Mllcg 3rd Gear July 23, 2012 Share July 23, 2012 http://www.nbclosangeles.com/news/local/flushservices.html watch the video. not much text ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear July 23, 2012 Share July 23, 2012 I am a believer in engine flushing. Link to post Share on other sites More sharing options...
Vaped Neutral Newbie July 23, 2012 Share July 23, 2012 flushed the engine at autobacs early this year in feb. after getting a used car last year in sept. so far so good. coz previous owner dragged....the engine oil change before selling the car...imo coz of the C&C svc sticker. 1 Link to post Share on other sites More sharing options...
Hi_torq Neutral Newbie July 23, 2012 Share July 23, 2012 My experience, performance improvement good. After a week, engine camshaft seized. Small particles got carried over to bearing. Have to be done very carefully. Ensure, nothing leftover in your system. Filters not to be removed at any point. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 23, 2012 Share July 23, 2012 Don't waste $$$. Even if previous owner drag the maintenance interval, just fill up with mineral oil and run for 1K, drain off and repeat until you song. 3 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 23, 2012 Share July 23, 2012 Save your breath.... those who swear by engine flush will continue to do so no matter what you say or what you show them... Let them be.... 2 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 23, 2012 Share July 23, 2012 Don't waste $$$. Even if previous owner drag the maintenance interval, just fill up with mineral oil and run for 1K, drain off and repeat until you song. Yup, thats the proper way if you want to clean up your engines.... Its slower, but sure it wont cause any damage to the engine.. Link to post Share on other sites More sharing options...
Yixiang1 3rd Gear July 23, 2012 Share July 23, 2012 Think i saw autobacs service package is engine flush using 4 litres of fluid leh... unlike the usual one just pour like 400ml of voltronic into engine oil, ask u rev a bit for 10-20 min... then drain out everything... wonder if that is any good... and autobacs oil change using their vantage oil or other oil is not exactly expensive.... since it comes with the flush... only fear is later, the mechanic tell u this and that need to change... after the normal servicing. 1 Link to post Share on other sites More sharing options...
5936 1st Gear July 23, 2012 Share July 23, 2012 If you care to take time to hunt for engine flush, there are some, maybe harder to find now, engine flush that needs to be added-in and driven for 200-300miles, before going for oil change. Its becoming harder to find this type of engine flush. Link to post Share on other sites More sharing options...
Arixlim Clutched July 23, 2012 Share July 23, 2012 haha..i was doing engine flush and fuel injector all the time every month 10k at C&C, after sometime, i give up after warranty, cos i wake up and find i am a carrot...hahaha...they rabbit me all the time...hahaha....engine flush and fuel injector always hardsell...iss correct, and any SE price also difference, the older SE charges higher and more insistent.. i like this thread...now i am feeling advised. thanks just fill up with mineral oil and run for 1K, drain off and repeat until you song....is the correct way...but it grinds metal and produces more wear and engine tear thru revving also, so i think just drive normal, they say japanese engine more durable can last 10 years after that...u must be ready to pay... 2 Link to post Share on other sites More sharing options...
Mickkiee 1st Gear July 23, 2012 Share July 23, 2012 it should not be flusehed it must be cleaned Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 24, 2012 Share July 24, 2012 not only deposit will get stuck in your engine. think about it... if the flush is strong enough to get ride of stubborn slug in minutes, what will it do to your engine seals.... 1 Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 24, 2012 Share July 24, 2012 not only deposit will get stuck in your engine. think about it... if the flush is strong enough to get ride of stubborn slug in minutes, what will it do to your engine seals.... specifically your head gasket. Link to post Share on other sites More sharing options...
Tayspiderx 3rd Gear July 24, 2012 Share July 24, 2012 My mechanic only flush my diesel van engine and not my petrol driven car. Guess its more of useful for high mileage vehicles. Link to post Share on other sites More sharing options...
Gee 1st Gear July 24, 2012 Share July 24, 2012 read somewhere that engine flush on old car also remove harden gunk that helps seal movement, and that created problem. 1 Link to post Share on other sites More sharing options...
Pitbull Clutched July 24, 2012 Share July 24, 2012 Go youtube, look for " Vtec club oil change". See what the Japanese boss of Spoon says about engine flush, believe you will not touch engine flush again lol Link to post Share on other sites More sharing options...
KaKiLang 4th Gear July 24, 2012 Share July 24, 2012 (edited) I always use cheap mineral oil without changing the filter, run 2-3k, drain, if not happy, drain, mineral oil and run another 2-3k den synthetic oil with filter change. Best drain when engine is still hot, oil more liquified. Edited July 24, 2012 by KaKiLang 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic July 24, 2012 Share July 24, 2012 I changed engine oil and put the used one in a 20L container. When it's full I'll empty in into a bigger drum. What comes out during the transfer are clumps of mud-like substance besides the liquid oil. They settle and form at the bottom of the container due to inactivity and change of temperature. Those who experience engine failure after engine flush, probably experience these substance being dislodged by the cleaner. Once it choked the small oil passage, there is no lubrication for the engine and the engine failed. For those who say they have no problem with engine flush, they are lucky they have not experienced it as yet. It doesn't mean they will always be that lucky. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
