Papercup Neutral Newbie June 12, 2005 Share June 12, 2005 Hi guys, I came across this passage when was reading an article about improving car performance: "Higher compression ratios produce more power, up to a point. The more you compress the air/fuel mixture, however, the more likely it is to spontaneously burst into flame (prior to the spark plug igniting it). Higher octane gasolines prevent this sort of early combustion. That is why high-performance cars generally need high octane gasoline - their engines are using higher compression ratios to get more power." Is it true? Does it mean that those car with high compression ratio need to use high grade fuel e.g. v-power? ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 12, 2005 Share June 12, 2005 Yap, that's should be true. The higher octane the fuel have, it can undergo higher compression before self-ignition. Link to post Share on other sites More sharing options...
Papercup Neutral Newbie June 12, 2005 Author Share June 12, 2005 So those SC and TC got to use those high grade oil right? Hmmm... so those high grade oil really got some advantages. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear June 12, 2005 Share June 12, 2005 yah....higher CR vehicle need higher octane rating fuel... some race cars use fuel moree then 100 ron.... the higher Ron also give racing cars more power... Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 14, 2005 Share June 14, 2005 [reply] Hmmm... so those high grade oil really got some advantages. Of course must have advantage, otherwise how to justify the higher pricing. Link to post Share on other sites More sharing options...
themagi Neutral Newbie July 11, 2010 Share July 11, 2010 (edited) Old thread but want more views, I've been asking around Honda owners and according to the owner manuals, City and Oddy at least can run on RON92 but the compression ratio of City is 10:4 and Oddy is 9:7. I thought any CR above 10 must run on at least RON95? Then I checked out Chevy Cruze and its CR is 9:5 and when I checked with a Chevy SA, he said that all the Chevys run on minimum RON95. So like different cars are telling different stories on what CR can accept what RON grade? http://www.------.com/pdb/cd.php?pid=1804 - City http://www.------.com/pdb/cd.php?pid=527 - Oddy http://www.------.com/pdb/cd.php?pid=2366 - Cruze Edited July 11, 2010 by themagi Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 11, 2010 Share July 11, 2010 The other factors affecting the fuel octance to be used are piston crown design, position of spark plug, used of pre-combustion chamber and direction of incoming air etc. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear July 12, 2010 Share July 12, 2010 and also whether it is DI or MPI. DI reduces cyclinder temperatures allowing a lower octane petrol to be used even though its at higher compression. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear July 31, 2010 Share July 31, 2010 and also whether it is DI or MPI. DI reduces cyclinder temperatures allowing a lower octane petrol to be used even though its at higher compression. Switched to Diesel engine? ↡ Advertisement Link to post Share on other sites More sharing options...
Used Car, what STA Inspection grade then can buy?
Fuel Plus Meet Up
Fuel Plus Meet Up
