Kinetics Neutral Newbie September 23, 2007 Share September 23, 2007 Hi My baby threw a small scrap paper in . Tried removing the screws but still stuck despite trying to jiggle it out. ↡ Advertisement Link to post Share on other sites More sharing options...
Fortress Clutched September 23, 2007 Share September 23, 2007 Hope this helps.... Link to post Share on other sites More sharing options...
Try_conti 2nd Gear September 23, 2007 Share September 23, 2007 you're not asking him to remove the whole dash, are you ? Link to post Share on other sites More sharing options...
Saabest 2nd Gear September 23, 2007 Share September 23, 2007 I do not think you can open this yourself! Is there a lot of noise? If not, let it be. Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie September 23, 2007 Share September 23, 2007 (edited) Did you try to full blast your aircon from the vents?the paper should fly out Edited September 23, 2007 by Streetbumpkin Link to post Share on other sites More sharing options...
Fortress Clutched September 23, 2007 Share September 23, 2007 if he wants to ... Link to post Share on other sites More sharing options...
Slowpoke156 Neutral Newbie October 1, 2007 Share October 1, 2007 Use plastic knife and lift from one end slowly, this vent is only held on by clips. Should be easy once you get a couple of clips out. By the way, the dash is soft, so don't be afraid to use force, it will regain its shape in a few days under the sun. Link to post Share on other sites More sharing options...
Friendstar Supercharged October 1, 2007 Share October 1, 2007 a small paper and it unsettled u ? i'm sure u have more important things to worry about Link to post Share on other sites More sharing options...
Vodkeith Neutral Newbie October 2, 2007 Share October 2, 2007 go get the extendable piont wif magnet at end, hopefuli the screw is alos magnet de Link to post Share on other sites More sharing options...
Try_conti 2nd Gear October 2, 2007 Share October 2, 2007 scrap paper lah, not screws .... magnet won't work ..... maybe powerful vaccum cleaner will .....? Link to post Share on other sites More sharing options...
Fortress Clutched October 3, 2007 Share October 3, 2007 May you can use something with a bluetack at the end to get it out....happened to my son(when he was 1), stuffed things into the bass bin of my speaker at home. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 3, 2007 Share October 3, 2007 Use a screwdriver. Cover the screwdriver tip with a cloth and pry the grill open. ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Car air-con
Car air-con
Dehumidifier recommendations
Old WW2 Relic disposals
