Knighthunter 4th Gear December 28, 2008 Share December 28, 2008 Anyone has experience with Omnia 16gb doesn't responding to incoming call? I missed couple phone calls since last week, the phone it doesn't ring at all only when I reset the phone the problem gone. usually when this happen the power button blinking red. Mac ID can be seen on your router, disable the mac filter and connect the phone via wifi, check and save mac ID then turn on the mac filter again. ↡ Advertisement Link to post Share on other sites More sharing options...
Fourth 2nd Gear December 28, 2008 Share December 28, 2008 Yesterday got a prob w my omnia. Was toking to my friend using bluetooth while driving. After ending the call, i find that my omnia's screen blackout. i have to take out my battery n put it back again to get the phone working again. what happen???? I had same problem. Software upgrade will resolve it. Link to post Share on other sites More sharing options...
Help1 1st Gear January 7, 2009 Share January 7, 2009 Hi, Has anyone upgraded to the latest firmware to address the battery consumption issue? Does it really works? Link to post Share on other sites More sharing options...
Mydotcom 1st Gear January 7, 2009 Share January 7, 2009 Latest firmware really address the battery consumption issue. Batt doesn't drain so fast after upgrade. Link to post Share on other sites More sharing options...
Robo 2nd Gear January 7, 2009 Share January 7, 2009 go to tt web site and d/l can liao right?? Link to post Share on other sites More sharing options...
Help1 1st Gear January 7, 2009 Share January 7, 2009 Latest firmware really address the battery consumption issue. Batt doesn't drain so fast after upgrade. thanks alot :) Link to post Share on other sites More sharing options...
Ms_tan Neutral Newbie January 8, 2009 Share January 8, 2009 Omnia is not cheap right, if wanna buy w/o upgrading. Omnia is quite big as compare to my current HTC.. But my HTC don't comes with GPS so need to change a new phone. Link to post Share on other sites More sharing options...
Guyver 1st Gear January 9, 2009 Share January 9, 2009 Omnia is not cheap right, if wanna buy w/o upgrading. Omnia is quite big as compare to my current HTC.. But my HTC don't comes with GPS so need to change a new phone. Think can get Omnia for about $600-$650 for a used one. Link to post Share on other sites More sharing options...
Ms_tan Neutral Newbie January 9, 2009 Share January 9, 2009 That's ex... Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 9, 2009 Share January 9, 2009 Anyone has experience with Omnia 16gb doesn't responding to incoming call? I missed couple phone calls since last week, the phone it doesn't ring at all only when I reset the phone the problem gone. usually when this happen the power button blinking red. Mac ID can be seen on your router, disable the mac filter and connect the phone via wifi, check and save mac ID then turn on the mac filter again. i think your phone could be left lying face down. this function can be disabled. Link to post Share on other sites More sharing options...
Ms_tan Neutral Newbie February 2, 2009 Share February 2, 2009 (edited) Hihi, need to ask.. My bro had just bought his Omnia last week. Can mapking be used in omnia? If not, what is the software he can uses? Btw, SG only sells 8gb now? Edited February 2, 2009 by Ms_tan Link to post Share on other sites More sharing options...
Jeo01 Neutral Newbie February 2, 2009 Share February 2, 2009 I don't know anout free wifi at Mac.... I have connected with wireless@sg and no probs.... I will try at Mac one day and let you guys know..... After playing with some themes, here's my latest download and installed.... chio leh bro...where u download from? Link to post Share on other sites More sharing options...
Jeo01 Neutral Newbie February 2, 2009 Share February 2, 2009 Wow!! Really cool shell! What's it called? I really like the weather and the clock. I just installed spb mobile shell last night. Playing around with the themes right now. spb need to pay rite? Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear February 2, 2009 Share February 2, 2009 I have loaded Mapking R12 onto my omnia and it worked fine. However you will need to install a port splitter first. The setup and configurations can be found here: mysamsungomnia. It takes quite a while to lock the co-ordinates on the initial setup but thereafter it's ok. But must always remember to activate the port splitter before running Mapking. Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear February 2, 2009 Share February 2, 2009 Mine is a "friendly" version... Link to post Share on other sites More sharing options...
Watwheels Supersonic February 3, 2009 Share February 3, 2009 (edited) Hihi, need to ask.. My bro had just bought his Omnia last week. Can mapking be used in omnia? If not, what is the software he can uses? Btw, SG only sells 8gb now? As long as any pda phone running on WindowsMobile OS it can run most of the Mapking versions. I installed the MK2007 in my Omnia. Btw the bluetooth as I found out it's not very friendly, hence if you wanna buy a bluetooth hands free earpiece/car kit make sure it's compatible with the Omnia. Edited February 3, 2009 by Watwheels Link to post Share on other sites More sharing options...
Ken1898 1st Gear February 24, 2009 Share February 24, 2009 I bought the Omnia last Saturday, this is my 4th WM phone and since my first, I refuse to go back to symbian.... GPS, it is free, signals are free to air, but for the first initialisation, it may take quite some time. Therefore, best is to use AGPS for the first time. That will incur data download charges. AGPS mean your phone will use GSM signals to interpolate where your current position s and then depending on time of day, will then know which satelittes are in the sky for the phone to pick up the signal to obtain a position fix. For the Omnia, you are porvided with AGIS maps for navigation. AGIS is good in that you could do search by postal code. But the map coverage is only for singapore and Malaysia. For samsung phone, you could download Garmin Mobile XT, which then there are tons of maps for you to use. But these maps may not be free. You could download Singapore, Malaysia maps on malsingmap.com, but the free map is not complete. Further, Garmin Mobie Xt is not completely free, once download and installed, trail period is 2 weeks, afterwhich you will have to purchase the software. But there are resources available on line to go around that, which I will not divulge for fear of being call a sw pirate. Omnia is a wonderful phone, I have no problems with using it at all, in fact it is very finger friendly, no need to use the stylus at all. My previous phone is a Samsung i780 whih I had use for 4 months before purchasing Omnia. The screen is large and on landscape mode is fantastic for GPs usage. Have fun using the phone, get use to it, you may want to register and access ppcsg.com to learn more of the phone. How come my 8GB omnia after deactivate the GPS, my fone doesn't ring. Can get through but no sound no number on the fone. Nothing at all. Got to switch off and on the fone den get back to normal. Only when GPS use. Can anyone enlighten me? Thanks Link to post Share on other sites More sharing options...
Ken1898 1st Gear March 1, 2009 Share March 1, 2009 How to change the default bluetooth userID?? As default is windowsmobile. How to change to another name? ↡ Advertisement Link to post Share on other sites More sharing options...
Android Phones
Android Phones
Any Top Notch Buffet Catering to recommend? PLEASE!!
W212 owners, please check-in
Samsung and Huawei crush Apple's smartphone global share
