Mivec9 1st Gear May 17, 2005 Share May 17, 2005 rubber seal = $200 ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 17, 2005 Share May 17, 2005 i replaced whole radiator only $100 nia.... Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 17, 2005 Author Share May 17, 2005 Hmm, think rubber seal gave way, but the whole pipe was replaced... Btw, how can radiator only cost $100? Recon? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 17, 2005 Share May 17, 2005 OK , they are using epoxy to glude the upper tank and radiator body.The upper tank must be of PU plastic. This separation of upper tank and radiator body is common with plastic component radiator. Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 17, 2005 Share May 17, 2005 i believe it is a recon one..it looks very new and the top pipe is brand new. the price is way low for new one. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 17, 2005 Share May 17, 2005 which mech u referring who bungle up job??? my regular mech? I was refering to the earlier post about your mech bungling up the repair. I mistook it to b simon. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 17, 2005 Share May 17, 2005 I had a similar problem some time back. The horizontal joint had given way. The metal clips along the joint had rusted away. I replaced the damaged radiator with a re-con one. Has been ok for about 4 years now. My cost was about $100 plus if I remember correctly. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 18, 2005 Author Share May 18, 2005 Actually do many pple go for recon parts nowadays? I mean not just radiator... Cuz we always tend to go for new parts. Last time replaced aircon coil also... Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 18, 2005 Share May 18, 2005 recon parts are cheaper...however as they are used parts but reconditioned, it may last as long as original parts. of course getting original parts are best, provided u r willing to fork out that much $$$ Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 18, 2005 Share May 18, 2005 You may consider that the "re-con or 2nd hand" parts u get r actually much better quality than what u get from the spare parts shops nowadays. Many parts don't come from Japan anymore & those that do might not b of as good quality as what is supplied to the factory. And on top of that, new parts here cost very high. Link to post Share on other sites More sharing options...
Minilexus Neutral Newbie October 14, 2005 Share October 14, 2005 Oh crap... $$$ Thanks for the advice anyway. go to an honest mech to check. even my regular mech anyhow diagnose when i got high temp issue and leaking coolant problem. and advice me to do a top engine overhaul to change the gasket - $400-$500...siao. A second opinion was due to: leaky rubber hose (abt $10+), change recon temp housing ($58) and radiator fan motor denso brand new ($90)- resolved the whole prob. where to buy the denso fan motor? Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 14, 2005 Share October 14, 2005 Oh crap... $$$ Thanks for the advice anyway. go to an honest mech to check. even my regular mech anyhow diagnose when i got high temp issue and leaking coolant problem. and advice me to do a top engine overhaul to change the gasket - $400-$500...siao. A second opinion was due to: leaky rubber hose (abt $10+), change recon temp housing ($58) and radiator fan motor denso brand new ($90)- resolved the whole prob. where to buy the denso fan motor? If I'm not mistaken, I think Xtraun got it from one of the shop at Yew Tee Industrial Estate. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 16, 2005 Share October 16, 2005 yes I got it from Simon @ yew tee industrial estate.. Link to post Share on other sites More sharing options...
Spikedoll Clutched December 22, 2005 Share December 22, 2005 (edited) my old civic also always kena such prob...first is radiator leak..then hose leak..not one but duno 2 or 3 hose leh they replaced with used parts from scrapyard..but dun really last long..see heng suay 1 ..suay suay get one bad condition den siao liao.... the mech told me dun anyhow use coolant...last time me duno poured whole bottle green coolant into my radiator and reserve tank..den top up with abit tap water...mech said the strong "acidic" coolant can "bite" the hose causing it leak still rem the agony ..drove halfway temp needle rose up to MAX red line stopped car immediately..saw green liquid below my car... Edited December 22, 2005 by Spikedoll Link to post Share on other sites More sharing options...
Kanchelsk 2nd Gear December 22, 2005 Share December 22, 2005 sis~ I din know female mthly flow is green in color... Link to post Share on other sites More sharing options...
RadX Moderator December 22, 2005 Share December 22, 2005 yah man..must be damn unhealthy flow that one...with fungus no wonder green Link to post Share on other sites More sharing options...
Maddude Neutral Newbie December 22, 2005 Share December 22, 2005 Reminds me of my army days when I brought lots of bottles filled with tap water when driving their mini-bus! There was this mini-bus, although the workshop claim that its not leaking, after 10Km+ the water somehow start to disappear, and finally found out the cause of it -> the cap wasn't tight anymore... Link to post Share on other sites More sharing options...
Spikedoll Clutched December 22, 2005 Share December 22, 2005 except the color is different lah ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Coolant question
Coolant question
Citroen C4 1.2 Sensor & Display
