inlinesix Hypersonic January 6, 2021 Share January 6, 2021 12 minutes ago, Vince218 said: -> Original PS4 ( 235/40R18 ) is 95Y, indicated on the tire show max 340 kpa..... means i can pump air to 340kpa without any risk? on the chassis indicate recommend air pressure 220/230kpa. -> Good Year Efficient Grip Performance ( 225/45R8 ) 95W, not sure the max kpa -> Hankook Prime3 ( 225/45R18 ) 95W, not sure the max kpa Follow manufacturer recommendation 230kpa ↡ Advertisement Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 6, 2021 Share January 6, 2021 (edited) 9 hours ago, inlinesix said: Follow manufacturer recommendation 230kpa ok go it, thanks but what if next time when i change to smaller size tire, how to calculate the suit air pressure? Edited January 6, 2021 by Vince218 Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 17, 2021 Share January 17, 2021 On 1/6/2021 at 8:24 PM, Vince218 said: ok go it, thanks but what if next time when i change to smaller size tire, how to calculate the suit air pressure? NO NEED TO calculate refer to car manufacturer recommendation. owners manual or door pillar , fuel cap cover dont follow tire sidewall 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 17, 2021 Share January 17, 2021 48 minutes ago, Roberttan said: NO NEED TO calculate refer to car manufacturer recommendation. owners manual or door pillar , fuel cap cover dont follow tire sidewall If load index is different from factory spec, need to increase or decrease tyre pressure. Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 18, 2021 Share January 18, 2021 i only know we follow the same tire pressure as recommended example (cold pressure) tire size load index pressure 225/45/17 94W 230 kpa (STANDARD LOAD) 250 kpa (full load) so you can inflate 230-250kpa depending on your own preference my understanding XL= extra load= for same tire same pressure = can carry heavier load (correct me if i am wrong) so to me always use manufacturer as guide line, i just pump 230kpa for comfort 250kpa for better fuel consumption ↡ Advertisement 1 Link to post Share on other sites More sharing options...
D1 Spec Brake Pads - Don't be fooled.
Full spec airbags for all PHV/Taxi
Glasses for anti glaring
Opinion on Dunlop Direzza Z1 Star Spec
B spec racing 2012
B spec racing 2012
D1 Spec VSD IV Reivew!!
US spec 2012 Toyota Camry secretly unveiled!! [youtube]
