Turbonetics 2nd Gear December 3, 2005 Share December 3, 2005 any of u using the Superione products??? or have any feed back on this products??? ↡ Advertisement Link to post Share on other sites More sharing options...
Yc86 Clutched December 4, 2005 Share December 4, 2005 er..... i think quite a few ppl here would say it's crap.. slight improvements only it works same as the E68 n other stuff like the 'volks racing-E68-lookalike' right? or is that thing connected to the fuel line instead... nv tried myself thou.. that thing is expensive! Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear December 4, 2005 Share December 4, 2005 Yeap, i do agree with Yc86. Its all up on your mind if you think its good, meand good. And if you think its bad, means bad. However, i was at Turf Kote in 2nd quarter in Sin Ming for my turf kote re-spray and the supervisor was highly recommended to me. It has a 30 days trial and if no improvement, full $$$ return without questions asked. Also i saw on the spot that a Honda driver installed this gadget. But to me, its all the same and it only SLIGHTLY improved. If this gadget is that good, then why manufacturer did not implemented in the car when they 1st designed the car? So, think about it... Link to post Share on other sites More sharing options...
Mitevo8 Neutral Newbie December 4, 2005 Share December 4, 2005 (edited) I guess it's up to individual's expectation lah. I used it and i dun think it's truely a snake oil. Abt 1 yrs+ ago i got a free trial unit on my old car (carburettor engine), it doesn't increase HP but can feel much responsive eng power. Once put in my new car, for the first few weeks can feel the same thing but aft that mayb ecu relearn and it's seem like back to normal (like stock). After changing to green twister, i scrapped it and it's now lying in my storeroom. so conclusion, mayb only good for older cars lor. Edited December 4, 2005 by Mitevo8 Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear December 4, 2005 Author Share December 4, 2005 haha...maybe u r used to the new mod... that's why u tot the ecu relearn itself... but if install this thing,the ecu will relearn itself meh??? then install for what??? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched December 4, 2005 Share December 4, 2005 (edited) the ecu will always try to maintain 14.7 part of air to one part of fuel (Stioch ratio) at the exhaust O2 sensor......the ecu realise leaner A/F mixture and slowly catches up to this stioch ratio after some time lapsed. tats is wat it meant by "ecu re-learn by itself" Older cars dun hv ecu or "smart" ecu so says. "Smart" ecu mean it uses 32-bit CPU inside, whereas old car uses only slower or "not so smart" micro-controllers. Edited December 4, 2005 by Normal_aspirated Link to post Share on other sites More sharing options...
Mitevo8 Neutral Newbie December 5, 2005 Share December 5, 2005 N.a has ans you on that. But i m sure it's not abt getting used to the new mod lor, hard to explain the experience but just put it this way: "use your feeling... luke...may the force be with u". Link to post Share on other sites More sharing options...
Marcostan 4th Gear December 5, 2005 Share December 5, 2005 Hi brother, You can try RMK202 almost the same as Superione but only half of the price. My follow RAVer using and hv very good FC. I'm in 16 rims only manage to get 11+++km/L but my follow RAVer in 18 rims but he can get 13+++km/L. He was already in his 6th full tank of petrol, still having the same FC. MarcosTan Toyota Rav4 Link to post Share on other sites More sharing options...
Mitevo8 Neutral Newbie December 5, 2005 Share December 5, 2005 Huh? it's not me that ask abt superione but turbonetics. i think you replied to the worng person i used superione b4 and already de-kitted it. Link to post Share on other sites More sharing options...
G0opy Neutral Newbie December 5, 2005 Share December 5, 2005 any of u using the Superione products???or have any feed back on this products??? Used it before. Superione ST555. 3 phrase to sum it up: Waste Time Waste Money Waste Effort Don't know how much it's costing now. But I got mine for $250. If you think that it's worth for that 'so called' little improvement (most likely verified with butt dyno), then by all means go ahead. For me, there's no improvement on anything at all. Link to post Share on other sites More sharing options...
Secondhand Neutral Newbie December 5, 2005 Share December 5, 2005 If like that ah, u can try to explain ur findings to NTU, School of Engineering. They are the ones who verify the gadget before and after installation... NTU leh... Somemore some professor by donno wat name... Anywayz, it did its job b4 the ECU re-learn... That's how much I can say... After the re-learn process, u're back to stock... Link to post Share on other sites More sharing options...
Yc86 Clutched December 5, 2005 Share December 5, 2005 (edited) Used it before. Superione ST555. 3 phrase to sum it up: Waste Time Waste Money Waste Effort Don't know how much it's costing now. But I got mine for $250. If you think that it's worth for that 'so called' little improvement (most likely verified with butt dyno), then by all means go ahead. For me, there's no improvement on anything at all. heheh... like ur style can anyone explain how does that thing actually work? the description frm the phamplet/box always put it in a BS way that makes some sense, and ppl add the rest to complete the story till they believe it's true. that's part 1 of the psychological game. called marketing? part 2 is feedbacks that come from the few satisfied customers...... Edited December 5, 2005 by Yc86 Link to post Share on other sites More sharing options...
Genie47 1st Gear December 6, 2005 Share December 6, 2005 Even with a carburetted engine, you don't need it because you can get away by tuning the carburetor. Something the EFI cars cannot go about. FYI, carburetted fuel delivery usually run much leaner than EFI systems. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie December 6, 2005 Share December 6, 2005 Part 3 is the need to rationalize one's purchase and the need to protect its resale value until it is sold, then they start bashing it as snake oil. Link to post Share on other sites More sharing options...
Chneo1982 1st Gear December 12, 2005 Share December 12, 2005 Ya the test reports are from NTU!!!! and if it's from NTU, DON'T BELIEVE IT!!!!! cos i am currently a undergrad in NTU and i have seen a lot wacko professors. No standard one they all..... super turned off by them..... i saw this product and learnt that it is test by NTU and all, i totally lost interest liao..... Link to post Share on other sites More sharing options...
Scorcher Neutral Newbie December 12, 2005 Share December 12, 2005 I bought it. Felt no improved performance. Wanted to sell it. Nobody wants. Left it in my boot for quite sometime. Recently put it back to use again, as nothing better to do. And recently found that my previous 3 tanks got an improvement of 50 Km mileage. Ha.. Afterall still got a bit use la... No performance gain, but minimal improvement in FC. But still think it's not worth it la... dunno whether it harms the engine anot... Link to post Share on other sites More sharing options...
Chneo1982 1st Gear December 12, 2005 Share December 12, 2005 i think all these waste money one la. even if really can improve FC, it will also be by a bit. and how many tanks of petrol to pump b4 you can really cover up the cost of the product. be it broquet or what, all is cheat money one.... if really want a powerful car then don't worry about the FC, if want a good FC car then can 4get about the power...agree??? Link to post Share on other sites More sharing options...
Scorcher Neutral Newbie December 12, 2005 Share December 12, 2005 haha... that's for sure... but alot of time when people got nothing better to do would tend to buy such things thinking tat it will improve the car.. haiz... i think the best gadget will allow people tried it first before paying... wouldn't it be better? hee... ↡ Advertisement Link to post Share on other sites More sharing options...
Superione Jet555 turbo?
Superione Turbo 555 Petrol Jet
RMK 202 & Superione T555..
How to Clean Superione T555
