Yeobh 4th Gear May 21, 2008 Share May 21, 2008 City driving and couple with our high temp and humidity, most of the singapore cars brake fluid will have absorbed enough moisture to reduce the brake fluid boiling point to drop as much as 50%. If yr mech have invested in a very simple brake fluid moisture tester he will have more brake business in hand than he can handle. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 21, 2008 Share May 21, 2008 Yes DOT 5 is basically silicon base Link to post Share on other sites More sharing options...
Accord Clutched May 22, 2008 Share May 22, 2008 ATE Germany Link to post Share on other sites More sharing options...
Yuan 6th Gear May 29, 2008 Author Share May 29, 2008 Thanks bro. Already got dot 4 brake fluid from my car made stockist. Apparently, my car made manufacturer does not produce its own brake fluid. So I only take what the stockist in Singapore has. So far changed already it is quite good. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 29, 2008 Author Share May 29, 2008 if you see the drop of your brake fluid which mean your brake pad is going to ware out.sometime we need to monitor the fluid level. and if you notice the drop it telling you that it time to replace the brake pad. just some word of advice for safety. cheers. Noted and thanks for your advice. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 29, 2008 Author Share May 29, 2008 100% agreed with you. Bleed my brakes again. Now the system is better. Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie May 29, 2008 Share May 29, 2008 If I'm changing from dot3 to dot4, how is the flush done in order not have the old dot3 in the system? Cause the other time when i replace and do a flush the mech suck the fluid from the reservoir (don't know the proper name ) till a little bit left, then he top it up with new dot3 fluid. He then worked from the rear left (RL) using vacuum bleeder, topping up the reservoir as the fluid level drop. And continue working his way to the RR, FL and lastly FR. I think he used about 1.5l of dot3 to flush the system. If using this method to switch from dot3 to dot4 will there still be dot3 fluid mixing with dot4. I know they are compatible but what about the diff boiling point? Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 30, 2008 Share May 30, 2008 (edited) The best method is to flush with yr preferred brake fluid until clear fluid flow out of the bleeding nipples. To do this th mech will need a auto refiller to help to do the work so that the master cylinder will not run dry and suck in air. Edited May 30, 2008 by Yeobh Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie May 30, 2008 Share May 30, 2008 Thanks bro, point noted Link to post Share on other sites More sharing options...
Albeniz Turbocharged July 27, 2008 Share July 27, 2008 Borrow this thread for brake discussion. Recently when I brake, I could sometimes hear a soft "Krong" sound coming from the rear. Does anyone here know what is the likely problem? BTW, the rear brake pads and drums had only done about 10,000km as I changed them not too long ago. My vehicle managed to pass the VICOM inspection a few weeks ago. VICOM had a brake test and there was no problem. Link to post Share on other sites More sharing options...
Ldawn88 2nd Gear July 27, 2008 Share July 27, 2008 bro. check the handbrake if it grips the drum at the back. I had the same issue. The AD workshop helped to fix my handbrake and problem resolved. Link to post Share on other sites More sharing options...
Albeniz Turbocharged July 27, 2008 Share July 27, 2008 bro. check the handbrake if it grips the drum at the back. I had the same issue. The AD workshop helped to fix my handbrake and problem resolved. You might be right. I have been parking on gentle slope these past few days. To prevent the car from sliding down, I have been pulling the hand brake higher than usual. I am not sure if my action has resulted on such repercussion on my brakes. BTW, if I leave the problem unattended, will it give rise to more serious problems? Link to post Share on other sites More sharing options...
Ldawn88 2nd Gear July 27, 2008 Share July 27, 2008 For my issue, it was the case of handbrake not able to release fully. So it gripped the drum at the back. So there was this noise when I drove. I am not sure if yours is the same problem. If yes, you'd better get it fixed rather than to leave it unattended. May affect your rear braking. Link to post Share on other sites More sharing options...
Jemjem 1st Gear August 25, 2008 Share August 25, 2008 Hi would like to confirm with if dot 5.1 is the same as dot 3 & 4 cat. I understand from a frd dot 5 is a diff cat. Therefore 5.1 and 5 are same or different cat? Lastly if 3, 4 and 5.1 are the same cat, is dot 5.1 better? Thanks Link to post Share on other sites More sharing options...
Eyke Supercharged August 25, 2008 Share August 25, 2008 dot 5 is different and shouldn't be mixed with 3/4/5.1. 5.1 better but if you don't do a lot of hard braking over a sustained period of time, eg. tracking, then 4 is good enough... Link to post Share on other sites More sharing options...
Jemjem 1st Gear August 25, 2008 Share August 25, 2008 Hihi Ic. Cos say Car***e dot 5.1 selling at giant tampines last week end at price close to dot 4 selling at patrol kiosk. Any suggestions which will u chose? I have never change brake fluid b4.. sorry for the noob qns. :) jemjem Link to post Share on other sites More sharing options...
Yuan 6th Gear August 25, 2008 Author Share August 25, 2008 Need to change brake fluid around once per year or 2 years to keep your braking system efficient and effective. Link to post Share on other sites More sharing options...
Karie Neutral Newbie August 25, 2008 Share August 25, 2008 DOT 5.1 is higher grade ( Fully Synthetic ) juz like engine oil....so is up to u whether u prefer to use a slightly lower grade DOT 4 or even 3. If the price for DOT 5.1 is close to DOT 4 WHY use DOT 4 ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
