Rezorn86 3rd Gear October 28, 2013 Share October 28, 2013 do you know what talking you? lolx I say wiring issue ↡ Advertisement Link to post Share on other sites More sharing options...
WONWON 1st Gear October 28, 2013 Share October 28, 2013 From what I read, most likely it's the cooling coil sensor or the compressor, but I'm sure most workshop will just say compressor, that'll cost a bomb to replace. So I'm asking around to see if anyone has encountered this problem before. I saw a few posting but no mention of the solution and cost. Link to post Share on other sites More sharing options...
Sharkey 1st Gear October 30, 2013 Share October 30, 2013 Recently my Sylphy's air con has issue, the air flow intake will alternate between fresh air intake and recirculation even though I have it set at recirculation. the problem with this of course is that smell/dust from the outside will flow in and temperature will increase due to hot air intake from outside. See this video. Anyone had this problem before, what was the issue? And what was the remedy and cost? My ride is 2.0, the buttons are a bit different, you have the 3 buttons Clean/ Fresh Air Inatke/Recirculation. Thanks had that problem. then again, i had a compressor problem. I drive a 5-yr old second hand 2.0 Sylphy. I recently had to change my compressor. voila. i didnt even realised it till i read this post, but the problem has not reoccurred since. Link to post Share on other sites More sharing options...
WONWON 1st Gear October 31, 2013 Share October 31, 2013 had that problem. then again, i had a compressor problem. I drive a 5-yr old second hand 2.0 Sylphy. I recently had to change my compressor. voila. i didnt even realised it till i read this post, but the problem has not reoccurred since. Thanks for the feedback. So the symptoms were the same? (1) Alternating air flow in take and (2) Blowing cool hot air (3) No cool air for long periods? How much did you pay for the compressor and whereabout? My Sylphy is 2nd hand , around 5 years as well. So might well be the compressor. Link to post Share on other sites More sharing options...
Shanhz 3rd Gear November 23, 2013 Share November 23, 2013 For this rotating between circulation internal and external, the car is designed like this. Seems like a common european design. Its meant to intro more oxygen into the cabin, which is great in fresh air europe but not here! Anyway, the aircon mechanic just need to disconnect one wire and circulation will stay permanently in internal circulation mode. My mechanic did for me foc when i was changing the coil recently. Link to post Share on other sites More sharing options...
WONWON 1st Gear November 26, 2013 Share November 26, 2013 For this rotating between circulation internal and external, the car is designed like this. Seems like a common european design. Its meant to intro more oxygen into the cabin, which is great in fresh air europe but not here! Anyway, the aircon mechanic just need to disconnect one wire and circulation will stay permanently in internal circulation mode. My mechanic did for me foc when i was changing the coil recently. Actually for the Sylphy, it should not switch automatically. Further more, most of the time, it just stay on fresh air without switching back Tan Chong confirms it's a compressor issue. Link to post Share on other sites More sharing options...
Dennis64 Neutral Newbie December 5, 2013 Share December 5, 2013 Hi, I am driving Sylphy since Nov 2006. Here are the issues I faced : a. Bubbles on dashboard (replaced by TC) b. Change of Shock Absorbers (around 150,000km, change to mileage instead of leaking) c. E Throttle (reduced RPM to 1,000 while driving on expressway, pretty dangerous, replaced at TC around $220) Current mileage is 180,000 km plus. Best speed is 150 - 160km/h on NSHW with 2 male adults, 2 small coffee machine and 2 luggages for 3 hours plus drive non-stop to Kuala Lumpur (Full tank from Tuas to Sungei Besi) So far, my only complaint is the soft suspensions, was recommended to change to BC, Tein or G-Force. But was told that the ride will be harsh. Hmm.. the space is huge, can be a love nest when in need.... hahaha Anyway, any feedback on new Nissan Syiphy ? Enjoy yr Nissan Sylphy. Cheers TC changed the dashboard for you FOC? I have this problem too. Link to post Share on other sites More sharing options...
The_Edge 1st Gear January 3, 2014 Share January 3, 2014 Do any of you know where i can go for nissan sylphy spare parts (other than TC)? Thank you in advance! Link to post Share on other sites More sharing options...
Shanhz 3rd Gear January 12, 2014 Share January 12, 2014 JAE Link to post Share on other sites More sharing options...
Joshterran 1st Gear January 24, 2014 Share January 24, 2014 Recently my Sylphy's air con has issue, the air flow intake will alternate between fresh air intake and recirculation even though I have it set at recirculation. the problem with this of course is that smell/dust from the outside will flow in and temperature will increase due to hot air intake from outside. See this video. Anyone had this problem before, what was the issue? And what was the remedy and cost? My ride is 2.0, the buttons are a bit different, you have the 3 buttons Clean/ Fresh Air Inatke/Recirculation. Thanks Hi, I too encountered this problem with my Sylphy air con. Went to workshop for check, compressor ok (Noisy tack tack sound), coil ok (coolant lost in one two days after topping up). So decided to do a air con system flush, top up coolant w lubricant & change cabin air con filter, cost S$ 60.00. Settled the problem since then. So far so good. Hope this is useful to you. Cheers. Link to post Share on other sites More sharing options...
WONWON 1st Gear February 13, 2014 Share February 13, 2014 Hi, I too encountered this problem with my Sylphy air con. Went to workshop for check, compressor ok (Noisy tack tack sound), coil ok (coolant lost in one two days after topping up). So decided to do a air con system flush, top up coolant w lubricant & change cabin air con filter, cost S$ 60.00. Settled the problem since then. So far so good. Hope this is useful to you. Cheers. Mine was the compressor issue, after the change, everything was ok, the ioniser should switch from Clean to Ion by itself every 15 mins according to some of the comments here. Link to post Share on other sites More sharing options...
Waiker76 Neutral Newbie August 22, 2014 Share August 22, 2014 Anyone driving a 2007 sylphy till now? Wanna know how this car performs after her 7th year.... What are the 'problem' I should look out for after the 7th year mark. (milege close to 100K km) The drive shaft seems to have problem, wonder is there any recommendation of workshop replacing recon or cheap drive shaft ? Advance thanks to those who can help!!! Link to post Share on other sites More sharing options...
YMGoh Neutral Newbie February 26, 2015 Share February 26, 2015 Hi, anyone encounter the air flow intake will auto switching between fresh air intake and in cabin recirculation even though I have set at recirculation. During the auto switching the air sometime cold and sometime hot.The auto switching occur during driving and stop at traffic lights. On certain day, it works as normal after i keep pressing the recirculation button for a few time. Some ppl suggest compressor problem but I have changed the compressor and cooling coil in 2013. http://youtu.be/3jRbIvAZ1LE Link to post Share on other sites More sharing options...
Sax Neutral Newbie March 4, 2015 Share March 4, 2015 BTW, anyone did performance enhancement such as Unichip Q tuning to the 1.5L Sylphy for better response and FC? Link to post Share on other sites More sharing options...
Cicada1810 1st Gear April 19, 2015 Share April 19, 2015 Hi I'm new to this forum, so pls pardon me if I sound ignorant or silly. I registered for 2014 Sylphy in Mar and will be collecting it on 29 Apr. Currently an 06 Altis owner. Hope to learn more from the experienced bros in this forum on the Sylphy. Link to post Share on other sites More sharing options...
Hutan 1st Gear April 19, 2015 Share April 19, 2015 What make you choose Nissan over toyota? The new altis look very sexy. Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 19, 2015 Share April 19, 2015 What make you choose Nissan over toyota? The new altis look very sexy. toyota is probably overpriced by the used car dealer. They can cos they know someone will buy eventually. 1 Link to post Share on other sites More sharing options...
Cicada1810 1st Gear April 23, 2015 Share April 23, 2015 What make you choose Nissan over toyota? The new altis look very sexy. The new Altis is a little too costly for me. So i took a bold step to try the Sylphy. Must say I fell in love once I took the first test drive. I was attracted by the comfort and acceleration was smoother than an Altis. I gueas Im more of a family man who is looking for a smooth and comfortable ride for my lady and 2 little kids. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
MAZDA 6
MAZDA 6
Nissan Preventive Maintenance Programme
Nissan QashQai 2014 Part 2
Honda City 4th Gen
Honda City 4th Gen
