Seanboi 1st Gear March 14, 2007 Share March 14, 2007 As mentioned above, is it ok to use Semi-syn oil for 5K servicing? Some say yes, some say no. ↡ Advertisement Link to post Share on other sites More sharing options...
Wizzercool 1st Gear March 14, 2007 Share March 14, 2007 It is OK to use full syn and semi syn for 5k servicing. Your engine is already run-in after 5k km. The only reason why it is not recommended is cost $$. This becos full syn and semi syn oil can last upto 10k km or more. So it is waste to throw it away after 5k km of usage (at 10k servicing). For me, I dun give a damn, I used the infamous Car*ube full syn oil at 5k servicing. Nowadays it is so cheap, less than $30 for 5L bottle. Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 14, 2007 Author Share March 14, 2007 Giant selling @ $27 if i m nt wrong. Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 14, 2007 Author Share March 14, 2007 Run In period of the engine is a time where engine parts with very tight tolerance gets worn. This loosens up the engine, helps improve economy, performance and engine life. Using synthetic oil, which gives better lubrication than mineral oil might just be too smooth to allow proper wear during the run in period, hence usually manaufacturers do not recommend synthetic oil during the first 1000km. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear March 14, 2007 Share March 14, 2007 5K........I think Use Normal Oil Better.......If AD Supply It ...... Link to post Share on other sites More sharing options...
Wizzercool 1st Gear March 14, 2007 Share March 14, 2007 WTF, you asking for opinion on 5k km servicing and now you are talking about 1k km servicing !!! Link to post Share on other sites More sharing options...
Omega Neutral Newbie March 14, 2007 Share March 14, 2007 GIANTS Tampines OPEN today check out the Straits Times....is selling @ $27.90 http://img218.imageshack.us/img218/2773/dsc00460bb9.jpg Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 14, 2007 Share March 14, 2007 any oil also can la. syn, mineral whatever. it doesnt really matter. its nonsense about break in and all that. have seen a BMW video where they redline the engine a few times to test the car before it leaves the factory. Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 15, 2007 Author Share March 15, 2007 actually thats wad i saw in another forum. so just copy n paste here lor... Pai seh la... Link to post Share on other sites More sharing options...
Xtras Neutral Newbie March 17, 2007 Share March 17, 2007 It is OK to use full syn and semi syn for 5k servicing. Your engine is already run-in after 5k km. The only reason why it is not recommended is cost $$. This becos full syn and semi syn oil can last upto 10k km or more. So it is waste to throw it away after 5k km of usage (at 10k servicing). For me, I dun give a damn, I used the infamous Car*ube full syn oil at 5k servicing. Nowadays it is so cheap, less than $30 for 5L bottle. Over at NTUC AMK HUB this Car-lube 5w30 5L is promoting at $26.90 Only Link to post Share on other sites More sharing options...
Lancer78jas Neutral Newbie March 18, 2007 Share March 18, 2007 Usually for new car, first two servicing will be semi syn oil. Meaning 1k and 5k. At 10k, use fully syn oil for for ride. First 2 servcing actually is to clear the wear and tear residue due to new part of the engine. When the parts are seasoned, then fully syn oil is used. Link to post Share on other sites More sharing options...
Demon81 Neutral Newbie March 18, 2007 Share March 18, 2007 bro you are right Link to post Share on other sites More sharing options...
Sambuca Neutral Newbie March 20, 2007 Share March 20, 2007 yea. good advice. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 20, 2007 Share March 20, 2007 I cant speak for the china made cars (now that they're out) but most engines are not new. It would have been run continuously for at least 24hrs at high rpms at the factory before it gets dumped in the car. There is little/no wear and tear residue and all this serves is to help the parts bed in better, but only if all the parts get as hot as they can get. If there is any bedding in, it will definately be completed properly within 1000kms. The first 15-20mins when the engine first starts is the critical section which makes or breaks the engine. Every "new" engine unfortunately would have been run for a much longer period before the owner even gets the car The oil should have been changed long before that event as well. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 20, 2007 Share March 20, 2007 Just use whatever lah. even normal dino oil can last 5000ks so you're fine since the next service is at 10000ks. Link to post Share on other sites More sharing options...
Solar Turbocharged March 25, 2007 Share March 25, 2007 (edited) It is OK to use full syn and semi syn for 5k servicing. Your engine is already run-in after 5k km. The only reason why it is not recommended is cost $$. This becos full syn and semi syn oil can last upto 10k km or more. So it is waste to throw it away after 5k km of usage (at 10k servicing). For me, I dun give a damn, I used the infamous Car*ube full syn oil at 5k servicing. Nowadays it is so cheap, less than $30 for 5L bottle. Over at NTUC AMK HUB this Car-lube 5w30 5L is promoting at $26.90 Only ok, call me cheapskate. out of curiosity, i used ca*lube on one of my car servicing, the 5w40 fully sync one. darn. fuel consumption shot up, from usual 11-12l/100km, now consistently 13-15l/100km. my driving pattern and route is pretty similar, 50% city. got this as an average figure over 5 fuel top-ups, so its not just a one-time. of course, my personal experience.. will change back to my usual oil on the first available opportunity.... a lesson learnt for being cheapo Edited March 25, 2007 by Solar Link to post Share on other sites More sharing options...
Pat10lim Neutral Newbie April 8, 2007 Share April 8, 2007 ↡ Advertisement Link to post Share on other sites More sharing options...
Car semi leather
Car semi leather
INSANE Gymkhana Style Semi Truck!
Walmart reveals concept Hybrid Powered Semi Trailer Truck
Semi Auto Transmission Gate Orientation
Age 25 and semi retired???
Recommendations for semi slicks
100K svcing bill.....
Semi_Synthetic and FC?
