Law_ong Neutral Newbie November 27, 2008 Share November 27, 2008 coz u didnt apply brake mah.. you must have discharging sticky slime on the road to slow down the vehicle.. ↡ Advertisement Link to post Share on other sites More sharing options...
Blue2 1st Gear November 27, 2008 Share November 27, 2008 no lah...I use my legs to brake lah...majiam flintstone lah Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 27, 2008 Share November 27, 2008 I think it is better to stick to original pads for $50 unless you find it really too dusty. However, if you choose those total without dust Pads, they are usually less grippy. I think safety should come 1st before beauty. As you know, most daily accidents occurs during mid range speed like 40km/h along heavy traffic expressway, start and stop, then driver's concentration is lacking. Suddenly the front car just stop dead. You jam your brake but just short 20cm of braking distance and hit the front car. The trouble for that little accident is hell of a lot, small repairs can cost a thousand dollars, not to mention the time to go IDAC and without car for 2 or 3 days. aftermarket pads are less dusty and more grippy than stock. The higher performance aftermarket pads will be very dusty but the grip is the best around. Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 27, 2008 Share November 27, 2008 Thought that some aftermarket brake pad are more grippy than the original? you are right, aftermarket pads are generally more grippy than stock (original pads) Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 27, 2008 Share November 27, 2008 wah then your feet must be 粗粗 di....good for tickling your prey huh... Link to post Share on other sites More sharing options...
Blue2 1st Gear November 27, 2008 Share November 27, 2008 my feet is aftermarket type...sticky ah... might not be good to tickle ah.... maybe change to stock first...then can tickle liao Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie November 27, 2008 Share November 27, 2008 sticky and 粗粗...best combination sia... Link to post Share on other sites More sharing options...
Blue2 1st Gear November 27, 2008 Share November 27, 2008 Link to post Share on other sites More sharing options...
Robo 2nd Gear November 27, 2008 Author Share November 27, 2008 thats even worse ah my stock brake pad...(touch wood) still going strong at 100K Er...dun ask me how i do it oso hor mine 2nd hand lahz.. got it at 38k.. the exowner must be those sissy.. go down slope brake see people brake he also brake, take corner he also brake. when i receive the car pads left less than 50% liao... Link to post Share on other sites More sharing options...
Robo 2nd Gear November 27, 2008 Author Share November 27, 2008 Few cheap ones..... normal ferodo, TRW, Bendix, etc. When I changed from stock to ferodo. Bite improved but a little squeaky at times when the pads have not warmed up. You see less brake dust but more silver dust from your rotors . Then TRW I used not too bad. More dust but lesser than stock... but grip is better. Now just changed Bendix Ultimate this morning.... haven't even bed them in yet (or is there any need to???).... very quiet pads Fluid can use the normal cheap Mintex ones. Then again, motul don't really cost that much more... so no need to save in this area lah.... about $13 diff for a litre to flush. i was told by my friends is overkill leh... advise me stick to stock ones cheap and lasting..unless i change the entire brake kit.. but i think its not necessary..just sometime on NSH takes abot of time to slow down from 160km/h. but seriously sometimes i feel scared on nsh.. scared my brakes cmi. but so far so good..combine engine brake with foot brake. stocks are just abit dirty.. but tot of trying aftermarket ones.. to see the difference. just not sure which one to bank my cash on.. also will surely flush the fluid. motul seems like a good idea. Link to post Share on other sites More sharing options...
Dwoon 1st Gear November 27, 2008 Share November 27, 2008 (edited) For my case, the stock ones are even more expensive than the normal aftermarket ones like TRW or Ferodo. (About the same price as Bendix Ultimate) So I just went for aftermarket.......better performance, less dust and slightly cheaper. You might want to check out the normal aftermarket pads for your ride to see the price diff. Then decide whether is it worth the extra if its more ex. Of course don't go looking at the high end race pads like Ferodo DS2500, Endless CCX, etc.... these will cost a bomb. Not so applicable for street use too unless you have good rotors & calipers to pair them. The cost of Mintex is like $20/ltr while Motul RB600 is ~ $32/ltr. This is something you only change once in a year or maybe 2 years..... so not worthile to save that few bucks. Actually when you consider pads, its also quite the same.... it'll last some 50 to 60K kms.... that's 2 to 3 years on average (depending on how much you travel in a year). So if the better pads are like 30 to 40 bucks diff.... factored over 2 to 3 years.... not much actually. Edited November 27, 2008 by Dwoon Link to post Share on other sites More sharing options...
Boopoo Neutral Newbie November 27, 2008 Share November 27, 2008 Where to get??? Link to post Share on other sites More sharing options...
Dwoon 1st Gear November 27, 2008 Share November 27, 2008 Your regular workshop should have what you need.... they will throw to you all options and it'll be upto you to choose. Link to post Share on other sites More sharing options...
Blue2 1st Gear November 28, 2008 Share November 28, 2008 like that u worse leh... 12k and the less than 50% oso gone liao Link to post Share on other sites More sharing options...
Yuan 6th Gear November 28, 2008 Share November 28, 2008 thats even worse ah my stock brake pad...(touch wood) still going strong at 100K Er...dun ask me how i do it oso hor You use flintstones method? Stick your foot on the ground to stop the vehicle instead of brake pedal? Link to post Share on other sites More sharing options...
Robin 4th Gear November 28, 2008 Share November 28, 2008 i buy from original from stockist. i recommend u stick to stock pads Link to post Share on other sites More sharing options...
Blue2 1st Gear November 28, 2008 Share November 28, 2008 no choice leh...times are bads Link to post Share on other sites More sharing options...
Solar Turbocharged November 28, 2008 Share November 28, 2008 a few weeks back, i was quoted by a workshop of over $400 for just 2 pair (front) of EBC Yellow stuff brake pads lucky i manage to find a direct distributor in uk.. shipped and i received it in less than a week, costed me only 59pounds+shipping costs. was changed at $20 labor @ workshop.. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
