What is wrong?
Tea3
Dear all,
Would like your opinion. I have a problem starting my Fabia after I switch off the engine to i.e pump petrol or air into my tyres or wait for someone in a carpark. Thought it was the battery problem but sent it to my mech & he says it's the temperature sensor(?). So, if I want to start it again, I have to step on the accelerator repeatedly while turning the key for some time before it can start again (even my friend doesn't have to do that with his 9 year old Mitsubishi). Any other Fabia owners encountered that problem?
Hi Tea3,
As your car is brand new, i feel it could just be some minor things which cause this starting problem. Please bring it back to the agent and ask them fix it under the warranty. This will also prevent them from saying later that the car has been 'touched' by outside workshop and therefore they dun want to be responsible for the problem.
btw, for all we know, the battery, though supposed to be new, may be too weak..... or some loose wire connections which reduce current flow etc therefore making it hard to start..... simple things but can cause big inconveniences..........
Just my 2 cents.........
Cheers
Edited by Super7
Well, my car isn't brand new. It's second hand & I bought it 3 weeks ago. Dealer told me it's one year old but when I received statement from loan company, it stated there "Manufactured year: 2000". That's beside the point.
Went to Czech Auto & they said the car is no longer under warranty. Just sent it for servicing last week & my mech has ordered a new sensor.
Fuel pump or idle valve? Hmmm didn't think of it but the mech would have spotted it if there was something wrong with them during last weeks' servicing, right?
Oh, I still haven't received my log card yet. Who am I suppose to get it from or rather, who is suppose to send it to me? I did received a letter from LTA stating that ownership of the car has been transfered to me. Apart from that, nothing else.
Does your car fan continue to work after you switch off
the car engine. Some European models have this concept
and if so, this could be the reason for not being able to start
your car bcos the fan is drawing electricity from the battery
but the battery is not re-charging since the car if turn off.
If that is the case, just ask mechanic to disconnect the
wire for this function and problem solve, liaw!
Believe that you do not have a problem ti start the car after
you have turn it off for about 30 minutes, right?
Cheers!
Nope, everything in the car stops working when I turn off the engine...except the driver [laugh].
Well, I find it can start once the engine is cool & yeah, 30 minutes after it is turned off. 2 weeks ago, I went to Czech Auto to buy some accesories for my car & was there for 15 minutes. My car was parked in the hot sun (parking lots along Queenstown bad for cars - no shade) & I had so much problem starting the car thereafter. When it finally started, I was soaking wet in perspiration. [sweatdrop]
Will go and check again whether it is in my car but I really don't remember getting it from the dealer. If I don't have it, it's time to KSA [sly]
BTW, what sensor is your mechanic ordering for you??
Have not come across any car that has a sensor that will not
allow you to start your car when it is warm.
Also you should not keep stepping on the accelerator when you
crank the car to start. Depress the accelerator 1-2 times and
then crank start.
Cheers!
"problem starting my Fabia after I switch off the engine"
Hi! there, Tea3,
Are your sparkplugs new? If it's a battery problem, you won't be able to crank for too long.
Have you tested the alternator & battery?
Temperature sensor?? at the air-flow meter?? or cooling system??
Rgds
Paul Yong
Thanks for the advice. So, I shouldn't hold the accelerator down either before starting eh? He said some temperature sensor was spoilt & because of that, there was too much petrol in the engine. Therefore, I needed to step on the accelerator to pump the petrol before I can start the car. I was confused because shouldn't the engine start even better if there was petrol in it? Excuse me for my ignorance.
Well it's a one year old car. The mech didn't say anything about the spark plugs. I am sure he would have if something was wrong with them. Battery is old too but he said nothing was wrong with it. He didn't tell me which temperature sensor was spoilt. I know that the car's cooling system pump is spoilt & I am waiting for stock to come.
IMHO, this happens only to cars without fuel injection [sweatdrop]
I concur with Pauly, that it could be an alternator problem.
Could it also be a problem with the starter? [rolleyes] My bro's Daihatsu used to have the same problem, and has since been rectified as it was due to a faulty starter [nod]
