Foofam77 Neutral Newbie March 26, 2007 Share March 26, 2007 Going for my 1st servicing, being a newbie myself, is there any specific areas I should ask the mechanics to look out for or check? I have at this moment, the following pointers that I would like the mechanics to cover: 1) check wheel suspensions for damage (as I have gone up a couple of kerbs) 2) do not wash the car body. Only wash the under-body chasis and wheel areas 3) reset ECU 4) check CVT gear box for damages (could be damaged due to frequent gear shifting to practise parking) 5) able to repair a mini dent slightly above the tyre area (absolutely no idea how this dent comes along!!) pls advise. thank you ↡ Advertisement Link to post Share on other sites More sharing options...
Mubarakrashid Neutral Newbie March 26, 2007 Share March 26, 2007 (edited) wah.. 1st 1000km oredi need to check gearbox ah.. how many million times u shifted your gear stick..? Edited March 26, 2007 by Mubarakrashid Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 26, 2007 Share March 26, 2007 Just let the SE know of items 1 to 4 n they will note it down on the job sheet. Item 5 have to pay!!! I suggest u do it elsewhere. Normally I will tell SE to wash the engine bay n the aircon condenser n radiator. Its not easy to access to such places to remove those small leaves. Link to post Share on other sites More sharing options...
Evilernie 4th Gear March 26, 2007 Share March 26, 2007 Guy does washing of the engine bay do damage to the car parts? Especially for those old model car? Link to post Share on other sites More sharing options...
Djcoolmax 2nd Gear March 26, 2007 Share March 26, 2007 bro... what car you driving until you keep mounting kerb? if you are new to driving or the car that you are driving now is longer, take your sharp turns slowly. I don't think you need to worry much about your gearbox.. if changing gears will cause you problems.. u will not be the only one. as for the mini-dent. maybe it from one of you kerb mounting. in any case, you will have to pay for this as dents is not covered by warranty. Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 26, 2007 Share March 26, 2007 Have u been to TCM servicing b4??? Tell the SE to wash ur engine bay, they will know wat to do. They dont use a jet nozzle n spray ur engine bay!!! They will use degreaser n water wif cloth to clean it. They know the dangers. When u collect ur car, open the bonnet n u will see a nice clean engine bay. Link to post Share on other sites More sharing options...
Quantum 5th Gear March 26, 2007 Share March 26, 2007 Going for my 1st servicing, being a newbie myself, is there any specific areas I should ask the mechanics to look out for or check? I have at this moment, the following pointers that I would like the mechanics to cover: 1) check wheel suspensions for damage (as I have gone up a couple of kerbs) 2) do not wash the car body. Only wash the under-body chasis and wheel areas 3) reset ECU 4) check CVT gear box for damages (could be damaged due to frequent gear shifting to practise parking) 5) able to repair a mini dent slightly above the tyre area (absolutely no idea how this dent comes along!!) pls advise. thank you Excuse me, What is ECU? and why 'reset ECU'? Thks Link to post Share on other sites More sharing options...
Ccssgm 1st Gear March 26, 2007 Share March 26, 2007 I Call them .....to check....The Exhaust Portion......Is there Too Low..... Why always Reverse Hit the Stopper...... Link to post Share on other sites More sharing options...
Mummypenguin Neutral Newbie March 28, 2007 Share March 28, 2007 Are u driving a Latio? My car exhaust also always hit kerb. So I can't reverse all the way in. Link to post Share on other sites More sharing options...
BoneStock 5th Gear March 28, 2007 Share March 28, 2007 ECU = engine control unit. The computer in your car controlling the fueling and sparking among other things. ECU no need to reset unless u do a mod, etc...it retains your driving habit called adaptive learning data. Once reset, it wont feel good to drive for a while cos the adaptive learning data need time to build up again. Link to post Share on other sites More sharing options...
Kxbc Turbocharged March 28, 2007 Share March 28, 2007 [reply]Are u driving a Latio? My car exhaust also always hit kerb. So I can't reverse all the way in.[reply] I have the same problem too. Exhaust hit a couple of times already but I think it's still holding steady. Need to take care esp parking in short parking lots eg one particular row at the East Coast UDMC parking area. I buang my bumper straight into the raised kerb as cannot see at night. But no damage to bumper at all. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear March 28, 2007 Share March 28, 2007 Same As me..........TC also Cannot Solve It...... ↡ Advertisement Link to post Share on other sites More sharing options...
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Workshops with engine oil flushing machine
Volvo Servicing
Volvo Servicing
