Turbobrick Neutral Newbie April 23, 2002 Share April 23, 2002 Don't say smuggle lah, for one item and for personal use it's fine. To play safe take it out of the packaging and stuff them into a container in the boot. Spare parts only mah ↡ Advertisement Link to post Share on other sites More sharing options...
Evo6_23 Neutral Newbie April 23, 2002 Share April 23, 2002 thanks guyver... but now still on member status (5-10% discount) with jackspeed... will try other mechanics once this membership expires... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear April 23, 2002 Share April 23, 2002 You may wanna try the following..... Racy Auto 360 Changi Road Tel : 6342 1793 Look for Heng or Ken Verdict : Not much of a workshop but workmanship is acceptable and reliable. I have been using them for the past 10 years. Auto Dynamac Blk 3019A Ubi Road 1 #01-28 Tel : 6745 9702 Look for Raymond Verdict : Nice workshop and fully equipped. Friendly boss helps and competent mechanics. Price reasonable. In fact I will be senting my car for the timing belt change tomorrow at Auto Dynamac. I will be doing the following preventive maintaince : Timing Belt Change Throttle Body Cleaning Adjust Tappet Replace waterpump Check and replace other belts (alternator and fan) Aircon servicing. (Top up of gas and replace the dryer) The estimation is around 700-800 as some of the parts do not require replacement. Why dun you give Raymond a call.......tell him that the ghost ask you to call one....he beri scared of ghost one.... Link to post Share on other sites More sharing options...
Hensony Clutched April 23, 2002 Share April 23, 2002 Initially, I did stay. Over time, I've come to trust them. I simply leave the car there, go shopping and then pick up the car. Wow!! so u stayed there & waited for them to complete for u? Link to post Share on other sites More sharing options...
Guyver 1st Gear April 23, 2002 Share April 23, 2002 Ok, u see how lah.... Link to post Share on other sites More sharing options...
Guyver 1st Gear April 23, 2002 Share April 23, 2002 So did u get the same guy to do the job? Or u liase with the boss.... and he'll get his mechanic to settle for u? Link to post Share on other sites More sharing options...
Toyota22 Neutral Newbie April 23, 2002 Author Share April 23, 2002 can i know what the waterpump for ? You may wanna try the following..... Racy Auto 360 Changi Road Tel : 6342 1793 Look for Heng or Ken Verdict : Not much of a workshop but workmanship is acceptable and reliable. I have been using them for the past 10 years. Auto Dynamac Blk 3019A Ubi Road 1 #01-28 Tel : 6745 9702 Look for Raymond Verdict : Nice workshop and fully equipped. Friendly boss helps and competent mechanics. Price reasonable. In fact I will be senting my car for the timing belt change tomorrow at Auto Dynamac. I will be doing the following preventive maintaince : Timing Belt Change Throttle Body Cleaning Adjust Tappet Replace waterpump Check and replace other belts (alternator and fan) Aircon servicing. (Top up of gas and replace the dryer) The estimation is around 700-800 as some of the parts do not require replacement. Why dun you give Raymond a call.......tell him that the ghost ask you to call one....he beri scared of ghost one.... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 23, 2002 Share April 23, 2002 Waterpump is there to circulate your coolant/water mix around the engine and radiator, crucial part. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie April 23, 2002 Share April 23, 2002 Hi! there, Toyota22, The water pump is used in water-cooled engines, e.g. the Beetle, has air-cooled engine. Water-cooled engines gives higher performances than air-cooled engines, thereby creating an increase in engine temperatures. To lower the temp., water cooling to intake manifold (though some don't have), cylinders, intake assembly is by water pump to circulate the water to a radiator for the safe operation of the engine at high mileage & speed. To enable the engine to reach optimum operating temp, a thermostat is installed, which restrict the water flow to the engine, where it will only open the valve for water to flow, once temp. of the cooling system is reached for the smooth running of the engine. In SG, with the temp. that we have, you'll not see the unsafe operation to the engine cooling system. In colder climates, if the temp. is too cold, damage to the engine is severe if it doesn't reach the operating temp of the engine. Hence, the radiator will have to be covered to prevent the flow of cold air into the radiator. Over here, overheating is more of a concern, as it will affect everything in the engine bay. Relays, connectors, electrical parts, a/c components, will be degraded from an overheating engine. Many times, pressure fitting on the a/c system have blown open from the overworked a/c compressor. Rgds Paul Yong Link to post Share on other sites More sharing options...
Hensony Clutched April 24, 2002 Share April 24, 2002 There is no particular mechanic I go to. I just tell the boss what needs to be done and confirm the price with him before I leave. So did u get the same guy to do the job? Or u liase with the boss.... and he'll get his mechanic to settle for u? Link to post Share on other sites More sharing options...
Guyver 1st Gear April 24, 2002 Share April 24, 2002 Wah!! U part time mechanic before is it? cos u sound like one!! Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie April 24, 2002 Share April 24, 2002 Hi! there, Guyver, I do some of my own maintenance, and parts replacements. As I was once a mechanic in the offshore diving industry and w/shop assistant in a heavy plant company, I spend a lot of time talking to the mechanics where I developed to be quite a good engine-near. The most significant incident that occured when I was at the w/shop was when sparks flew from a grinder and ignited a tray of thinner for cleaning parts, the explosion of flames engulfed an Indian worker. Be very aware of safety instructions. Rgds Paul Yong Link to post Share on other sites More sharing options...
Guyver 1st Gear April 24, 2002 Share April 24, 2002 Wow!!! no wonder.... u sound so hands on..... Wah!! u have experience real life things like this ah? like those in movie like that..... how did u save the guy then? Care to tell us about your heroic act? Link to post Share on other sites More sharing options...
Maverick88 Neutral Newbie February 23, 2004 Share February 23, 2004 Did you went back to starauto change it? Yours should lanos I right? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie February 23, 2004 Share February 23, 2004 As my car is reaching the 80000km mileage soon, is it a must to change the timing belt ? I driving a toyota soluna.Any recommendation of where to change and the cost? Whatever it is, don't tempt fate by going beyond the recommended mileage for a timing belt change. One busted timing belt means many other things needed to be changed. Since your car has served you well for 80000, don't you think it's time to serve her well too? Link to post Share on other sites More sharing options...
Genie47 1st Gear February 23, 2004 Share February 23, 2004 I would replace all the belts and battery in one go once a year. No need to remember the distance covered. Country is small and even with drives to MY, replacing them once a year is very recommended. Link to post Share on other sites More sharing options...
Soya Supersonic February 23, 2004 Share February 23, 2004 u replace all the belts once a year??? wah, super overkill. even my pants belt i dun replace every year.... Link to post Share on other sites More sharing options...
Hitman Neutral Newbie February 23, 2004 Share February 23, 2004 even my pants belt i dun replace every year.... ... thats shows how well you maintain your tummy , me gotta change every year , tummy bloating liao ↡ Advertisement Link to post Share on other sites More sharing options...
Rear seat passenger : Do they belt up?
Clean car seat belt
Clean car seat belt
Changing of water pump and timing belt.
Remember to wear seat belt
Rear seat belt stuck
Little Nonya - change in timing today
Lancer CS3 timing belt change
CNA: More drivers caught for flouting child seat belt rules
