Chucs75 Neutral Newbie June 5, 2007 Share June 5, 2007 Hi, The engine light on my 3yr 3mths Altis is ON all the time even after starting the engine. It doesn't go off. Any idea why this is so? BR ↡ Advertisement Link to post Share on other sites More sharing options...
Jassonlo Neutral Newbie June 5, 2007 Share June 5, 2007 bro, encountered tis problem during my las ride. brought back to AD. its something with the checkback of our ECU bring back to ur AD get them do a chk on where your problem is n do a reset. Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie June 5, 2007 Share June 5, 2007 A simple check on yr engine oil if low engine oil top it up.... or ask yr mechanic to chk on it Link to post Share on other sites More sharing options...
Ccssgm 1st Gear June 5, 2007 Share June 5, 2007 Your Battery Still Can Tahan ?..... Link to post Share on other sites More sharing options...
Limitedspeed Neutral Newbie June 5, 2007 Share June 5, 2007 Think its your mods that are giving you the problem but must establish which is the 'culprit'. Bring it back to BM, they have a diagnostic kit to check this kind of problem. Some outside workshops may also have the diagnostic kit too but may not have the analysis manual meaning when the code or codes reading comes up they may not know how to interpret it. Better to get it resolved then drive around with the problem Link to post Share on other sites More sharing options...
Chucs75 Neutral Newbie June 5, 2007 Author Share June 5, 2007 hmm, isn't there a light solely for battery? Link to post Share on other sites More sharing options...
Jassonlo Neutral Newbie June 5, 2007 Share June 5, 2007 bro, jus send it to ur AD. let them chk. Link to post Share on other sites More sharing options...
Chucs75 Neutral Newbie June 5, 2007 Author Share June 5, 2007 ok thanks Link to post Share on other sites More sharing options...
Ccssgm 1st Gear June 5, 2007 Share June 5, 2007 Also Can Cause battery failure..... Link to post Share on other sites More sharing options...
Crowbar Neutral Newbie June 5, 2007 Share June 5, 2007 it cud be sum sensor prob..get diagnosed asap..shud be faulty sensor.... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear June 5, 2007 Share June 5, 2007 (edited) Engine light is on or check engine ? engine light 1) Not enuff oil pressure. 2) Low level engine oil Check Engine light 1) ECU fault Bring back to agent and use a OBD computer to check. Could be one of the sensors are faulty. Dunno about Toyota....some cars when they detect fault...they will go into limp mode. (that is they will seal off the final ratio....car can move...enuff for you to drive to service station but cannot speed.) Edited June 5, 2007 by Ghostrider Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie June 6, 2007 Share June 6, 2007 Try not to ramp the engine sometimes engine might even stall..... go to your mechanic they or agent, they can check with OBD computer Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear June 6, 2007 Share June 6, 2007 Hi, The engine light on my 3yr 3mths Altis is ON all the time even after starting the engine. It doesn't go off. Any idea why this is so? BR My Engine light is on lately and brought it back to Agent. Claim that O2 Sensor connector pin loose.... Just cannot accept the logic.... ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Anybody into quantum physics, relativity or just a science freak?
Sg Election 2025!
Sg Election 2025!
