Jl1500k Clutched September 17, 2007 Share September 17, 2007 Hi, for those who drive manual gear do you often use engine brake to redure speed when cornering or stopping? ↡ Advertisement Link to post Share on other sites More sharing options...
Kwchan 1st Gear September 17, 2007 Share September 17, 2007 if not how? step on the clutch and brake together? Link to post Share on other sites More sharing options...
Hermit 1st Gear September 17, 2007 Share September 17, 2007 i drive both manual and auto yes, i do. for auto tranny- i used it mainly during decending a hill/ mountain. eg. Genting/ Cameron But there are some who may comment using engine brake is putting unnecessary stress on the engine, thus engaging Neutral when approaching a stop. Their reason: 1)save petrol 2)replacing brake pads are much cheaper than replacing engine. My reason: 1)reduce stress on the braking system, once broken- it'll just give up on you when you need it most. and all will be too late then. 2)reduce heat generated on the brake pads juz my 2-bytes of info Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 17, 2007 Share September 17, 2007 (edited) yes,don't really like to step the brake pedal. sometimes when coming to a redlight i also use engine brake. Edited September 17, 2007 by Turbonetics Link to post Share on other sites More sharing options...
Herk Neutral Newbie September 17, 2007 Share September 17, 2007 Wrong basics. Manual car use engine brake. Ur engine will not deteoriate........Unless u engage 3rd gear at 150km/h........ Link to post Share on other sites More sharing options...
York Clutched September 17, 2007 Share September 17, 2007 engine wun spoil...but clutch lining worn faster... Link to post Share on other sites More sharing options...
Herk Neutral Newbie September 17, 2007 Share September 17, 2007 True, part of wear and tear. Auto car is automatic engine braking, for manual, gotta do it thyself. Follow wat the school teaches. Its correct driving techniques that might save lives when seconds count. Link to post Share on other sites More sharing options...
Slayer Clutched September 17, 2007 Share September 17, 2007 Hi, for those who drive manual gear do you often use engine brake to redure speed when cornering or stopping? engine braking is just a supplement to your brakes. u reduce speed / stop with your brakes. Link to post Share on other sites More sharing options...
Route88 2nd Gear September 17, 2007 Share September 17, 2007 For manual cars,can try this heel+toe shifting method Link to post Share on other sites More sharing options...
Silhoutte Clutched September 17, 2007 Share September 17, 2007 Hi, I use it all the time when cornering or stopping. Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 17, 2007 Share September 17, 2007 (edited) Engine and exhaust brake are widely used by drivers of heavy transport goods vehicles travelling in mountainous roads. If they use thier air brakes, the brake shoes will wear off too fast. Edited September 17, 2007 by Yeobh Link to post Share on other sites More sharing options...
Genie47 1st Gear September 17, 2007 Share September 17, 2007 Actually the main skill to learn is throttle control. Fine throttle control. An EFI engine can go down to 1.3kRPM w/o stalling. For practice, try going through North Buona Vista (The Gap) on 4th gear w/o touching your brakes. Link to post Share on other sites More sharing options...
Jl1500k Clutched September 17, 2007 Author Share September 17, 2007 (edited) Some pp just put to free gear and use brake when approaching traffic light. I believe alot taxi driver do that too and never use engine brake. Edited September 17, 2007 by Jl1500k Link to post Share on other sites More sharing options...
Crazybugger 1st Gear September 17, 2007 Share September 17, 2007 We should always maintain our car in gear when slowing down or taking corners. Reason is because when the car is in gear, it is under more positive control and also power is available at an instant should there arise any emergency, eg need to swerve to avoid something/somebody etc. ALSO, car in gear corners much more stable and therefore FASTER!! The trick is rev matching so that the shifts are not jerky thus destabilizing the car and making your passengers puke This is where heel and toe technique becomes useful. Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie September 17, 2007 Share September 17, 2007 I was told before that transmission stressed more then engine when gearing down. Any expert advise here? Link to post Share on other sites More sharing options...
Hermit 1st Gear September 17, 2007 Share September 17, 2007 For manual cars,can try this heel+toe shifting method no offense bro, i dun see the use of his 'heel', probably coz he's got a big feet Link to post Share on other sites More sharing options...
Icekitten Clutched September 17, 2007 Share September 17, 2007 Yes I do. Engine brake before entering corners and also while stopping. Only when lazy then I will free gear and brake all the way to stop. My hubby doesn't though. He brakes all the way before entering the corner then downshifts for power to exit. He says it's cheaper to change brake pads than clutch. And he also believes in the theory of wearing out of gears. Link to post Share on other sites More sharing options...
Adwin Neutral Newbie September 17, 2007 Share September 17, 2007 I do.... It is definitely a faster and more safer way to slow down or stop. At least you know you are in control when you need it. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
SCHNELL Engine Oil 5W40
P2096 Check engine light
