Beregond Supersonic January 3, 2021 Share January 3, 2021 (edited) 3 hours ago, Vince218 said: Referring to the 1st pic below is ,my car honda civic turbo, the RIM is 8' width equip with 235mm tire width, while referring to a BMW 218i coupe, the M sport RIM is also 8' width but can equip with 225mm tire width. so with this reference i think should be ok to smaller to 225mm width size for my original RIM...... what do you think? if u asking about your honda, and your rim is original honda rim, with original 235/40/18 tyres. then dun need think ma, just back the same size. if u go 225.40.18 , will still fit in, but the diameter of the whole tyre become smaller. and your gap from the fender to tyres become bigger. no to mention the tyre might stretch abit. 235.40.18 tyres is not hard to find ma, why would u change it and compromise unless your tyre urgent blow and u struck at tyre shop and u got no choice? Edited January 3, 2021 by Beregond ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 3, 2021 Share January 3, 2021 17 minutes ago, Beregond said: if u asking about your honda, and your rim is original honda rim, with original 235/40/18 tyres. then dun need think ma, just back the same size. if u go 225.40.18 , will still fit in, but the diameter of the whole tyre become smaller. and your gap from the fender to tyres become bigger. no to mention the tyre might stretch abit. 235.40.18 tyres is not hard to find ma, why would u change it and compromise unless your tyre urgent blow and u struck at tyre shop and u got no choice? ya the RIM is original, but as i attach the screenshot in the previous msg, the RIM width is actually the same as BMW 218i, which is 8 inch width, if 218i can fit with 225/40, then why my Civic can't ? i asked the Honda technicial as well, they won't void warranty if i change to 225mm as long as remain original rim. i wouldn't consider 225/40 actually, but i will consider 225/45... below pic show another reference, as you mentioned the 225/40 is smaller dimension than original 235/40, then 225/45 is a choice. the purpose of i want to change smaller width is just because of wanna feel whether it will lighten the car a bit to increase acceleration and better fuel economy, but i know same time it will reduce the stability, but how big the diff will .. will wait til i change it only know... btw i see the so powerful car BMW 340i also using 225mm width tire only, maybe Civic equip 235mm is a overkill? 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic January 3, 2021 Share January 3, 2021 If you want to improve economy and have a lighter tyre, suggest you research GY EfficientGrip Performance 2. Comes in 225/45/18 I think. My consumption improves by about 0.3km/l (was about 7.2km/l) after replacing the old Dunlops. It is light due to very thin side wall. Cheap and very quiet too. Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 3, 2021 Share January 3, 2021 9 minutes ago, Volvobrick said: If you want to improve economy and have a lighter tyre, suggest you research GY EfficientGrip Performance 2. Comes in 225/45/18 I think. My consumption improves by about 0.3km/l (was about 7.2km/l) after replacing the old Dunlops. It is light due to very thin side wall. Cheap and very quiet too. hey nice, good to hear that, thanks for another choice, initially i was consider the new Hankook ventus prime 3, it is balance between performance and comfort. and cheap haha... rm290 per donat.. btw whats the price of Good year Efficient grip performance 2? Link to post Share on other sites More sharing options...
Volvobrick Hypersonic January 3, 2021 Share January 3, 2021 About SGD 135 for R17. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic January 3, 2021 Share January 3, 2021 1 hour ago, Vince218 said: wouldn't consider 225/40 actually, but i will consider 225/45... below pic show another reference, as you mentioned the 225/40 is smaller dimension than original 235/40, then 225/45 is a choice. the purpose of i want to change smaller width is just because of wanna feel whether it will lighten the car a bit to increase acceleration and better fuel economy, but i know same time it will reduce the stability, but how big the diff will .. will wait til i change it only know... 225.45.18 will be too high, u use the calculator u can see the diameter increase alot, really dun advice u to do that. if your sole concern is acceleration and fc. my advice is go back same size. but pump the tyre pressure higher by 20% , maybe u alway pump 220. pump 250 instead. Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 3, 2021 Share January 3, 2021 (edited) 13 minutes ago, Beregond said: 225.45.18 will be too high, u use the calculator u can see the diameter increase alot, really dun advice u to do that. if your sole concern is acceleration and fc. my advice is go back same size. but pump the tyre pressure higher by 20% , maybe u alway pump 220. pump 250 instead. ya higher by 15mm... mind to know what will happen cause by this higher diameter? normally i pump 220~230... i tried before 250 it's very stiff... and think it's loosing a bit grips... Edited January 3, 2021 by Vince218 Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 3, 2021 Share January 3, 2021 (edited) 51 minutes ago, Vince218 said: ya higher by 15mm... mind to know what will happen cause by this higher diameter? normally i pump 220~230... i tried before 250 it's very stiff... and think it's loosing a bit grips... 225/40 will result in slightly smaller size, 225/45 will result in slightly bigger size, h none has any significant difference. 225/45 will give you less power, slightly slower odo reading than the original meter should read. But we are talking about less than 3 %, no difference it is going to make at all. You spent so much to buy a turbo car, why go cut on tyres brand and size to save that few dollars ? Just enjoy it. Edited January 3, 2021 by Ct3833 2 Link to post Share on other sites More sharing options...
q1n3fer 1st Gear January 4, 2021 Share January 4, 2021 You can use this calculator to check what tyres can fit your rims. (minimum/ideal/maximum) https://www.tyresizecalculator.com/tyre-wheel-calculators/tyre-size-for-rim-size-width-calculator Link to post Share on other sites More sharing options...
Soundphile 3rd Gear January 4, 2021 Share January 4, 2021 no big deal on the sizes, both works for your rims. only Honda engineers will know which side of the limits they spec the car on. Maybe you can try out for yourself to see if the change meets your expectation? Best to experience it for yourself to learn, and do share your experience here for everyone's knowledge too. 👍 1 Link to post Share on other sites More sharing options...
DylanChen 2nd Gear January 4, 2021 Share January 4, 2021 17 hours ago, Vince218 said: ya the RIM is original, but as i attach the screenshot in the previous msg, the RIM width is actually the same as BMW 218i, which is 8 inch width, if 218i can fit with 225/40, then why my Civic can't ? i asked the Honda technicial as well, they won't void warranty if i change to 225mm as long as remain original rim. i wouldn't consider 225/40 actually, but i will consider 225/45... below pic show another reference, as you mentioned the 225/40 is smaller dimension than original 235/40, then 225/45 is a choice. the purpose of i want to change smaller width is just because of wanna feel whether it will lighten the car a bit to increase acceleration and better fuel economy, but i know same time it will reduce the stability, but how big the diff will .. will wait til i change it only know... btw i see the so powerful car BMW 340i also using 225mm width tire only, maybe Civic equip 235mm is a overkill? crazy. y 235 . fd2r only 225/40/18 & many downgrade to 17. Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 4, 2021 Share January 4, 2021 2 hours ago, q1n3fer said: You can use this calculator to check what tyres can fit your rims. (minimum/ideal/maximum) https://www.tyresizecalculator.com/tyre-wheel-calculators/tyre-size-for-rim-size-width-calculator wow, good website to refer... thansk a lot, very useful here, clear and straight forward.. Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 4, 2021 Share January 4, 2021 2 hours ago, DylanChen said: crazy. y 235 . fd2r only 225/40/18 & many downgrade to 17. need to ask honda liao... 235 is the original size that offer for latest facelift turbo highest spec version... i tested pre facelift one before i book it, end up i bought facelift one , after i got my car i feel like it a bit heavier and slower than pre facelift one.. so that's the feel of 215/50R17 ( old ) vs 235/40R18 ( facelift )... Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 4, 2021 Share January 4, 2021 30 minutes ago, Vince218 said: wow, good website to refer... thansk a lot, very useful here, clear and straight forward.. So the calculator shows the minimum can be fitted in 215mm... thats great.. i put 4 configurations below, it looks like the 215/45R18 is the closest to original one in terms of the outer diameter and side wall... any comment? anyone? Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 4, 2021 Share January 4, 2021 2 hours ago, DylanChen said: crazy. y 235 . fd2r only 225/40/18 & many downgrade to 17. Latest Type R is running on 245/30 20" Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 4, 2021 Share January 4, 2021 55 minutes ago, Vince218 said: need to ask honda liao... 235 is the original size that offer for latest facelift turbo highest spec version... i tested pre facelift one before i book it, end up i bought facelift one , after i got my car i feel like it a bit heavier and slower than pre facelift one.. so that's the feel of 215/50R17 ( old ) vs 235/40R18 ( facelift )... The heavy could be coming from heavier rim + heavier tyre. 215/50 17 has an overall diameter of 646.8mm 235/40 18 has an overall diameter of 645.2mm Wider tyre has to do with lower profile + bigger rim Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 4, 2021 Share January 4, 2021 19 hours ago, Vince218 said: ya higher by 15mm... mind to know what will happen cause by this higher diameter? normally i pump 220~230... i tried before 250 it's very stiff... and think it's loosing a bit grips... Check A-pillar. What is the stock tyre load index? What is recommended tyre pressure? If you change the tyre, what is the new tyre load index? Link to post Share on other sites More sharing options...
Vince218 Neutral Newbie January 6, 2021 Share January 6, 2021 On 1/4/2021 at 1:21 PM, inlinesix said: Check A-pillar. What is the stock tyre load index? What is recommended tyre pressure? If you change the tyre, what is the new tyre load index? -> Original PS4 ( 235/40R18 ) is 95Y, indicated on the tire show max 340 kpa..... means i can pump air to 340kpa without any risk? on the chassis indicate recommend air pressure 220/230kpa. -> Good Year Efficient Grip Performance ( 225/45R8 ) 95W, not sure the max kpa -> Hankook Prime3 ( 225/45R18 ) 95W, not sure the max kpa ↡ Advertisement Link to post Share on other sites More sharing options...
D1 Spec Brake Pads - Don't be fooled.
Full spec airbags for all PHV/Taxi
Glasses for anti glaring
Opinion on Dunlop Direzza Z1 Star Spec
B spec racing 2012
B spec racing 2012
D1 Spec VSD IV Reivew!!
US spec 2012 Toyota Camry secretly unveiled!! [youtube]
