When to change sparkplugs
Xmark
'IK' series have a Iridium 0.4mm diameter center tip electrode and a normal alloy ground/side electrode.
'SK' series have a Iridium 0.7mm diameter center tip electrode and a Platinium coated ground/side electrode, that's why it can last much longer.
A standard copper plugs will have a 2.5mm diameter center tip electrode.
will PM you.
Thinking to change sparkplugs on coming 25K servicing. What is the best time (eg. 20K or 30k) to get our sparkplugs replaced.
save the resources and recycle the old sparkplugs... learn how to do gapping for your old sparkplug. Invest $10 on 1 set of gapping tools and another $10 on a sparkplug oppener.... 1 set of copper sparkplug will easily last 100k km. The gapping should be done ideally every 20k km, its eazy as 1,2,3.... just search around google and you can find out how to DIY.
Bro, for info, normally where to buy the gapping tools? autobacs? thanks
stock plug r cheap and good enough for normal usage. plugs that say it could last for 100k may not really last till 100k. sometimes one may have to change it earlier.
so i still prefer stock plug and change every 20K.
use cheaper sync oil and change every 5k better than use long OCI oil and change every 20k right?
Ya juz brought spark plug @ authorised dealer @ verasammy rd only $15 - 4pcs. THey told me next change 20K. Cheap & Good [laugh]
Hi,
I have a set of used Denso Iridium IK16 spark plugs, clocked 1200km before removing from my previous ride. Is it advisable to install into my new ride? The spark plugs appearance wise dun look like "new".
Same thinking! [thumbsup]
do u know where i can find the plug gap distance for lancer CS3? Cant seem to find on google.
Ya juz brought spark plug @ authorised dealer @ verasammy rd only $15 - 4pcs. THey told me next change 20K. Cheap & Good [laugh]awesome price for stock plugs I'd say, they carry any better aftermarket ones? [sly]
Same here.
I too prefer to use the normal copper plugs. Cheap & good plus I get a fresh set every 20k km. [thumbsup]
Using those ex plugs r good if u r in a place where it is difficult to get spark plugs or change them.
In SG, almost every spare parts shop has plugs. But I do prefer to use those Made In Japan plugs as I find the quality is better & can really last 20K km without any noticeable drop in power up to 20K km even.
The worst plugs I tried was the Made IN Msia type. [thumbsdown] I did try the Indo & Thai plugs & found them quite good also.
I am now trying the Made In Korea plugs on my Optra but intend to change to the Japan plugs at the next change. [nod]
Edited by Pisces69
The main problem I feel with re-gaping plugs is the crushable washer might not give such a good seal if the plugs r screwed in again.
Plugs r cheap & easily available. I just replace at 20K km for peace of mind. I have seen plugs leaking around the ceramic joint even. Definitely not good for the engine. [sweatdrop]
