atlantis Neutral Newbie October 4, 2007 Share October 4, 2007 My only grouse with this so far is it does not allow keying in coordinates for destination. And I thought it was a basic feature in GPS. ↡ Advertisement Link to post Share on other sites More sharing options...
Ooniik Neutral Newbie October 5, 2007 Share October 5, 2007 Get a Garmin Nuvi.... U won't regret it... I'm using it, for a week now.....very simple and clear. Link to post Share on other sites More sharing options...
atlantis Neutral Newbie October 7, 2007 Share October 7, 2007 Feedback after using the device for a week. Feedback is from a first time GPS user perspective and my requirements (as opposed to comparing to other brands and model). This feedback also goes to Eastgear in the hope firmware upgrades to address the cons. Pros: 1- Value for money @ $499, notably inclusion of all key maps for M'sia and S'pore (malsing, SLA, mapking), and text to speech (TTS) 2- Pretty easy to use (given the available functions) Cons: 1- Not able to use coordinates for destination (this is my biggest grouse) 2- Not able to switch off completely when plugged into car charger; every car ignition starts GPS and the startup 'announcement' [also not able to disable the announcement, after all how many times must I hear the same thing] 3- Not able to see coordinates of destination (after search), so can't share coordinates with others 4- Not able to see visually on the destination/navigation screen which map is currently used: malsing, SLA, or mapking 5- In car charger connects to mini-usb port instead of GPS holder (despite the contacts available on holder and on GPS). So, removing GPS from the car requires extra step for disconnecting charger from GPS unit) Less important but useful to point out that the documentation is a bit thin in explaining certain things - for example, one has to clear the track log to avoid 'hang situation' (that even a reset/restart) won't help. Link to post Share on other sites More sharing options...
Cklasse 1st Gear October 7, 2007 Share October 7, 2007 After so many posting...it is very clear Garmin is the leader and Garmin is the one that knows what a user wants. It has never been any easier to use a Garmin, others are simply trying and have not reach there yet. Link to post Share on other sites More sharing options...
atlantis Neutral Newbie October 7, 2007 Share October 7, 2007 I hope you did not make that universal endorsement from my posting. It is afterall a price performance issue to many who cares for the utility value each dollar brings. Holux 53Clife serves my purpose well and if it knocks off the first few cons in my list, it is then perfect for my purpose (but perfection is not needed in reality). Link to post Share on other sites More sharing options...
Rskeisuke Clutched October 7, 2007 Share October 7, 2007 hi there, i'm a holux user too.. i believe you can see the coordinates by selecting the satellite icon when you are at the location. i can't figure out the clearing of track log as i haven't encounter it on my set. care to elaborate? Link to post Share on other sites More sharing options...
atlantis Neutral Newbie October 7, 2007 Share October 7, 2007 (edited) Agree, but I need the coordinates for any POIs before I reach them. On the 'hang' situation: Sometimes, when I switched on the GPS inside a building (where the GPS cannot get a fix), the 'timer' icon (similar to Windows OS's timer icon) will appear (as if it is waiting for something). This seems to last forever, even after I leave the building and it remains in the same state even after powering off (and on again) with the front button or the switch behind. The solution: press the "Cancel Routing" button (next to the "View GPS Status" button). p.s. I was told this happens when the system thinks it has not reached a destination when it was last powered off. However, in my last incident, I had actually reached my destination before powering off. Edited October 7, 2007 by atlantis Link to post Share on other sites More sharing options...
Rskeisuke Clutched October 7, 2007 Share October 7, 2007 i haven't encounter the hanging issue you've got. this may be due to the fact that i only turn on the unit only after i leave my MSCP, usually getting a fix within 30 secs. Strange though, iirc, my unit doesn't turn on after i start the engine even with the car charger adapter plugged in. It only turned on after i depress the front on/off button. Link to post Share on other sites More sharing options...
atlantis Neutral Newbie October 7, 2007 Share October 7, 2007 Let me ask EastGear on the on/off issue. It makes sense to work that way. thanks! Link to post Share on other sites More sharing options...
atlantis Neutral Newbie October 10, 2007 Share October 10, 2007 Clarification: The symptom I described (GPS starts during ignition) is only applicable when the switch behind the GPS unit is turned to OFF. Which means it must be left in a constant battery mode/charging mode. Link to post Share on other sites More sharing options...
Rskeisuke Clutched October 11, 2007 Share October 11, 2007 actually, i'm still a little confuse about the system switch at the rear. i never switch it off. i believe it's the switch to the OS core. iirc, the manual states only to switch it off if one encounters severe problem with the set (i.e. cannot lock on to birds or lock-ups) Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged October 11, 2007 Share October 11, 2007 My only grouse with this so far is it does not allow keying in coordinates for destination. And I thought it was a basic feature in GPS. I believe they will have this added feature when a later model comes up for sale. Anyhow, every GPS set will have their own inherent problems lah. The searches for Garmin also takes sometime to get use to, eg. if u key in JLN...chances are u get no matching results but if u key in Jn, then all the Jalan Jalan will come out. Can take quite awhile to search sometimes since I kept it in my car (hidden away) most of the time and won't be meddling with it till I'm in it. Btw...can your set search via postal code? Link to post Share on other sites More sharing options...
Zaxx 2nd Gear October 19, 2007 Share October 19, 2007 hi so u mean this holux can actually use malsing maps?so beside some functons will not be much different from garmin what?think will take a look at it... Link to post Share on other sites More sharing options...
atlantis Neutral Newbie October 19, 2007 Share October 19, 2007 You have wait for eastgear to provide you the (converted) malsingmaps. You cannot use those from malsing web site directly. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 27, 2007 Share October 27, 2007 is holux running mapking? u can download the mapking map from malsing. Link to post Share on other sites More sharing options...
Wish_ros Neutral Newbie November 6, 2007 Share November 6, 2007 too bad, East Gear is running out of stock, any shop selling the Holux..? cheers Link to post Share on other sites More sharing options...
Mivec9 1st Gear November 6, 2007 Share November 6, 2007 should have. what's the price range for holux? it was 499 previously. Link to post Share on other sites More sharing options...
Penthousepauper Clutched November 6, 2007 Share November 6, 2007 abt $230 ↡ Advertisement Link to post Share on other sites More sharing options...
Speeding captured through on board GPS/In Car System
Car immobiliser and GPS tracker recommend?
Is Standalone GPS obsoleting?
Dashcam with GPS
Dashcam with GPS
Car Accessories Workshop in West Area
Replacing GPS software on DVD WINCE 6.0
GPS location tracker for Pets, Kids, Equipment and
Does haze affect GPS signal?
