogen gas fill, free rotation and free puntured service till yr tyres are changed to the next set The price is incl of GST. Link to post Share on other sites More sharing options...
Seanboi 1st Gear August 31, 2005 Share August 31, 2005 how much they selling G3 over there? for 14inch ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
