Strawberrypink Neutral Newbie June 7, 2008 Share June 7, 2008 pulled out all my wisdom tooth when i did braces. dr singh (surgeon) ko djeng dental lucky plaza 5th floor ↡ Advertisement Link to post Share on other sites More sharing options...
Qpik Supercharged June 7, 2008 Share June 7, 2008 hmmm....i doono why not allowed... i knew at AH they can though MC i doono how many days u will get... even for complications during tooth extraction, no worries, they sure will not make you suffer Link to post Share on other sites More sharing options...
Comfy 1st Gear June 8, 2008 Share June 8, 2008 hi..anybody have lobang for good and experience dentist ? am looking for wisdom tooth extraction Always had a phobia visiting dental..been eating painkiller/antibiotic to stop the unpleasure feeling on the gums/tooth. After a few months , pain back again..sian 1/2 is there any pain during the minor op ..? I have take x-ray and found there are 2 wisdom tooth great, at least you are smarter than me, i got no wisdom tooth so no need to extract i got wisdom tooth but no need to extract ley.. Link to post Share on other sites More sharing options...
Achtung 6th Gear June 8, 2008 Share June 8, 2008 Gonna pay about 500 plus to remove TWO @ the same corner. hi..how much do they charge per wisdom tooth? Mine was quoted 300++ depending on the position of the tooth There is one dental clinic located at cbd ..charge me 800 per wisdom all dentist advise surgery .. Link to post Share on other sites More sharing options...
Mazdaowner Moderator June 8, 2008 Share June 8, 2008 Sister, your tooth extraction can go AH do meh? Thought yours would have to be at least a vet at Singapore Zoo? Tiger mah. Link to post Share on other sites More sharing options...
Leslielai 1st Gear June 8, 2008 Share June 8, 2008 Dr Wu loo cheng? Link to post Share on other sites More sharing options...
AngelEye Neutral Newbie June 8, 2008 Share June 8, 2008 Uh? you did yours under GA?LA should be sufficient. You should be conscious to respond to the nurse and doctor, who would from time to time enquire whether you feel any pain. This is to access his approach to the extraction/surgery. The team would do some commentary and update you of the status of the procedure. Male. wisdom tooth is under General Anaesthesia... u will be sleeing thru out, pain only after the anaesthetic drug wears off well, it it's a straight forward wisdom tooth w/o any complications yes you can opt for LA, during LA u will hear and see the instrucments they use. some ppl will freak out. esp knowing how much blood u can actually lose from the surgery itself. Post surgery is standard 5-7 days rest. Link to post Share on other sites More sharing options...
Antonee 6th Gear June 8, 2008 Author Share June 8, 2008 Mine was lower 2 wisdom Btw, during ur tooth extraction, did u feel any pain or already numb liao after the injection? How come didn't settle all of them while you were in NS? During NS time, there wasnt any pain/unpleasure on my gum/wis tooth, so i bochap.. only now in my 20s, pain came Link to post Share on other sites More sharing options...
Antonee 6th Gear June 8, 2008 Author Share June 8, 2008 hmmm....i doono why not allowed... i knew at AH they can though MC i doono how many days u will get... even for complications during tooth extraction, no worries, they sure will not make you suffer After the extraction, will the stitches ard the gum traped any food debris when eating? is there any needle poke sensation ard the gums ah.. Link to post Share on other sites More sharing options...
Route88 2nd Gear June 8, 2008 Share June 8, 2008 So young got tooth problem? Link to post Share on other sites More sharing options...
Route88 2nd Gear June 8, 2008 Share June 8, 2008 U have to return back to dentist for the stitch removal. FOC Link to post Share on other sites More sharing options...
Antonee 6th Gear June 8, 2008 Author Share June 8, 2008 since young till now, sometimes i opened my mouth and tried to close it. My jaw a bit slanted and have to open it again and close it My usual go dental clinic appt is quite packed.. have to wait for my turn to get it done. Now the pain ard my gum/wis tooth gone already. Btw, one wis tooth 5 days mc , If 2 w/s, 10 days mc ah Link to post Share on other sites More sharing options...
Curahee 1st Gear June 8, 2008 Share June 8, 2008 (edited) Male. wisdom tooth is under General Anaesthesia... u will be sleeing thru out, pain only after the anaesthetic drug wears off Wah my surgery juz inject the drug and numb my gun only. Den proceed to slice up the gum and extract the tooth. Damn it i dunno. The whole 2 hr plus sit there suffering thru out the process for the 4 wisdom tooth surgery. Almost wanna faint. Edited June 8, 2008 by Curahee Link to post Share on other sites More sharing options...
Route88 2nd Gear June 8, 2008 Share June 8, 2008 Dont ectract 2 at one go...rugi. Spread the extraction,get 10 days m/c Link to post Share on other sites More sharing options...
Antonee 6th Gear June 8, 2008 Author Share June 8, 2008 ok..wat does the gum look like after w/s removed.. any scar ,colour pink/ swollen? urs did at hospital or dental clinic .. Qpik rec @ AH for pain-free removal Link to post Share on other sites More sharing options...
Route88 2nd Gear June 8, 2008 Share June 8, 2008 Dentist injected pain killer analestatic ...i tink Dental clinic. After removal it will heal up and look like any other gum,without a tooth,felt empty. Qpik scared needle Link to post Share on other sites More sharing options...
Albeniz Turbocharged June 8, 2008 Share June 8, 2008 (edited) I never had the wisdom tooth issue. Is it because wisdom tooth does not occur on everyone? Edited June 8, 2008 by Albeniz Link to post Share on other sites More sharing options...
Rollagt 5th Gear June 8, 2008 Share June 8, 2008 I went to NTUC Denticare..NTUC enjoy slightly cheaper rate. Dun procrastinate..after the whole process is over U will ask urself why dont you visit the dentist earlier.. There is a research saying toothache is the most unbearable pain compared to other aliments.. ↡ Advertisement Link to post Share on other sites More sharing options...
Inspiring Words of Wisdom
Desmond's wisdom:If your wife is unable to cook
Any recommendation for head unit with blue tooth?
BMW X6 blue tooth speaker
Split Tooth..Need Advice
5 Pearls of Wisdom!
5 Pearls of Wisdom!
What blue tooth head set is this ah?
