Suzy Pics
Hoppe
er, water temp and vacuum were ard 60+ for each. install by myself lor, very easy de.
for vac just direct plug into vacuum source. water temp have to drain coolant and cut pipe. make sure to get the 28mm adapter, cos i bought the wrong size before.
volt is around 60 also.
only oil temp and pressure need a little more effort to fix [sweatdrop]
AET gauges are very cheap, all under $80 but no installation fee.
installation for vac n water temp shd be ard $30-$50, suggest go JB n do.. much cheaper + very fast also [thumbsup]
AET stands for? os my friend did his 3 gauges in moffiz, cos him 600 riggit. so i think end of the day still 200+ sing dollar, tats y i think the price in singapore almost the same. if tats the case then rather do in singapore, anythin wrong at least dun need to go back jb.
unless the price difference in jb really very big
noted tat ur side got 2 gauges. both different design? the vacuum gauge looks better than the other one, as the other one the rite side got some obstruction. ur vacuum gauge is wat brand? as i like the color. isit smoke face?
ATC TECH PTE LTD
20 ANG MO KIO IND. PARK 2A
AMK TECHLINK #02-14
SINGAPORE 567761
Tel : 6484 3431
i find the gauges there are the cheapest so far... for autogauge, timex, pro and swoosh. [thumbsup]
think still got other brands.. motor meter.. etc?
but all taiwan de, wanna get good ones go for VDO n autometer.. cheaper than defi i think but no link.
NA, shd have water temp and vacuum...
water temp would indicate a overheat, loss of coolat pressure.. etc
normally, water temp is almost the same as oil temp so it's a gd indicator. unless u wack the engine then oil temp wld be high 90s to 100, while coolant temp only shows 80+deg.. but the temp will even out later.
saved my a couple of times, cos the stock gauge is not that 'attractive' to look at, so most of the time don't pay attention.
vacuum is for monitoring FC also, step more and it shows more air going into engine = more fuel used. also can help detect leakage in gasket and other stuff, have to find on the web. 'monitor' health of engine or so they say..
And since it is an 'active' gauge = moves alot during driving, quite fun to place it on the dash or on the side.. [laugh]
another should have is the voltage gauge.. shows if ur alternator is working and how much power u using.., best is have voltage and ampere gauge.. can show if the battery is charging or discharging. [nod]
Edited by Yc86
heheh.. cos its autometer, and it's a white faced one?
or maybe the price put wrong, shd be ard $50+ [hur]
but i think voltage is ard $30 also.. [:/]
i saw the gauges in moffiz.. quite ex, ard 200+RM per gauge. but it's 60mm one and dunno what taiwan brand, think in s'pore can find cheaper..
some stuff are more ex than s'pore, but workmanship is definately cheaper.
Edited by Yc86
60mm for the vacuum and water temp on the windscreen right.
52mm for the oil temp/pressure.. one i place on the center console, the other hide below.. too many look too 'beng' [laugh][laugh]
think 52mm looks nicer, 60 too big for small cabin like ours [sweatdrop]
ATC TECH PTE LTD
AMK TECHLINK #02-14
SINGAPORE 567761
Tel : 6484 3431
saw the net, the autometer, where the meter got 7 different color. is tat a smoke face? or can still see the meter readin when the ignition off. AET got sell tat? how muc is it per gauge
sorry i quite blur by the white face n smoke face.
am i rite to say the smoke face is totally black when ignition off n the white face is can still see the gauge readin when the ignition is off
