Proton Exora
Neokn
-Is there a switch to allow both the door side mirrors to fold in???
-Investing on a 16" Sportier Rim will for sure make the exora look much nice.
But I think ur colleague's 2nd row seat of his strem has to be pushed to the front making the ppl in 2nd row a bit squezy.
Maybe but i dont rem he got do any adjustment.Exora second row cannot slide is a weak point.
i think it's really up to individual to rate the spaciousness of a car...if proton can make a car as good as the Wish, that is really saying something...there's a sudden improvement since the launch of the Gen-2 in singapore...
Hmm,I think its after the Persona launch the quality is improving.I do hope that the new Gen2 and Satria Neo CPS is making way here.
The m-line does not have the original black sticker on B & C pillars.
only the H-line has it.
The Front bonnet does not have an inner insulation pad to
protect it from the heat of the engine. which also insulate sound from engine.
No auto fold-in for door side mirrors.
Anyone knows where all these could be fitted professionally to look
like original in Spore.
You go to Proton service ctr in Larkin look for Mr Faizal,All the Exora accessories is there...You know the route to Larkin famous wet market beside the bus terminal?There's a Traffic junction turn right and then turn left and go straight all the way till you see the Proton Ctr on your right.S'pore one is too ex,Unless you can find aftermarket parts
Edited by Mustang
Hi all,
if you bring your proton (s'pore plate), service in authorized proton jb, will the price same with the proton (m'sia plate)
If you're in doubt can always check the price of the parts at the showroom.Last time i bring my friend who is driving a Persona there for servicing.Using Petronas 4litres fully synthtic,Proton ori spark plugs,Oil filters and tandom check all for RM190 including labour charge..
Mustang, thanks for the info. [thumbsup]
No problem Bro,As a Proton owner we ought to take the advantages of having original parts with cheap price across the causeway right?If not i won't be bother to buy a Proton in the first place.
The wheels in the Exora are quite small. So is the ride as bad as the honda Stream?
Bro you cant judge the ride by only looking at the rims only,Agreed the rims is quite small but an 16 incher is worth the try.
any exora owners here care to share on their ride so far.
especially the autogearbox with city driving.
cos I still cant decide either to get auto or manual
tested the auto yesterday at leng kee, found that the shift from 1st to 2nd takes longer than usual.
almost 3,500rpm before it switches.
SA says is designed this way to allow the exora to reach higher rolling speeds faster.
But wont it create higher FC.
[drivingcar]
Blackhawk, to me the engine is ok but the air-con is a bit noisy. Luckly, the noise level is acceptable and it is only for a few seconds when you start your engine. After about two weeks, I'm sort of immune to it.
Panhard, mine is auto-car. Personally, auto pick up is not as fast as manual. If you are one of those drivers who prefer "ZOOM" after green light, I will suggest you get the manual version [drivingcar]
Mustang, what is simota drop air-filter? what are the pro and con to install it? Please share! Lastly, will FC higher if change the wheel to 16" [confused]
Ok bro based on my mum in law Exora,She already trade-in her stock rims for 16 inch BSA 5 spokes rims with Dunlop 205/55 tyres and had to top up another RM500.FC wise it's not much different from the stock ones unless you use more wider and bigger rims..Also to take note your new rims must be more lighter than stock ones!Reviews from my friends using SIMOTA drop in for their Saga/Gen2/Persona/Neo is that the pick up is more smoother than stock ones.Just that and dun believe if people says they gain extra horsepower or top speed by just changing filters.The People at Proton advice that Exora doesn't require to fully depress the pedal for pick up,Just slight press will do and the gear will change smoothly,And after 3rd gear then you can drive you can start to drive your style of driving..
Guest
