Chuapcd 1st Gear January 26, 2013 Share January 26, 2013 Hi, my 2007 Mazda 5 when idling e.g stop at traffic light, I can feel the engine vibrate and seems going to stall although it has not happen yet. I am worried it may not be a good sign and possibly of potential problem or the car suddenly stalled. The problem seems only happen when idling...Anyone can advise what could be the cause of it ? Any recommendation for a workshop in the west who is familiar with Mazda cars to solve this problem ? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Gitanic 6th Gear January 26, 2013 Share January 26, 2013 auto gear problem? Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear January 26, 2013 Share January 26, 2013 Hi, my 2007 Mazda 5 when idling e.g stop at traffic light, I can feel the engine vibrate and seems going to stall although it has not happen yet. I am worried it may not be a good sign and possibly of potential problem or the car suddenly stalled. The problem seems only happen when idling...Anyone can advise what could be the cause of it ? Any recommendation for a workshop in the west who is familiar with Mazda cars to solve this problem ? Thanks in advance. Go back to AD to seek advice.. spend a little bit of money to buy peace of mind.. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear January 26, 2013 Share January 26, 2013 usual suspects lor coils/plugs/maf or map sensor/o2 sensors/egr valve or solenoids go back AD if wanna be sure Link to post Share on other sites More sharing options...
Warthog Clutched January 26, 2013 Share January 26, 2013 Check your air flow meter, EGR valve, vacuum leak and idle control valve. If dirty, just clean it with a parts cleaner. Link to post Share on other sites More sharing options...
Pureness Clutched January 27, 2013 Share January 27, 2013 have you ever replaced your engine mounting? perhaps its the mounting that is causing the vibration afterall you've said the car only seems like its going to stall but has never stalled before, perhaps this is an indicator that your problem isn't serious Link to post Share on other sites More sharing options...
Hosaybo 6th Gear January 27, 2013 Share January 27, 2013 To check if it is engine mount issue, engage gear in D mode with your legs stepping on the brakes, check to see if vibration occurs. Then switch to neutral or park. If the vibration is reduce or disappear, then likely hood it is engine mount. Replace all mount and all issues wil be gone. Damage should be about 400 to 500 bucks for a bread butter car. Link to post Share on other sites More sharing options...
Orbit78 1st Gear January 28, 2013 Share January 28, 2013 Do take note of the rpm when the vibration kick in. It the idle rpm went too low it will have big vibration too. That I am not too sure what cause it ↡ Advertisement Link to post Share on other sites More sharing options...
MAZDA 6
MAZDA 6
2025 Mazda EZ-6
2025 Mazda EZ-6
2019 All new Mazda 3
The Rotary-Electric Mazda Iconic SP Concept Could Save the Sports Car
2022 Mazda CX-60
2022 Mazda CX-60
Looking for Job in automotive sector, need advise
