Cyberet Neutral Newbie October 30, 2007 Share October 30, 2007 the first time i had such sound, i thought the brake pads were worn out, i was right, so i went to change the pads, and skim the rotor. however, after about 1k km, the grinding sound came back, what could it be? can only hear it occasionally during braking ↡ Advertisement Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged October 30, 2007 Share October 30, 2007 1) pads too tight? 2) incorrect brake pad used? 3) The type of brakes used? 4) there is free play? can only think of these... but duno correct anot... Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 30, 2007 Author Share October 30, 2007 1) not sure also 2) used back the exact same brand/model as previous 3) 0-400c brake pad 4) free play? u mean steering wheel? Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged October 30, 2007 Share October 30, 2007 duno leh... my fren's mazda 3 also got gringing sound, den realised i think used incorrect pad then the mech say got free play.... thats y got sound.... i giving suggestion only cuz i not very sure. but i know sometimes, it is the rust when u never used car for awhile then starting brake will have sound. that is what i experienced Link to post Share on other sites More sharing options...
Clubace Clutched October 30, 2007 Share October 30, 2007 i think put copper grease on the back of the brake pad. search thru forum... Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 30, 2007 Author Share October 30, 2007 hmm.. can't be rust, mine's a mazda as well, different model haiz.. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged October 30, 2007 Share October 30, 2007 then you got to wait for the experts liao... Link to post Share on other sites More sharing options...
Wolverman Neutral Newbie October 30, 2007 Share October 30, 2007 the first time i had such sound, i thought the brake pads were worn out, i was right, so i went to change the pads, and skim the rotor. however, after about 1k km, the grinding sound came back, what could it be? can only hear it occasionally during braking Bushings! Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 1, 2007 Share November 1, 2007 Jack up the car, turn the wheel manually, if you feel of hear grinding sound chance the pad caliper is not properly retracted. Try bleeding the brake system to remove air bubble at the wheel brake cylinder. If the runing don't produce any grinding sound, the other possiblity is the rotor is not properly skim and and surface is not properly hone and washed to remove minute metal chip residue. Link to post Share on other sites More sharing options...
Nkps 1st Gear November 1, 2007 Share November 1, 2007 the first time i had such sound, i thought the brake pads were worn out, i was right, so i went to change the pads, and skim the rotor. however, after about 1k km, the grinding sound came back, what could it be? can only hear it occasionally during braking go back to the shop... likely happen after a long drive right? cud be overheat pad that causes it, not sure, best is go back to the shop where u change the pad Link to post Share on other sites More sharing options...
Deadsoulz 1st Gear November 6, 2007 Share November 6, 2007 cv joint? turn ur steering to full lock n look inside ur wheel arch. check if the rubber booting is tear? Link to post Share on other sites More sharing options...
Evoluzio Neutral Newbie November 6, 2007 Share November 6, 2007 Check your brake pad. The pad might be rubbing against the disc, so after 1 week ur pads are gone already. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie November 6, 2007 Author Share November 6, 2007 i went to do some firm braking about 10 times from 80km/h to 10km/h.. so far, the problem has not resurfaced for a week.. i guess the surface was not hone/washed properly? Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 6, 2007 Share November 6, 2007 Yes , the hard braking may have caused the pad and disc to bed-in. Link to post Share on other sites More sharing options...
Ben123 Neutral Newbie November 10, 2007 Share November 10, 2007 no lah....new pad and newly machined disc need time to match the surface profile..if i am not wrong it will go away after a while ↡ Advertisement Link to post Share on other sites More sharing options...
Washing machine front loading
Favourite Japanese Songs from 1980-90s
2 lanes turn right to 3 lanes - which lane to go?
Yusheng from Singapore, Malaysia or China
Sound Proofing the car
