Clubace Clutched July 22, 2005 Share July 22, 2005 Use this...it translate the whole web site. www.worldlingo.com ↡ Advertisement Link to post Share on other sites More sharing options...
Clubace Clutched July 22, 2005 Share July 22, 2005 btw...i am using kizz clear R....sealant + filler....quite ok...only thing is pray that it dont rains after u apply it.....harder to apply than the wax...have to clean fast or die. On 3 coats of kizz clear...next time going to fusso 9 mths sealant liao... Link to post Share on other sites More sharing options...
Toalson 1st Gear July 22, 2005 Share July 22, 2005 Kizz clear is actually a filler/sealant 2 in 1 rite? How's the shine of the Kizz clear? And tks for the link will try to use it to translate the soft99 webby. Link to post Share on other sites More sharing options...
Toalson 1st Gear July 22, 2005 Share July 22, 2005 So I actually got the wrong product..... the hand spray seemed to be use more like for touch up and not for actually coating. Btw the product should be Fusso Speed & Barrier. Now I wonder wat damage I had done to my existing coat of EGP. Anyway just now i tried to put some water over my car n was with the results. Cant see beading but water seemed to run off pretty fast when I pour water over the roof but if I spray beading occurs As compared to EGP, regardless of pouring or spraying, the water still bead with the latter showing very fine beading. Oh I realised that if use google to translate oso yielded similar results as wordlingo. Link to post Share on other sites More sharing options...
Southpark2000 Neutral Newbie July 24, 2005 Author Share July 24, 2005 Managed to dig this up from my hard drive.... Southpark The Dude Use and Care of Plastics.pdf Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 28, 2005 Share July 28, 2005 1. Wash 2. Clay 3. Polish with swirl/scratch remover like Scratch-X (if there are swirls and scratches) 4. AIO 5. SG 6. Wax Bro stil need to apply wax after applying the SG? Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear July 28, 2005 Share July 28, 2005 Actually no need. Wax is just a LSP to add extra shine onto SG. In fact SG can be layered. But after u wax over several layers of SG, there's no point layering SG onto wax liao. Hope I'm making sense Question: If I wan to layer SG, do I need to apply AIO all over again for surface preparation. If so, would it be like starting all over again since AIO remove SG? Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 28, 2005 Share July 28, 2005 ok bro, so after laying SG, i can still put a layer of wax? but u sae many layers of SG den u wax will remove the SG ah? or wad? sorrie i dun realli get the meaning. Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear July 28, 2005 Share July 28, 2005 Wax wont remove SG. It will only add extra shine onto it. But after u wax liao, it is meaningless to apply SG onto the waxed surface. No worries, I also learning. Maybe bros like gen2 can help Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 28, 2005 Share July 28, 2005 ok.. so how long must i wait before applying another layer of SG? Link to post Share on other sites More sharing options...
Silgt Neutral Newbie July 28, 2005 Share July 28, 2005 But after u wax liao, it is meaningless to apply SG onto the waxed surface Synthetic sealants (like SG) won't bond to a natural wax, but wax on top of synthetic is OK. Link to post Share on other sites More sharing options...
Silgt Neutral Newbie July 28, 2005 Share July 28, 2005 ok.. so how long must i wait before applying another layer of SG? as a general rule, do allow at least 6 hours to half a day for synthetic polymer to set. Try not to layer immediately as you might just wipe off your previous layer underneath. Hope this helps... Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear July 28, 2005 Share July 28, 2005 yea bro, thanks for clarifying...was waiting for some expert comments Link to post Share on other sites More sharing options...
Gen2 Neutral Newbie July 29, 2005 Share July 29, 2005 but u sae many layers of SG den u wax will remove the SG ah? Hi Seanboi, SG is a sealant and it can be layered but its better to wait 12-24hours before you put on the next layer so that the sealant can complete the bonding. Normally 3 layers will be enough and any extra layer will not show a significant difference in appearence. After layering SG you may consider toping with a pure carnauba wax which will give the car a more wet look appearence. Do not use any wax with cleaner, this will remove the SG that you have put on the car. A few pure carnauba wax you can consider is Mother's CG pure carnauba wax, Meguiar's #26 High Tech Yellow Wax and S100. You may even consider topping SG with some other sealant like NXT paste wax, which has a mild cleaning property not strong enough to remove the SG you have layered. So the procedure is SG -> SG -> SG -> carnauba but do not do this SG -> carnauba -> SG SG does not bond well onto carnauba. Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear July 29, 2005 Share July 29, 2005 Seanboi, follow Gen2's instruction can never go wrong Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear July 29, 2005 Share July 29, 2005 Gen2 bro, if I were to layer SG, say I already apply 1 layer liao, I just need to wash my ride then apply SG? Like that like no surface prep leh...how ah? Link to post Share on other sites More sharing options...
Gen2 Neutral Newbie July 29, 2005 Share July 29, 2005 It should be ok unless your car surface have alot of contaminants which need claying otherwise pretty safe to just wash with car shampoo than apply SG. Better still you can do a QD wipe down first after the wash before the application of SG. Link to post Share on other sites More sharing options...
Toalson 1st Gear July 29, 2005 Share July 29, 2005 I managed to try the Fusso speed & barrier good for 90days spray. I was surprise to feel that my car surface feels very different. It feels very smooth as compare to my previous use of AG SRP and/or EGP (if I dont use claybar) But yet to really try out the beading effect cos tis feel days hardly rain. However when I spray and wash car, realise the beading not really there but the surface still feels smooth. The shiny is not really present for this product. Guess need to top up with wax. ↡ Advertisement Link to post Share on other sites More sharing options...
[Spyshots] 2023 4th Generation Skoda Superb
Soft99 Products Rock!
SKODA Octavia vRS Combi Mk II
P21S and Klasse available in Singapore!
Skoda Superb Combi 2016 model - nice!
Soft99 Fusso 12-month water repellant
Soft99 meta-clean
Soft99 meta-clean
ST: Toddler fell to death two mths after maid saved his life
