Looking for ground wires
Whistlad
oh... u should hv informed me, i'll go n screw them abit and find out where else got. anyway, what is done is done. the $18 ones is the same, all ready to bolt on type.
you can get 5-pt grounding cable set (taiwan made) 4AWG (thicker cable) $25 @ TOYOGO showroom, Unit 11 Toa Payoh Ind Park off Toa Payoh Lor 8
got this info from Wish Club forum [thumbsup]
now buy already don't know how to ground...i know connect all from negative to the points that you wanna ground BUT problem is that i don't know where is some parts located....eg. alternator and throttle body and .......
i live in west area too...wanna meet at clementi area or jurong area, i live in ghim moh...
Edited by Dennisk
hmmm...
3 points wrong.
1/ alternator to car body (driver's side, as far fr batter as possible), short cable, check, there should be a original ground point somewhere.
2/ battery to front of car for headlamp & horn.
3/ best point is fr battery to foot of ECU. << this is the most import place to ground.
correction for yer grounding:
1) fuel rail mounting screw instead of the fuel regulator, becuz nearer to injectors coils and oso to avoid fuel leakage at the regulator.
2) ideal grounding is at least 8 points.
okay,
1) the vibration from engine may loosen the bolt where the grounding is done, so leakage from the screw will result. Mine is done on the mounting screw of the fuel rail. You need to scrape off some paint from the rail body to make good contact. [nod]
2) Additional grounding:
The first method u hv already used is a star connection.
The second set of grounding is to make a daisey-wheel chain to provide good ground to all mud guard chassis, firewall chassis (infront of driver), and front chassis for items like signal and head lamps, horn, wiper-motor, etc. [:)]
