Difference VTEC Sohc & Dohc
Llfr
i have heard of vtec controller. can u tell me more about it. how dose it operate function.!!!
sorry i love v-tec cars but dont drive a v-tec.
1. 1stly, I don't use one. The stock VTEC is good enough for me.
2. Based on my limted understanding, a VTEC Controller help you to adjust your VTEC engagement point by presetting engagement to a lower RPM to kick-in the VTEC early. Read from somewhere that there are Bros that tune it to 2000rpm. In addition, it also provides some vital statistics and you can also adjust the air/fuel ratio on different RPM. In this way, you tell the system when your VTEC will be ignited and you can monitor it right from the display.
Regards,
piggyback ECU like VAFC (displaced by Apexi AFC-New) and V-Con (Buddyclub)
Yes that Apexi VAFC is like a piggyback (not real piggyback lah) around 500 bucks a pop...can greatly tune your Vtec.. at the same time the Vtec engineers who migrated to germany also came up with a new add-on --> the Ninja capsule air charger ...
How do you know it was invented by the VTEC engineers?
Regards,
I'm no expert in this field. Logically if you want power, the engine has to suck in more air, more fuel is burnt and thus give you the go. Of course, there is a chance to alter the air/fuel mixture to optimize usage but by how much is a question mark for the tuner.
Regards,
Vtec controller is use to control the old Vtec...can't be use in the new R18A engine.
This new engine is more of a fuel consumption and better torque output with variable length intake manifold
i need your advise.
iam caught between Ninja capsules,Vtec and Turbo.
magnet works best.. confirm ur BMX will become babe magnet
need your advise.
which should i install for my BMX?
No need them lah, jsut strip your BMX at the BMW boot can liao.
Regards,
i need your advise.
Honestly speaking i would recomend the Vtec ... why? Because the Vteck allows your BMX to have a sudden surge at high Leg Rotation per minute... if u have turbo.. there will be a lag.. at low RPM... so Vtec is the best
