Xmark 1st Gear November 17, 2008 Share November 17, 2008 Thinking to change sparkplugs on coming 25K servicing. What is the best time (eg. 20K or 30k) to get our sparkplugs replaced. ↡ Advertisement Link to post Share on other sites More sharing options...
Kr_toy 1st Gear November 17, 2008 Share November 17, 2008 Standard copper plug can last 20k, so depends on what is your typical servicing period, you can suit the timing. What is your car ? Link to post Share on other sites More sharing options...
Xmark 1st Gear November 17, 2008 Author Share November 17, 2008 Corolla fielder. Any good plug to recommend? Link to post Share on other sites More sharing options...
Newcar 1st Gear November 17, 2008 Share November 17, 2008 Just to share, I replaced to Bosch Platimum Fusion [F1-4, FGR7DQ1] lately for my Tom Yam toyota... Do felt some differences , better in respond and FC wise.. just a little better for city driving. Wherelse when drving in the North, gain about 50km more at half fuel tank mark when compare to normal copper plugs... Same plugs goes to Avante 1.6L for my colleagues and having similar feedback. give it a try which last you 100K km mileage. Link to post Share on other sites More sharing options...
Xmark 1st Gear November 17, 2008 Author Share November 17, 2008 How much will it cost? Link to post Share on other sites More sharing options...
Newcar 1st Gear November 17, 2008 Share November 17, 2008 The market price heard is about range of S$80 to S$100... I do not about current price since long time did not visit my usual work shop...! For mine, got a extreme good proce from their factory (In overseas)... almost buy 1 get 1 free when compared to local price... Just make sure that the mechanic don't touch your plugs on every servicing after replace to the 100K mileage plugs. Would PM my usual workshop soon... Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 17, 2008 Share November 17, 2008 Denso Iridium long life plugs, SK20R11, Iridium with 0.7mm diameter center tip and Platinium coated ground electrode, can also last 100k km Link to post Share on other sites More sharing options...
Ronnchee Clutched November 25, 2008 Share November 25, 2008 SK20R11 can be used for Mazda 3SP ?? Currently I am using Denso, already travelled 30k km. Think time to change sparkplugs. Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 25, 2008 Share November 25, 2008 which denso plugs are you using now Link to post Share on other sites More sharing options...
Ronnchee Clutched November 25, 2008 Share November 25, 2008 Currently using Denso IK16. Always wanted a better plugs. Link to post Share on other sites More sharing options...
Darkblue 1st Gear November 25, 2008 Share November 25, 2008 Normal copper, every 20K (no track or racing conditions) Link to post Share on other sites More sharing options...
Lab4games 1st Gear November 26, 2008 Share November 26, 2008 stock plug r cheap and good enough for normal usage. plugs that say it could last for 100k may not really last till 100k. sometimes one may have to change it earlier. so i still prefer stock plug and change every 20K. use cheaper sync oil and change every 5k better than use long OCI oil and change every 20k right? Link to post Share on other sites More sharing options...
Fortress Clutched November 26, 2008 Share November 26, 2008 Do have a look at your service manual which will advise you appropriately. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 26, 2008 Share November 26, 2008 Thinking to change sparkplugs on coming 25K servicing. What is the best time (eg. 20K or 30k) to get our sparkplugs replaced. save the resources and recycle the old sparkplugs... learn how to do gapping for your old sparkplug. Invest $10 on 1 set of gapping tools and another $10 on a sparkplug oppener.... 1 set of copper sparkplug will easily last 100k km. The gapping should be done ideally every 20k km, its eazy as 1,2,3.... just search around google and you can find out how to DIY. Link to post Share on other sites More sharing options...
Xmark 1st Gear November 26, 2008 Author Share November 26, 2008 I'm thinking to use the stock plug also. Anyway, how much does the stock plug cost? Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 26, 2008 Share November 26, 2008 Currently using Denso IK16. Always wanted a better plugs. ok, you can use SK20R11 if you want to Link to post Share on other sites More sharing options...
Ronnchee Clutched November 26, 2008 Share November 26, 2008 (edited) I bought my IK16 from Waterloo Street, Tye Soon. Mazda authorised workshop Shell Proserve also recommended me to use SK series. Anyway, what are the differences between the two, other than replacable at 100k km. Btw, what is the price bro ? Edited November 26, 2008 by Ronnchee Link to post Share on other sites More sharing options...
Tohto Hypersonic November 27, 2008 Share November 27, 2008 (edited) Corolla fielder. Any good plug to recommend? Since Toyota Fielder is a JDM car, it might came with factory fit Denso Iridium plug. If so then you can change the plug at 40k. Fielder is using the same engine as Allion, my Allion is using Denso Iridium from factory. You might want to check your plug. Edited November 27, 2008 by Tohto ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Budget 2025 - February 2025.
Change Disc Rotors
Change Disc Rotors
X for twitter change request
