Ommph Clutched September 14, 2007 Share September 14, 2007 Hi All, Just need to check if the following scenario is normal (coz i never encounter this for my past 2 cars): After turning off the engine of my car, I walked out and hear a fan running.....then i opened my bonnet and the fan seems be from the radiator (the bigger one, if i m not wrong...coz carpark quite dark)! I tried to turn on the engine again n turn it off......but the fan is still running. I only managed to stop it after stepping on the accelator a few times. Is this normal?? or is there something wrong with my A5?? ↡ Advertisement Link to post Share on other sites More sharing options...
Route88 2nd Gear September 14, 2007 Share September 14, 2007 Normal leave it as it is Link to post Share on other sites More sharing options...
Othello Supersonic September 14, 2007 Share September 14, 2007 aiyoh sis .... this is very normal for conti cars i think .... my old FIAT also behaves this way, and my A4 Octy too !! But never happen in my other jap/korean cars .... what happened was that the thermostat detects high temp and thus activates the fan to operate for a while .... dun worry, there's nothing wrong .... by the way hor, the fan din go off becos u stepped on the accelerator hor !! Link to post Share on other sites More sharing options...
Route88 2nd Gear September 14, 2007 Share September 14, 2007 Machiam turbo timer Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 14, 2007 Share September 14, 2007 do you mean you also off the electrical in your car meaning you remove your key? or electric is still ON but only engine is off? if it is the latter,it is normal. but if it is the former,it is really puzzling. Link to post Share on other sites More sharing options...
Dudemobile Neutral Newbie September 14, 2007 Share September 14, 2007 Yep, I've on my second Skoda, and it's normal. The car will continue to cool the engine even when it's off. These cars have alot of electrics working even without the key. When you park in a quite place, unlock the car and open the driver door. You will hear some motor turning for around 2-3 secs. Link to post Share on other sites More sharing options...
Othello Supersonic September 14, 2007 Share September 14, 2007 When you park in a quite place, unlock the car and open the driver door. You will hear some motor turning for around 2-3 secs. bro, what is that ah ? I discovered that recently too. Initially thought it was some other car/stuff/thing, then realised its my car. And if I remember correctly, the sound only appears if you open the Driver's Door ..... weird Link to post Share on other sites More sharing options...
Beanoyip Turbocharged September 14, 2007 Share September 14, 2007 The fan turns when your switch off everything. It's the characteristic of the car. Esp when you have been driving the car quite hard for that journey. Most likely the fan will still be blowing for 1-2 mins even after you switched off everything. Link to post Share on other sites More sharing options...
Dudemobile Neutral Newbie September 14, 2007 Share September 14, 2007 I tried looking everywhere, almost 5 yrs now. Still can't find it. I suspect it's the fuel pump or something like that (i could be very wrong). My new A5, the wipers will move to a lower position when i turn of the ignition, where you can actually see and hear them move, macham disarm position liddat. That's why i love these cars, they are very technoligically advanced for the humble entry level models. My A5 will automatically put the wipers in INT mode, when the car is stationary, and resume to the driver set speed when moving. Link to post Share on other sites More sharing options...
Dudemobile Neutral Newbie September 14, 2007 Share September 14, 2007 My A5 fan sounds like those old merc. My A4 fan concked off ard 120k km, but no overheating at all untill my service at 135k km, the fault code was set off. Link to post Share on other sites More sharing options...
Volk74 Neutral Newbie September 14, 2007 Share September 14, 2007 Same here... Knew that our cars have this in-built turbo timer....fans will continue to turn for a minute or two..after switching off engine, pull out key, close and lock door... also noticed that once open the driver door, there are something being swtiched on already... Link to post Share on other sites More sharing options...
Ommph Clutched September 14, 2007 Author Share September 14, 2007 So it is normal that the fan continues to run after i off everythin n took the keys out la???!!! I tot my car haunted or the carpark haunted loh!!!!!!!!!!!! wah biang.....nearly die from scares.... Then wat caused it to stop?? since stepping on the accelator is not the one.......A5 got turbo-timer meh? Does this often happens? coz this is my 1st time encountering this. N i m glad to know dat there is a sound when one opens the door.....coz i was abt to ask dat too...wahahah! Link to post Share on other sites More sharing options...
Volk74 Neutral Newbie September 14, 2007 Share September 14, 2007 It should be control by a thermostat...it will stop when the temp is lower to a preset value... not hantu lar...dun worry Link to post Share on other sites More sharing options...
Cantona156 Clutched September 14, 2007 Share September 14, 2007 You need a very good strong battery then. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear September 14, 2007 Share September 14, 2007 Didn't know that this is one of the feature of conti rides until today Since the rest of the Bros have said that this is normal hence you don't have to worry Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie September 14, 2007 Share September 14, 2007 bro no worries, same happens to me, everytime i open the door there is a short electric current sound like that last for 3 secs. as for the engine, its good that the fan is running to cool the engine irregardless its on or off. mine failed on me and i had to change the water pump, gasket, pipes...etc.....cos my engine nearly got burnt...temp hit beyond red line. Link to post Share on other sites More sharing options...
Tckrto 2nd Gear September 14, 2007 Share September 14, 2007 (edited) but your engine is off liao... coolant is not circulating right? den the fan just blow on the radiator area nia leh not the engine. Edited September 14, 2007 by Tckrto Link to post Share on other sites More sharing options...
Fortress Clutched September 14, 2007 Share September 14, 2007 Hi All, Just need to check if the following scenario is normal (coz i never encounter this for my past 2 cars): After turning off the engine of my car, I walked out and hear a fan running.....then i opened my bonnet and the fan seems be from the radiator (the bigger one, if i m not wrong...coz carpark quite dark)! I tried to turn on the engine again n turn it off......but the fan is still running. I only managed to stop it after stepping on the accelator a few times. Is this normal?? or is there something wrong with my A5?? Happened to all me 22 continental cars in the last 20+ years. It is quite normal to have the radiator fan running even after you have switch off the engine, this is especially useful in countries that have high summer temperature. This is because, the cooling water is heated up and if the engine/fan is switched off, you will find water coming out of the reservior. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
You thought it is F1 track meh.........
Budget 2025 - February 2025.
