Johnchong Neutral Newbie May 15, 2005 Share May 15, 2005 Need some help here. I just happened to open the bonnet, only to discover green stuff splattered over the engine bay, esp on the fan area. Then I checked my coolant reservior tank, it's almost empty! Strangely, the temperature gauge on the dash doesn't show any abnormality. How? ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 15, 2005 Share May 15, 2005 the reservoir is like backup. so may not show symptom on temp gauge. i still think it is leakage somewhere. and the temp gauge sensor may have some prob - does it move?? Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 15, 2005 Author Share May 15, 2005 Ya, the temp gauge does move. You're referring to slowly rising after start up rite... I tot of filling it up with some coolant as a temp solution. Tmr then go workshop. can? Link to post Share on other sites More sharing options...
Linus Clutched May 15, 2005 Share May 15, 2005 the same thing happened to me during my last PG trip. during rest time, open up the bonnet to cool down the engine, saw water gushing out from the coolant compartment. the cap is loose and flipped open by itself. need to secure the cap tightly and top up the compartment to the right water level. perhaps u need to fill up ur tank again. any idea wat sort of coolant u r using ? Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 15, 2005 Share May 15, 2005 ensure the cap is tight and top up the reservoir tank near to full mark. if u free, on engine and check for any leakage. then if ur temp guage moving, shd be still working. shd be still able to tahan to workshop tomrrow. Link to post Share on other sites More sharing options...
Apollo 1st Gear May 15, 2005 Share May 15, 2005 hose leak? fill it up, keep bonnet up, and rev the car, look for watergun effect fr the hoses. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 15, 2005 Author Share May 15, 2005 Both the reservior and radiator caps looks secure to me. However, there seems to be greenish residue along the top of the cooling fins, just below the coolant pipe. Dunno wat coolant leh, we alwiz just send for servicing, let the mechanic do everything. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 15, 2005 Author Share May 15, 2005 What coolant should I top it up with? Link to post Share on other sites More sharing options...
Linus Clutched May 15, 2005 Share May 15, 2005 hmmm.. then better send it to workshop 1st thing tomm morning. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 15, 2005 Author Share May 15, 2005 Hose looks ok to me leh. But the piping maybe got prob. Link to post Share on other sites More sharing options...
Apollo 1st Gear May 15, 2005 Share May 15, 2005 i was hoping for u it's the hose, tat would hv been hell cheaper. piping means the radiator? jialat.... there r temporary measures like radiator leak additives. but u'll need permanent fixes. Link to post Share on other sites More sharing options...
York Clutched May 15, 2005 Share May 15, 2005 go to any supermarket, get 1.5L bottle distilled water to top up... Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 15, 2005 Share May 15, 2005 i bought the coolant only $2 at Sheng siong. cheap and gd Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 15, 2005 Share May 15, 2005 heard from my frenz his once got choked...his mech helped to clear the chokage. after that ok liao. for me, my radiator got leakage, changed a new one $100 with installation. Link to post Share on other sites More sharing options...
Linus Clutched May 15, 2005 Share May 15, 2005 (edited) this coolant u bought, is it of a certain colored liquid ? i was thinking if to replace the water with coolant, means gotto flash out the entire reservoir and the radiator oso. then top up the radiator with water and the reservoir with coolant ? anybody can help with the sequence ? Edited May 15, 2005 by Linus Link to post Share on other sites More sharing options...
Josephtan1234 Neutral Newbie May 15, 2005 Share May 15, 2005 Need some help here.I just happened to open the bonnet, only to discover green stuff splattered over the engine bay, esp on the fan area. Then I checked my coolant reservior tank, it's almost empty! Strangely, the temperature gauge on the dash doesn't show any abnormality. How? Wait for the radiator to cool and remove the cap and check to see if its corroded. It sometimes happen. Otherwise there is a choke somewhere. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 15, 2005 Author Share May 15, 2005 Oh crap... $$$ Thanks for the advice anyway. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 15, 2005 Author Share May 15, 2005 But normally, what do pple put in the reservior tanks? Should be half water, half coolant I heard... ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Coolant question
Coolant question
Citroen C4 1.2 Sensor & Display
