Panhard 1st Gear November 13, 2011 Share November 13, 2011 it seems that my petrol consumption have gone up.I'am using 5w30 enging oil! Anyone here have the same problem pls share. any 30 weight engine oil is best for the exora, a syn one would be even better. using 98 does help improve FC.. but dont expect to have good FC if you do alot of short distances & city driving. ↡ Advertisement Link to post Share on other sites More sharing options...
Panhard 1st Gear November 13, 2011 Share November 13, 2011 i'm a heavy user... my FC has always been on the low side. 9-10km/l.. i think i wanna try change my spark plugs to iridium.. hope it help a little.. and maybe try to reduce some load in the car. the only thing i can think of is change the front two seat to sports seats.. much lighter.. remove my spare tyre (risky). has anyone did the 'Cold' air intake in JB before? honestly, changing to iridium spark plugs or high flow air filter is not going to improve FC very much... on the other hand, you ,may want to try increasing tyre pressure to see. what is this "COLD" air intake thing? -maybe you can give more details Link to post Share on other sites More sharing options...
Verve 1st Gear November 13, 2011 Share November 13, 2011 try again and put your cheque book on the table, maybe they will listen. or ask a pi to bring in for you, but looks like you may have to pay more omv. Link to post Share on other sites More sharing options...
Panhard 1st Gear November 13, 2011 Share November 13, 2011 i tried ask at ubi showroom, if i can order manual, it is ok if need longer time, but they said can not :( i wonder what reason behind it. because they have manual version before. it is not like the other brand that have manual in origin country, but never bring in to singapore. if someone have connection with proton singapore and can help me to get manual version, please pm me :) currently, their existing stocks are all auto, they dont intend to bring in any more manual-cos there was some clutch pedal noise on the manuals here which has no solution. Link to post Share on other sites More sharing options...
Panhard 1st Gear November 13, 2011 Share November 13, 2011 anyway have stopped going to Proton Spore to do servicing since they started sub-letting their aftersales to TTS group at sin ming. Cos their charges are much higher & less personalised.-their main support is for fiat cars only. at my 20k svcs with them, they used the ows dexron 3 to replace the atf fluid on the auto transmission. however, the owners manual strictly states use only proton atf SP3 specs. when wrote to them about this issue- no firm reply at all. Link to post Share on other sites More sharing options...
F1f2 Clutched November 14, 2011 Share November 14, 2011 currently, their existing stocks are all auto, they dont intend to bring in any more manual-cos there was some clutch pedal noise on the manuals here which has no solution. hi.., so as you know all exora manual trans in malaysia also have "no solution for clutch pedal noise issue"? thanks for sharing :) Link to post Share on other sites More sharing options...
Panhard 1st Gear November 14, 2011 Share November 14, 2011 hi.., so as you know all exora manual trans in malaysia also have "no solution for clutch pedal noise issue"? thanks for sharing :) honestly, dont know if the latest batch of manuals still have this problem-- anyway not many manuals compared to autos too in "Boleh" Land. Most of the early batch of manual owners already got use to it so they just let it be. Link to post Share on other sites More sharing options...
Shorty Turbocharged November 14, 2011 Share November 14, 2011 hv yet to go for my 6-monthly oil change. no time. lucky i change to a quite gd oil previously. any kakis wanna go together? will wanna try to change at JB. saw one proton service ctr beside holiday plz. anyone tried? Link to post Share on other sites More sharing options...
Panhard 1st Gear November 14, 2011 Share November 14, 2011 hv yet to go for my 6-monthly oil change. no time. lucky i change to a quite gd oil previously. any kakis wanna go together? will wanna try to change at JB. saw one proton service ctr beside holiday plz. anyone tried? I can keep you company when you drive in to JB Link to post Share on other sites More sharing options...
Human Clutched November 16, 2011 Share November 16, 2011 Since mine is a OPC i seldom drive everyday,Once i top up my fuel to full tank the next top up will be 2 wks later.I always top up when the gauge shows half tank. But during this process for a distance of 300 km it shows avg consumption 10.9l/100km.i just recently change to a K&N filter lets monitor and see. Link to post Share on other sites More sharing options...
GoofRider Neutral Newbie November 16, 2011 Share November 16, 2011 how much tyre pressure should i set for front and back? tyre profile for now is 195/60/16 Cold air intake. the one i use to do and other usually do is have a funnel and direct to outside far from the hot engine area to take in cold air to our air filter. but this 'indonesian' air intake they actually tap the cold air from the aircon hose.. so its naturally cold air despite the hot weather outside.. plus the air is 'cleaner' compare to outside air(dusty). i've yet to see it personally, but this guy order it from Indonesia and install it to the msia exora forumers. for COld are intake, pick up does improve as i've install the standard cold air intake on my old honda fit. Link to post Share on other sites More sharing options...
Panhard 1st Gear November 17, 2011 Share November 17, 2011 Since mine is a OPC i seldom drive everyday,Once i top up my fuel to full tank the next top up will be 2 wks later.I always top up when the gauge shows half tank. But during this process for a distance of 300 km it shows avg consumption 10.9l/100km.i just recently change to a K&N filter lets monitor and see. I personally noticed that i get better FC when my fuel tank is not full. think its because of the extra weight you carry. maybe you can just keep the tank half filled most time--since so many petrol kiosk around. that is one way you can get better FC. Link to post Share on other sites More sharing options...
Panhard 1st Gear November 17, 2011 Share November 17, 2011 how much tyre pressure should i set for front and back? tyre profile for now is 195/60/16 Cold air intake. the one i use to do and other usually do is have a funnel and direct to outside far from the hot engine area to take in cold air to our air filter. but this 'indonesian' air intake they actually tap the cold air from the aircon hose.. so its naturally cold air despite the hot weather outside.. plus the air is 'cleaner' compare to outside air(dusty). i've yet to see it personally, but this guy order it from Indonesia and install it to the msia exora forumers. for COld are intake, pick up does improve as i've install the standard cold air intake on my old honda fit. front- 230, rear 250---these readings when cold yes! cold intake air does help, cos night/cool weather driving can always feel that car is more responsive Link to post Share on other sites More sharing options...
Panhard 1st Gear November 18, 2011 Share November 18, 2011 some mod ideas you may want to do on your exora...... Link to post Share on other sites More sharing options...
GoofRider Neutral Newbie November 21, 2011 Share November 21, 2011 jus to share.. on paper exora full tank is 55litres. but i manage to pump up to 62litres from blinking sign on my meter gauge. Link to post Share on other sites More sharing options...
Richard_Peh 1st Gear November 22, 2011 Share November 22, 2011 i tried ask at ubi showroom, if i can order manual, it is ok if need longer time, but they said can not :( i wonder what reason behind it. because they have manual version before. it is not like the other brand that have manual in origin country, but never bring in to singapore. if someone have connection with proton singapore and can help me to get manual version, please pm me :) Or u don't mind getting a high wheel SUV. U may consider Daihatsu Terios 7seater also got manual version. Link to post Share on other sites More sharing options...
Shorty Turbocharged November 22, 2011 Share November 22, 2011 i've been eyeing the last bodykit. must save money first. hehe Link to post Share on other sites More sharing options...
Hubbysr Neutral Newbie December 6, 2011 Share December 6, 2011 HI.. [WTS] COVER SEAT LEATHER EXORA ORIGINAL PROTON INCLUDE ARM REST RM2000 FRONT BUMPER + REAR BUMPER WTH PAINT RM800 FULLSET BODYKIT EXORA FULL SPEC WTH PAINT RM1300 ALL NEW & ORIGINAL PROTON CALL/SMS 019-9362993 ↡ Advertisement Link to post Share on other sites More sharing options...
Vincar to distribute Proton’s first electric vehicle in Singapore
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Proton X50
Proton X50
Proton eMas 5 previewed – rebadged Geome Xingyuan, RWD, 250 to 325 km WLTP
Proton overseas
Proton overseas
New Proton Perdona.
New Proton Perdona.
Proton To Introduce smart Electric Vehicles In Malaysia
