Brake Fluid
Yuan
Any recommendation or brand(s) of DOT 4 brake fluid for auto Japanese cars?
any brands will do. can alway get from EXXON or CALTEX. these are respectable companies, so their products do meet the minimum requirement.
Dot 4 Dot 5 no issue... just remember to replace them ard 1-2 year interval, keep the remaining fluid in a store and top up if necessary. stick to same brand and not mix them due to different chemical composition may hv adverse reaction, as not all fluid are created alike.
but use masking tape to seal it tight. the fluid is hydroscopic (can become moist easily), mark date of use.
discard the remaining fluid after the 2 yr period even though properly sealed.
Fluid is best done at a place where mechanical vacumming is used. i suggest at stamford tyre since they r inexpensive.
hahaha....
Just changed my brake pads (Toyota) and SPC DOT4 oil at WS in Yishun...
Total damaged: $135. [sweatdrop]
The mech told me that it is not necessary to change the brake oil unless there is a leak or brake not jiat after changed brake pads. [hur]
Same goes to the ATF Filter and Fuel Pump Filter. I was intend to do change on my 80K service. [hur]
His reason, most car will be sold off within 5 yrs and japs car can tahan for 5yrs just need to do the normal engine oil, ATF, spark plugs and oil filter change will do.... [shakehead]
Anyway he did quite a good job in replacing my brake oil using vacuum to suck out all the old oil and replaced with new oil. [thumbsup]
Not those drain and top up method. [thumbsdown]
try ATE Super DOT4. can be found in alexandra village. under $14 per 1l tin.
or if possible ATE SL.6 which just replaced Super Dot4.
the shop is along the row with the 2 tyre shops, facing OG building.
I believe Dot 3, Dot 4 and Dot 5.1 is one category, and Dot 5 should be another category. Should not mix this 2 category up.
6th Gear
I am working in Bukit Merah. Near Alexandra Village. Can pm me the address and contacts? Thanks!
bro, i dun have any info for u, last time i just pop by and buy only... hehehe...
there is only 2 shops there, stockists in fact...
6th Gear
hahaha....
Which workshop in Yishun? I used to go to a workshop in Yishun Ind Pk A also.
Some cars accepted Dot3 and Dot4 but not Dot5.
So as a rule, always refer to owner's manual.
Dot5 is different type and may damage seals in the brake system.
ha... but the brake fluid set u back by only some $50 at most, include labor to bleed and fix. i wud bother to save $50 if it means saving $500 excess for accident and all load of troubles
6th Gear
I tend to agree with you because there was once I did not flush and bleed my fluid for more than one year. My brakes become soft and spongy. Almost got myself into trouble... [sweatdrop]
After bleeding, it became very effective. [thumbsup][nod]
if you see the drop of your brake fluid which mean your brake pad is going to ware out.
sometime we need to monitor the fluid level. and if you notice the drop it telling you that it time to replace the brake pad. just some word of advice for safety. cheers.
hahaha....
Which workshop in Yishun? can PM me as well?
hahaha....
If this is really the case, then those manufacturer's selling lubricants & spare parts would have to close shop then [laugh][laugh][laugh][laugh][laugh]
