Garlic 1st Gear January 27, 2009 Share January 27, 2009 Hello everyone, Recently changed timing belt and 3 other drive belts. Been experiencing occasional squeaks on the expressway and during full lock turns thereafter. Squeaking sound is exceptionally loud during full lock turns (both directions). Could this be due to improper installation? There were no squeaking sounds prior to change. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Albeniz Turbocharged January 27, 2009 Share January 27, 2009 Most probably. Better to get it checked by the same mechanic. Link to post Share on other sites More sharing options...
Blue850r Clutched January 27, 2009 Share January 27, 2009 Hello everyone, Recently changed timing belt and 3 other drive belts. Been experiencing occasional squeaks on the expressway and during full lock turns thereafter. Squeaking sound is exceptionally loud during full lock turns (both directions). Could this be due to improper installation? There were no squeaking sounds prior to change. Thanks. Your power steering belt tension not enough. Go back to the mechanic who did the belt, just tighten will do. Not that the mechanic is no good, belts do stretch a little after running in. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 27, 2009 Share January 27, 2009 Squeaking sound can only mean one of the pulleys is not properly tightened. Link to post Share on other sites More sharing options...
Enduro25 Clutched January 27, 2009 Share January 27, 2009 mine also just change recently..so far there's a slight sound heard at the belt area..so far not so loud..i rem my old gti had tis sound b4 ...is bcos of the belt not 'season' yet.. Link to post Share on other sites More sharing options...
Chivas Neutral Newbie March 6, 2009 Share March 6, 2009 my ride's belts tend to Squeak only when i 1st started the engine. be it day or night... does it means that they need to be replaced??? i changed them out @ 40k KM. now only about 55k km. Link to post Share on other sites More sharing options...
Gibwaja Neutral Newbie March 6, 2009 Share March 6, 2009 not tight enough, can ask mechanic to retighten all the belt... Link to post Share on other sites More sharing options...
Chivas Neutral Newbie March 6, 2009 Share March 6, 2009 not tight enough, can ask mechanic to retighten all the belt... okie thanks thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Sound Proofing the car
Rear seat passenger : Do they belt up?
Tool to change Spark Plug
X for twitter change request
Whole car sound proof
COVID-19: Retrenchments
